MAQ16 mit Launchpad steuern
Last week I bought a Novation Launchpad to experiment further with Ableton Live. But I also wanted to see if the Launchpad can be used to control the Doepfer MAQ16/3. I discovered the AutoMap software provided with the Launchpad is a bit of a disappointment. As far as I know now you cannot send a Program Change message with the buttons. And the MAQ16/3 needs them. I also did not get the MIDI learn function to work but maybe I missed something and the documentation is not much help.
Anyway, I used the MIDI-OX software to translate the MIDI notes, which the Launchpad sends, to Program Change commands with the Data Mapping option. I am only using the top 4 rows. The buttons on the first row turns step 1 to 8 on. The second row turns step 1 to 8 off. The third row sets the first step of the 8 step sequence and the forth row sets the last step of the 8 step sequence. Also the top 4 arrow buttons on the right are used. The first one turns all steps on. The second one turns all steps off. The third one chooses the first row on the MAQ16/3 sequencer and the forth one chooses the second row on the MAQ16/3 sequencer. You first have to choose the row on the sequencer where after the buttons apply for that row. It would be easier if the first four button rows could be used for row 1 on the sequencer and the second four button rows for row 2 but I could not map one note command to two program change commands.
The first row on the MAQ16/3 sequencer drives the Synthesizers.com Modular and the second row the self-built Modular.
This video is a demonstration and not intended to provide you music of a certain quality ;-)
Das Ding
1) sieht schlimm aus, kannste nicht mal live bringen, so ein hässliches Design..
2) hat es kein anständiges Feedback. Aber im Studio für bestimmte Sachen ists ok und umständlich zu bedienen. Finde den Mac Editor immer noch nicht auf deren Site.
Mit dem Launchpad kann man auch Lauflicht machen zB mit Numerology und zwar so, dass die Farben auch genutzt werden.
Das kann das Behringerdingens nicht. Verliebt hab ich mich daher eher nicht. Das LP ist mir lieber und das B hat keine Taster in ausreichender Menge.
Wenn´s prinzipiell um Bedienbarkeit und nicht Machbarkeit geht, dann ist so eine Launchpad/MAQ-Lösung auch nur von hinten durchs Knie geschossen. Dann sollte man gleich in einen größeren Stepper investieren, der Entsprechendes am Gerät bietet.
Moogulator schrieb:
Das Ding
Also ganz ehrlich,ich finde der BCR ist einer der besten Livecontroller fürs Geld.
Das ist genau das was man braucht fürs Livespielen: Endlosregler mit Lichtkranz,wodurch das ständige abholen irgendwelcher Regler etc pp obsolet wird,
besser gehts nicht.
Und achja :P
Ja, es ist nicht schlecht, aber es sieht (wie man sieht) doof aus ;-)
Aber deshalb hat der Herr Exile ja auch einen Koffer. So siehts ok aus. Das man damit arbeiten kann ist außer 2fel.
Übrigens ist sicher wahr, dass LP und MAQ ein wenig oversized ist, würde selbst auch eher voll mit dem Rechner dann arbeiten.
Die Drehreglerdinger sind schon ok für Eingabe, wenn alles hin und rückgemeldet wird. Dazu brauchst du aber auch ein Patch, was schlau genug ist. Also per se Reaktor oder Max oder beides mindestens notwendig, sonst kein Spaß, oder man hat was, wo das Teil schon als Controller eingeplant ist.
