Elektron Analog 4/Keys .. Testroutine?
V
V
weiß nicht, ob du das meintest, Mr Admiral, das hier hatte pulsn mal geschrieben:
pulsn schrieb:
Du könntest vorher nochmal den "TEST MODE" laufen lassen um das Gerät zu checken.
To access this menu, hold down the [FUNCTION] key while powering up the Analog Four. From here you can
perform a variety of tasks. To choose the different alternatives, press the corresponding [TRIG] key.
TEST MODE
To enter this mode, press the first [TRIG] key. If you have any trouble with your Analog Four and suspect it may be due to a hardware problem, perform this self test. No errors should be reported as shown below. If that is not the case, contact Elektron support or the retailer you bought the Analog Four from.
Sequencer-News
