Elektron Analog Rytm – 8 voice analog drum machine with sample support
Elektron Analog Rytm is the name of the new Elektron Drum Box.
8 analog filters and distortion.
analog components are connected internally via digital tech – so it is also a full analog drum synth!
8 voices
Synth DB -> Elektron Analog Rytm groove box with TR sequencer
128 projects – Samples via USB – but it’s not just a sampler but has sample support.
DIN Sync & MIDI.
also analog: compressor @ master section
12 pads are dynamic
drum sounds are made from analog components that can be reconfigured by software (updates)
so this is both – an analog drum machine but also a sampling engine that can be filtered analoguely.
so this is a real analog machine PLUS digital features, routing and a lot of analog components. 1489€
the samples are not analog of course –  filters and distortion are
sample SUPPORT may not mean tooo much sample ram but enough to load what you really need.
Forum: Elektron Analog Rytm
Die neue Maschine hat dynamische Pads,
analoge Filter
ist 8 stimmig
kann Samples einladen (unter dem Begriff „support“, dh das wird nicht so viel Speicher sein–)
analoge Verzerrung und Master Abteilung mit Kompressor
12 dynamische Pads mit Beleuchtung (farbig)
Related posts
