8 bit Sample CD
Anonymous
Hey ho,
Kennt jemand was vernünftiges in der Richtung 8 bit Sounds?
Vorwiegend für ne Akai Mpc 2000xl oder emu esi 32
by the way: Mit Akai Import meint der Emu ESI was für ein Format? Sind die bei den s 1000 samplern und MPC die gleichen Formate?
Sieht schonmal gut aus. :supi:
Gear wollte ich mir deswegen nicht zulegen. Ne schicke Sample CD sollte ihren Zweck erfüllen
@xcenter :supi:
Das steht beim emu
0. Akai Import
The Akai Import function allows you to import Programs, Samples or
entire Volumes from the Akai S1000 (and S1100) samplers and convert
them into an ESI-32 bank. Data is imported into the ESI-32, from an
Akai formatted SCSI device. Load time varies and may be either slightly
longer or shorter than the Akai. There are a few fundamental differences
between the Akai samplers and the ESI-32. For this reason a number of
the Akai program parameters are ignored during the conversion process.
In most cases, however, the converted programs and samples should
sound and behave very similarly to the originals.
Und das bei der MPC
Sample files may be loaded from Akai S1000 and S3000 disks.
