Dispatcher (dispatch)
This app routes MIDI note messages from a single channel to several channels. This allows you to play chords on a rack of monophonic synths, for example.
inp 5
Input channel.
mod cyc
Dispatching method:
* cyclic (*cyc*). Each new note is cyclically played on the next channel.
* polyphonic (*pol*). The mapping of notes to channel uses a true voice stealing algorithm. The MIDIpal tries to reuse the same channel for occurrences of the same note ; or the least recently used channel.
* random (*rnd*). Each new note is routed to a random channel.
* stacking (*stk*). Each note is sent to all channels at the same time. Perfect for thickening a lead by sending it to several synths, or to several parts of the same multitimbral device.
* velocity (*vel*). The louder (higher velocity) the note, the higher the MIDI channel it is sent to.
out 4
First output channel.
num 3
Number of output channels. For example, if out = 4 and num = 3, the notes will be dispatched to channels 4, 5 and 6.
