Fred’s Lab Töörö
dilettant
Proud 2 be a gearslut
Hmmmm.....
Fred’s Lab unpacks the elephant with the Töörö, a new 12bit crunchy-sounding hybrid desktop Synthesizer that combines digital morphing oscillators with analog filtering.
Fred’s Lab aka Frédéric Meslin, former developer of Waldorf (NW1 …) today presented Töörö, a new desktop Synthesizer. Töörö is not an elephant sound generator but a hybrid synth with a quite different sound engine. It offers a 6-voice engine with 4-parts that offers a mixture of analog and digital technologies.“
https://www.kickstarter.com/projects/tooro/tooro-hybrid-polyphonic-supersynth
Technical aspects
All Fred's Lab instruments are produced and manually assembled locally in Germany.
Following specifications are preliminary and are subject to changes.
The Töörö is a polyphonic and multitimbral synthesizer module with 6 voices, 4 partsand a stereo signal path.
Sound Engine
Per voice
Oscillators
Two 12bit digital oscillators with:
- waveform morphing
- factory and user tables
- additional sine modulator (for linear through zero phase modulation)
- auto-sync feature - hardsync
Filter
A single FL A847 optocoupler based 12dB/Octave low-pass filter with auto-oscillationand saturation features.
Shaper
A selection of shapers and filters algorithms from Fred's Lab.
Noise
A regular white noise source.
Ring modulator
An audio rate multiplication of osc1 output by osc2 output.
Envelopes
Two ADSR envelopes with hold stage and multiple triggering options.
LFOs
Two complex LFOs with various waveforms and their own AD envelope.
DCA
A digitally controlled attenuator with volume and panning control.Per part
MIDI channel selection, overall part volume and panning.
A syncable arpeggiator with multiple modes and patterns is included.Global
Multi-FX
A 12bit digital multi-FX module with:
- stereo ping-pong delay (with length, feedback and mix)
- chorus / flanger effect (with mode, speed and depth)
Instrument
Memory
The Töörö can store:
- 100 sound presets
- 10 multis
Connectivity
- 2 line-level unbalanced 6.35mm jacks (mix left & right)
- 2 instrument-level 3.5mm jacks for separate voice outputs (for voice 1-4 only)
- 1 DIN5 MIDI-IN
- 1 DIN5 MIDI-OUT (OUT + THRU configurable)
- 1 USB 1.1 B compatible port (for power and MIDI over USB)
- 1 power switch
UI
- 4 high-quality metal encoders
- 14 tactile switches
- dual digit 7-segment hexadecimal display
- 12 leds
Mechanics
- aluminum industrial enclosure
- quality rubber feet
- 170 x 120 x 45 mm
- 750 grams
Also der Name ist schon mal Hammer. :) Ist das quasi eine Microwave im praktischen Sirin Format? Grundsätzlich daher spannend.
Interessant.. das Filter klingt gut, die grafische Gestaltung des Gerätes finde ich etwas... gewöhnungsbedürftig
Keine Einzelouts... bin ich denn der Einzige der gerne all seinen scheiß zentral am Mixer pegeln will und Send-Effekte hat?
JA GEIL! Hoffe mal die meinen Parts und nicht Voice?
Der Buzzy hat Nen feinen Hall integriert.
Allerdings tör(önt) mich die minimale Beknopfung hier wieder genauso ab.
von der produktseite:
The Töörö is a polyphonic and multitimbral synthesizer module with 6 voices, 4 parts and a stereo signal path.
Sound Engine
Per voice:
Oscillators
- waveform morphing
Filter
A single FL A847 optocoupler based 12dB/Octave low-pass filter with auto-oscillation and saturation features.
Shaper
Noise
Ring modulator
Envelopes
LFOs
DCA
Per part:
Global:
Multi-FX
Instrument
Memory
- 100 sound presets
- 10 multis
Connectivity
- 1 DIN5 MIDI-IN
- 1 power switch
UI
- 12 leds
Mechanics
- 170 x 120 x 45 mm
- 750 grams
ueberblicks-video mit prototyp (en francais - aber auch mit rudimentaeren franzoesischkenntnissen verstehe ich erstaunlich viel - das standard-synth-vokabular ist halt sehr aehnlich. man muss eigentlich nur wissen, dass "numérique" digital heisst :) ):
Teureueueu - très chique ;-)
Sieht ein wenig wie ein Shruthi aus...
Nun auf Kickstarter:
Video:
https://www.youtube.com/watch?v=QBDwZhsobiM
Die Herkunft des Namens?
https://www.youtube.com/watch?v=YB8hqFLRb5k
Ach ja, Claudius Brüse (ebenfalls ex. Waldorf) hat für Benjamin Blümchen mal Musik geschriben:
Holla, Johannes Schmölling auch.
@qwave:
Transformed beyond recognition - mehr fällt mir da nun auch nicht mehr ein...
Der Sound hat seinen Charakter und der Formfaktor bzw. die Features sind sehr interessant. Aber irgendwie klingt der trotzdem kacke... oder Demos sind einfach schlecht.
Irgendwie klingen die Demos etwas besser auf der Webseite: fredslab
Keine Ahnung woran das liegt (Komprimierung bei Souncloud ?)...
Finde "Complex pad" klingt schon ziemlich interessant...
..noch 9 Tage bis zum Kampagnenende, bisher steht es leider erst bei 61% wer also noch interessiert ist, es gibt neue Soundbeispiele auf der Kickstarterseite...
@Moogulator vielleicht könnte man auf gearnews nochmal support geben und an den Fortschritt der kampagne erinnern..
