InSEQt Handbuch
Ein-/Ausgänge mit Pre-Patchings
Oberer Teil:
| Modul | Buchse | Art | Pre-Patch | Beschreibung |
| Clock | CLK FM | IN | RAMP | Clock Frequency |
| Clock | CLK PWM | IN | Länge des Gates | |
| Clock | EXT CLK | IN | Externe Clock | |
| Clock | RESET | IN | Zurück auf Gate 1 | |
| Clock | PULSE | OUT | Gate als Rechteck | |
| Clock | SQUARE | OUT | Gate als 50% Rechteck | |
| Clock | HOLD | IN | Anhalten (Clock läuft weiter!) | |
| Gate | GATE 1 - 16 | OUT | Einzelausgang pro Step | |
| PW LFO | PULSE | OUT | Rechteck | |
| PW LFO | RAMP | OUT | CLK FM | Sägezahn/Triangle |
| PW LFO | SYNC IN | IN | Zum Synchronisieren | |
| CV LFO | SQUARE | OUT | 50% Rechteck | |
| CV LFO | TRIANGLE | OUT | Dreieck | |
| CV LFO | SPEED CV | IN | ROW B | Geschwindigkeit |
| Level | MIX IN | IN | ROW B | |
| Level | LEVEL OUT + | OUT | ||
| Level | LEVEL OUT - | OUT | ||
| Multi | 1 (über dem M) | IN | Clock | |
| Multi | 2-3 | OUT | ||
| Slew | SLEW IN | IN | ROW A | |
| Slew | RESET | IN | ||
| Slew | SLEW OUT | OUT | ||
| S&H | S+H IN | IN | PW LFO | |
| S&H | TRIGGER | IN | Clock | |
| S&H | S+H OUT | OUT | ||
| Trigger Delay | DELAY IN | IN | Clock | |
| Trigger Delay | DELAY OUT | OUT | ||
| Length | SEQ TR OUT | OUT | Rechteck LFO | |
| Length | SEQ LENGTH | IN | 16 | Trigger/Gate input für Sequenz-Ende |
| Sequencer Out | ROW A | OUT | ||
| Sequencer Out | ROW B | OUT |
Unterer Teil:
| Modul | Buchse | Art | Pre-Patched | Beschreibung |
| Clock & Trigger | START | IN | ||
| Clock & Trigger | START/STOP | IN | ||
| Clock & Trigger | STEP | IN | Next Step 1 | |
| Clock & Trigger | RESET | IN | Zurück auf Step 1 | |
| Clock & Trigger | CL OUT | OUT | Gate (1,2 oder 3) | |
| Clock & Trigger | QT CLK OUT | OUT | Quantizer Gate | |
| Clock & Trigger | OUT BUS 1 | OUT | Gate 1 | |
| Clock & Trigger | OUT BUS 2 | OUT | Gate 2 | |
| Clock & Trigger | OUT BUS 3 | OUT | Gate 3 | |
| Divider | IN | IN | Gate (CL OUT) | |
| Divider | 1.n | OUT | Jeder 2/4/8/16/32/64/128. | |
| Multi 1 | 1 (Links vom M) | IN | Clock | |
| Multi 1 | 2-3 | OUT | ||
| Multi 2 | 1 - 4 | |||
| Quantizer | 1 QUA IN | IN | 1 CHA OUT | 1 Bei 1-16 und 1 Bei 2x8 |
| Quantizer | 2 QUA IN | IN | 2 CHA OUT | (Bei 2x8) 2 Bei 2x8 |
| Quantizer | CV 1 QUA IN | IN | Add to QUA 1 | |
| Quantizer | 1 QUA OUT | OUT | ||
| Quantizer | 2 QUA OUT | OUT | ||
| CL P1 | FM CLK | IN | OUT BUS 1 | Geschwindigkeit |
| CL P1 | CLK PWM | IN | Gate Länge | |
| CL P1 | OUT POS 1 | OUT | Gate bei STEP 1 | |
| Channel Outs | 1 CHA OUT | OUT | CV 1-16 bzw. 1-8 Bei 2x8 | |
| Channel Outs | 2 CHA OUT | OUT | CV 1-16 bzw. 9-16 Bei 2x8 | |
| Inverter 1 | 1 INV IN | IN | ||
| Inverter 1 | 1 INV OUT | OUT | ||
| Inverter 2 | 2 INV IN | IN | ||
| Inverter 2 | 2 INV OUT | OUT | ||
| AND | 1 AND IN | IN | ||
| AND | 2 AND IN | IN | ||
| AND | AND OUT | OUT | ||
| OR | 1 OR IN | IN | ||
| OR | 2 OR IN | IN | ||
| OR | OR OUT | OUT | ||
| XOR | 1 XOR IN | IN | ||
| XOR | 2 XOR IN | IN | ||
| XOR | XOR OUT | OUT |
Oberer Teil
Anzahl Schritte setzen
Entweder den Gate-Ausgang mit Reset-In verbinden oder mit dem Seq Length Eingang. Beim Reset-Eingang muss man allerdings das Folge-Gate benutzen (2 Schritte = Gate 3 mit Reset-In verbinden, statt Gate 2).
Spannungsstärke
2. Sequencer Reihe oben geht bis 10 V.
