Nintendo NES circuit bend ???
ID_nrebs schrieb:
hallo zusammen,
kennt jemand ein projekt dazu???
http://cgi.ebay.com/Nintendo-NES-midiNE ... dZViewItem
es gibt auch ein soundsample bei dem angebot...
gruß, Bernd
:waaas:
/EDIT
Kamma kaufen hier:
http://www.wayfar.net/0xf00000_overview.php
69 $
Midines is a hardware / cartridge interface (game) that enables MIDI control of the 8bit NES sound chip. Midines allows the 8bit NES to join the ranks along side other retro gear in the professional MIDI recording studio. NesFX is a retro graphic visualization that is seeded by the incoming MIDI sound data, and is included with Midines.
Version 1.1.0 features 256 samples (accessible in two keyboard banks) featuring TR707,TR808,TR909,LINN,Amen+other breaks, stabs, and essential chip battlz.
For details on modifications and improvements from earlier versions please consult the changelog.
Midines 1.1.0
_______________________________________________________________________________________________
______________ TECHNICAL_______________________________________________________________________
Midines is crafted via modifying 8bit Nintendo game cartridges, cleaning / stripping the original cases, removing the original game CIC chip and installing the Midines 1.1 circuitboard.
Midines is a independently authored, non-Nintendo licensed hardware interface that enables MIDI access to the 8bit NES sound chip, allowing integration of the NES into your MIDI recording studio.
Midines provides full access to the 2x Pulse, Tri, Noise and DMC (sample) channels. Including access to sweep, duty, volume and length sound registers. The sound routine is not dependent on the vertical screen refresh rate (vblank) allowing high speed MIDI CC modulation of all parameters.
To learn about the effects avaliable, and detailed MIDI information please visit the manual.
Samples?
Nix mit Soundchip anscheinend...
Habb auch grad noch ne Info von nem Kollegen dazu bekommen der sich auf dem Gebiet richtig auskennt:
Besten Dank für den hinweis,circuit bent heisst da wohl das mehrere
Audioausgänge für die vorhandenen 4 Kanäle eingebaut wurden.
Da es immer noch keine Pal Version von Midines gibt muss man bei der
Europa Konsole zuerst den Nintendo Lookout Chip deaktivieren.
Ist jedoch keine Sache da man nur ein Füsschen des Chips durchtrennen
muss.Anleitung im Netz(NES Lookout Chip)
Der eingebaute Soundchip ähnelt dem des Gameboys.
