ich habe so eben die Lösung gefunden:
Reset Pitch Bender and Ribbon Controller Procedure:
1) Turn on power while holding [OSC2 SYNC], [-12dB/-24dB] and [FILTER TYPE] to enter Test Mode. Wait until display
indicates "[1] MIDI Test."
2) Press the [3] button to display "[3] Bend Mod."
3) Push the bender lever left fully and gradually return it to the center. Press [LOWER].
4) Push the bender lever right fully and gradually return it to the center. Press [UPPER].
5) Push the bender lever to the MOD position and then gradually return it to the original position. Press [KEY MODE].
6) When the '*' appears on the display, press [UP].
7) From the previous display, press [4] to display "[4] Ribbon."
While pressing down on the left edge of the ribbon controller, press [LOWER].
9) While pressing down on the right edge of the ribbon controller, press [UPPER].
10) While pressing down on the center of the ribbon controller, press [KEY MODE].
11) When the '*' appears on the display, press [UP].
12) Turn off the power of the JP-8000.
Use the following procedure to reset the JP-8000 to factory settings:
1) Turn on the power of the JP-8000. The unit may display "Memory Damaged."
2) While holding [SHIFT], press [INIT/UTIL].
3) Press [INIT/UTIL] repeatedly to select "INITIALIZE WRITE."
4) Use the [UP / DOWN] buttons to select "FACTORY PRESET," then press [WRITE].
After this procedure has been completed, the new version of software should be ready to go.
