tempest bei thomann
Dieses Thema im Forum "mit Sequencer" wurde erstellt von orgo, 13. Januar 2011.
  1. orgo
    orgo Tach
    Neue Drummashine von Dave Smith Tempest
  2. TEMPEST von Roger Linn & Dave Smith
    []http://www.youtube.com/watch?v=WRD8f5BJSsw&feature=player_embedded[/media]
  3. stuartm
    stuartm musicus otiosus
  4. orgo
    orgo Tach
    Re: Neue Drummashine von Dave Smith: Tempest
    * Each of the 6 analog voices has 2 analog oscillators plus 2 digital oscillators (with a large bank of included samples), Dave's classic analog low-pass filter with audio-rate modulation, an additional high-pass filter, analog VCA with feedback, 5 envelopes, 2 LFOs, an extraordinary variety of analog modulation routings, and stunning sonic quality, warmth and punch. Although optimized for drum sounds, it excels at tuned sounds as well, and even doubles as a 6-voice analog synth. In addition to the 6 direct voice outputs, there are stereo mix outputs and phones outputs, plus 2 inputs for foot switches or expression pedals, MIDI in/out and USB.
    * The performance-oriented operating system, 90 panel controls, and bright 256 x 64 OLED display work together to provide a tightly integrated, non-stop workflow: record a drumbeat in real-time, switch to another drumbeat and use the lit pads to record it using step programming, switch to another drumbeat and record tuned keyboard parts, use the 2 touch controllers to to record real-time note or beat-wide parameter animations, use the generous sound controls to edit any of the drum sounds, tweak the analog effects or drum mix, arrange beats in real time and record the live arrangement into a song, enter/exit Song mode and much more, all without ever stopping play.
    * 16 pressure- and velocity-sensitive lit pads are arranged in a 2x8 configuration, providing intuitive access to all your fingers and providing the ideal compromise between the popular 4x4 pad arrangement (popular for real time programming ) and 1x16 arrangement (popular for step programming) because Tempest does both. The pads can be used to play 32 drum sounds (2 banks), mute/unmute the 32 sounds on playback, play and arrange 16 beats in real time, play one sound at 16 tunings (in a variety of scales) or 16 velocities, or as 16 time steps for step programming. The ROLL button permits creating drum rolls or repeated groove patterns by varying pad pressure as the beat records, and doubles as a momemtary "stutter" effect when the pads are assigned to play beats. Use the Sustain button on tuned parts like a keyboard's Sustain pedal, or to choke drum sounds or drumbeats when the pad is released.
    * Two pressure- and position-sensitive Note FX slide controllers permit real-time recording of note or beat-wide sound parameter changes into the drumbeat as you play. For example, record simultaneous filter frequency, tuning, envelope decay and pan changes for each note, or control similar parameters affecting the entire beat.
    * A variety of unique effects are provided while maintaining a pure analog signal path: 1) Stereo analog compressor and distortion circuits affect the stereo output mix, 2) beat-synced delay is achieved by generating additional delayed note events within the sequencer, and 3) a beat-synced "stutter" effect is created entirely within the sequencer by looping short portions of the drumbeat on demand.
    * The degree of swing timing can be adjusted in real time during playback. Roger used his entire bag of tricks to make the swing sound very human and natural.
    * Compact and portable: 15.4" L x 9" W x 2.5" H
  5. weinglas
    weinglas Tube-Noise-Maker
    Re: TEMPEST von Roger Linn & Dave Smith
    Sehr cool! Großer Habenwill-Faktor!
  6. stuartm
    "Dave Smith called for a reboot, and the result will be not one but two drum machines. One will be released by Dave Smith Instruments, and another by Roger Linn Design."
    Da kommt also noch mehr !
  7. Anonymous
    Anonymous Guest
    das teil sieht interessant aus.... aber 2000 dollar ist ein haufen holz!
  8. Re: TEMPEST von Roger Linn & Dave Smith
    Das Design finde ich persönlich irgendwie eigenartig, aber das Konzept ist schon klasse!
  9. Xpander-Kumpel
    Xpander-Kumpel bin angekommen
    Huch!
    Sehr geil, da spielt nur mein Konto grad nicht mit!
    ...Sie betonen ja immer wieder da man "alles" bei laufender Maschine machen kann, heist das genau wie beider SPSUW samplen und resamplen bei laufendem Beat?
  10. snowcrash
    snowcrash Tach
    wow, grosse ueberraschung... bin schon gespannt und gespart wird jetzt auch gleich mal.
  11. kl~ak
    kl~ak Tach
    leider zu teuer :sad:
  12. max mayer
    max mayer Tach
    Wau, absoluter Kracher! Und wenn sie tatsächlich das kann, was versprochen wird, ist das nicht zu teuer. Qualität hat halt ihren Preis.
  13. orgo
    orgo Tach
    preis ist noch nicht offizell....oder?
  14. Bruce
    Bruce Tach
    Coole Sache - wenn die so geil ist, wie ich mir das jetzt vorstelle ...
    Allerdings: Die Vorführung im Video überzeugt mich noch nicht so - da müssen die zwei alten Knacker erstmal wen anders ranlassen ;-).
    mfG Bruce
  15. citric acid
    citric acid aktiviert
    mann in usa gibet wohl keine krise mehr...2000bugs ...wow wie zu begin der machinedrum und was kostet die heute ...mann die fixen einen wieder ganz gut an :-=) das video ist jedenfalls ganz gut
  16. gruengelb
    gruengelb Tach
    Das sind "Bucks".
  17. RetroSound
    RetroSound ●--~√V√V√V~--●
    2000 bugs kann auch möglich sein! :lol: ;-)
  18. Lauflicht
    Lauflicht x0x forever
    C-O-O-L
    Große Überraschung nach der Absage beider.
    Komplett analoge Tonerzeugung mit Effekten plus digitale Waveforms. :)
    Sieht schön aus und kann sogar Lauflicht als Zugabe. Reine Drummaschine, kein MIDI-Sequenzer, also kein MPC Ersatz.
    Bin mal gespannt wie sich die deutlich günstigere, neue Konkurrenz von Arturia schlagen wird.
  19. Moogulator
    Moogulator Admin
    Das Teil dürfte wohl am meistem mit dem Speckie kämpfen, da oben ist mehr Luft als unten wo die Sumoringer um geiz kämpfen. Ein bisschen Evolverzergrooveboxung schadet ja nicht.
  20. Anonymous
    Anonymous Guest
    Wer das Interview nicht gelesen hat...hier nochmal zur Info...der Tempest ist ein vollwertiger polyphoner 6 stimmiger analoger Synth! Sozusagen ein "Hextra'". Und dafür ist der Preis durchaus gerechtfertigt.
  21. Moogulator
    Moogulator Admin
    Dies aber plus Sampling. Das ist doch was. Den DSI'schen HPF könnte man bei der Gelegenheit noch etwas verbessern, so wie den 12dB Mode.
  22. Anonymous
    Anonymous Guest
    Ich bin mal gespannt was dann von Roger Linn kommt, schließlich war ja von zwei Drummaschinen die Rede...
  23. pD
    pD Tach
    Bin sehr überrascht, ....als ich jedoch den Preis von 2000$ sah verging mir alles. Das geht mal garnicht. Schade, werd das gute Stück aus meinen Gedankengängen streichen müssen. Einfach viel zu teuer.
  24. Summa
    Summa wibbly wobbly timey wimey
    In Anlehnung an den Venom Thread... ;-)
    [​IMG]
  25. phunk80
    phunk80 Tach
    Ein geiles Ding so rein auf dem Papier. Klar, der Preis ist nat. kein Schnäppchen, aber das waren gute analoge noch nie. Kann ja quasi mehr als ein Prophet :)
  26. pD
    pD Tach
    Amis, ...muss man da noch was erwähnen?
    (zur Zeit laufen dort doch selbsternannte Superhelden herum und wollen Amerika retten) ;-)
    Bei Tempest muss ich allerdings an Tempest 2000 (Atari Jaguar) denken. Super Spiel mit geilem Soundtrack!!
    http://www.youtube.com/watch?v=ijjQpOuognI
    http://www.youtube.com/watch?v=EfyCBtGy ... re=related
    http://www.youtube.com/watch?v=8tUN5f9Y ... re=related
  27. Summa
    Naja, das Original waer' in deinem Fall der Tempest Automat...
  28. Anonymous
    Anonymous Guest
    Der Schriftzug erinnert mich an den Spectralis ;-)
    Apropos Specki. Neben Tempest, Spark und Beat Thang müsste er mal wieder Flagge zeigen. :twisted:
  29. Anonymous
    Anonymous Guest
    Du könntest auch dir selbst eine "Tempest" "lite" Drummachine basteln...mit 4 Stimmen...Man nehmen einen DSI Tetra und einen "Europa" Sequencer.
    Wahlweise noch kombinieren mit einem Doepfer Dark Time. Dann noch eine MPC500 dazu...oh...das sind dann auch schon fast 2k... :cry:
  30. Anonymous
    Anonymous Guest
    Keine Konkurrenz, da anderes Obst. Spark ist wie Maschine, nur ein Midi Controller. Tempest ist ein 6 stimmiger polyphoner analoger Synthesizer.
Diese Seite empfehlen
