Arturia Minibrute 2 & 2S (mit Sequencer)
In ca. 'ner halben Stunde wird sich die nervenzerrende 8) Spannung lösen...
Nach der unteren Zeile gehe ich auch von einer weiteren (Desktop- und/oder Rackversion) des MB2 aus.
Sogar die Daten für den "MB 2S" wurden schon gepostet....besonders interessant dessen Seq-Features :supi:
SEMI-MODULAR SEQUENCING SYNTH
Meet the ultimate sequencer-synth. Everything you know and love about the Minibrute 2, but integrating a powerful, triple-layer sequencer. Where the original Minibrute brought analog synthesis to the masses, Minibrute 2 brings the huge potential of Eurorack modular to a new audience. The Minibrute 2S combines lots of exciting new features without losing sight of what made the original so special: analog tone, powerful sound shaping features, a step-sequencer, and an arpeggiator.
INSPIRING SYNTH POWER
Featuring two of Arturia’s legendary Brute oscillators, the classic Steiner-Parker filter, an innovative looping envelope, and hands-on control for every parameter, Minibrute 2S is a monosynth to be reckoned with. Minibrute 2S is all about freedom: freedom to create totally unique, inspiring sounds; freedom to build a system that’s unique to you; freedom to expand your collection at your own pace.
A MODULAR SOLUTION
One of the most exciting aspects of Minibrute 2S is how perfectly it integrates into modular setups. It features a comprehensive modulation matrix with dozens of sources and destinations, letting you experiment with the instrument’s own sound, or hook it up to synth and effect modules.
ADVANCED SEQUENCING
Swapping out a keyboard for velocity and pressure sensitive performance pads, the Minibrute 2S features a triple-layer, monophonic sequencer that works in the same way as Arturia’s award-winning Keystep controller. You can control your notes with one track, and use the other 2 to sequence parameters like gates, CV, LFOs, and envelopes. You can do this in real-time, or by step-editing.
Features :
Mixable, multi-waveform VCO1 and VCO2 with sound shapers: Sawtooth, Ultrasaw, Square, Pulse, Triangle, Metalizer, and Sine waves, with fine and coarse tuning modes, noise generator, and external input.
Steiner-Parker multimode filter with beefy, acidic tone, capable of self-oscillation. Featuring low pass, high pass, band pass, notch, and bypass.
ADSR envelope generator, and extra multi-mode, CV-controllable AD filter.
Brute Factor™ adds subtle drive effects to full blown intermodulation havoc.
Comprehensive CV Gate modulation matrix with 48 patch points, letting you control many elements of the synthesizer and sequencer.
Two LFOs with multiple waveforms, able to run in sync with the sequence
Intuitive triple-layer Sequencer and advanced Arpeggiator, syncable with MIDI and USB.
High quality, durable performance pad interface with velocity and pressure sensitivity.
Line out, headphone output, dedicated MIDI I/O and USB connectivity.
"As you’ve seen, the top secret Arturia sonic research labs have been busy!
Return tomorrow to discover the third, and final part of the MiniBrute 2 story.
23 57 02 ...
:fressen:
23 57 02 ...
:fressen:
Ah, dann habe ich also morgen noch mal die Chance richtig zu liegen mit dem Tipp, dass eine Erweiterungsbox für die seitlichen Link-Anschlüsse kommt - möglicherweise mit Effekten, Envelope-Follower usw. ....
Aber was anderes. Sehe ich richtig, dass man anders als beim MB1 Modwheel und Aftertouch im Prinzip beim MB2 nur alternativ verwenden kann? Falls nicht, wie legt man z. B. den LFO-Amount für Vibrato auf den Aftertouch und gleichzeitig die Cutoff-Frquenz auf das Modwheel?
Der Sequencer hat wieder kein Glide, nur generelle Slew/Portamento, oder? Also nix 303 funky, funky? Konnten die Brutes/Keystep ja bisher alle nicht intern, nur mit entsprechendem externem Sequencer...
Trotzdem sehr ansprechendes Teil, wenn jetzt auch noch alle Tracks (Pitch, Gate, Velo, Press) unterschiedlich Last-Step Einstellungen haben können, wär das ganze schon eine Überlegung wert... :D
Arturia hat einiges verstanden. Da kann der Mono-Circuit einpacken.
Pitch, Gate und 2xMod, feiner Sequencer.
wenn diese knöpfe nicht so hässlich wären..
irgemndwie eine korg er-1 ..hat was 90s mässiges
Wow, der 2S ist nochmal ne ganze Ecke geiler als der 2, ich bevorzuge auch ohne Tasten hab ja mein Midi-Keyboard dafür hier stehen :D Was damit alles möglich ist gefällt mir echt riesig, dazu dann noch ordentliche Effektgeneratoren anschließen..
Gibt's für den 2S auch schon Preisschätzungen?
Bin mal gespannt ob der dann preislich genauso landet wie der Minibrute 2.
Morgen wird von einem Rackbrute gemunkelt, bin gespannt.
Und morgen kommt der dann?
