2.2 Update mit einigen Fixes:
Edit: Change log von Gearspace rüberkopiert:
New In V2.2
Peak:
In the rare event front panel controls become responsive after completing this update it will be necessary to restart your unit.
* Local state is now stored in the global settings. If Local is saved to ‘Off’ a temporary display will show on boot. Settings must be saved in order to be retained through a power cycle (go the Settings menu and press Save)
* All local modes can be set by sending the following values on CC122. A temporary display will be shown when the local state is changed via MIDI:
0 = off
127 = on
* Bug fixes:
* Sudden changes in stereo position - fixed an issue where certain combinations of Spread, SpreadMode and PanPosn settings could result in sudden changes to the distribution of voices in the stereo field.
* Poly mode voice management - Previously when using 8 voice unison with long envelope times in Poly mode all 8 voices may not be triggered when playing in legato style. All 8 voices are now triggered whenever a new key is pressed. This fix does not apply to Poly2 mode.
* Hanging notes - Playing greater than 8 notes after the unit has booted can no longer result in a hanging note.
* Reverb Size not recalled correctly when loading a patch - Reverb Size front panel control and Reverb Size menu parameter (FX 8/10) now work bi-directionally and settings are recalled correctly.
* All sounds off/all notes off - Peak now responds to both CC120 & CC123 according to the MIDI org specs. CC120 (all sounds off) cancels all notes and shuts down envelopes & FX – settings are restored with the next note. CC123 (all notes off) cancels any active notes.
* LFO FadeSync - LFO FadeSync now works in both Mono & Poly voice modes. This feature determines whether fade is applied to an LFO, when set to ‘On’ the fade value will be applied to with each keypress in legato playing style. When set to ‘Off’ the fade will be applied with the first key press in legato playing style.
* Mixed displays when moving multiple controls - Revisions have been made to the screen display prioritisation to prevent mixed/garbled displays appearing on screen.
* Screen doesn’t wake from a USD MIDI event - Fixed an issue when the screen would not wake when receiving a USB MIDI event.
* Ignores LSB in CC pairs - LSB is no longer ignored, this reduces stepping when controlling Peak via external MIDI
* Notes held in Arp cache when Arp is off - In previous builds if Arp was disabled while notes were being held, the notes would be cached causing the same arpeggiated sequence to play when Arp is enabled again. The Arp note cache is now cleared when Arp is disabled.
