Neues MOTU 828 Audiointerface
Introducing the 828​
MOTU is now shipping a complete redesign of its popular 828 rack-mounted (1U) audio interface for macOS, Windows and iOS. With superb analog performance driven by renowned ESS Sabre32 Ultra™ DAC technology, the 28x32 828 connects to a Mac, PC or iPad via 5 Gbps USB3 with low-latency, high-performance drivers to deliver 60 total channels of I/O and 24-channel mixing with on-board effects processing, including reverb, 4-band EQ and compression.
Front Panel​
On the front panel, a large, bright 3.9-inch full-color LCD display provides 480 x 128 pixel high-resolution metering for all analog and digital I/O. Control room features include talkback with front panel "talk" button and "A/B" monitor select, mute, and sum-to-mono buttons for the main outs.
Two front-panel “combo” style XLR/TRS mic/line/hi-Z guitar inputs provide advanced mic channels with cutting-edge components that deliver ultra-transparent sound with -114 dB THD+N, 118 dB dynamic range and -129 dBu EIN. Each mic channel provides individual controls for preamp gain (+74 dB), -20 dB pad, 48V phantom power, and phase invert. All settings can be controlled remotely from a computer or iOS device. Each mic channel includes a dedicated send/return insert for outboard gear processing. When nothing is connected to the front-panel mic inputs, the two rear-panel returns function as additional balanced line inputs with identical signal path characteristics as the other eight line inputs.
Additional I/O​
Additional audio I/O includes 8 TRS analog (line-level) in/out, separate main outs on XLR jacks, two banks of 8-channel ADAT optical I/O, stereo RCA S/PDIF digital I/O, and two front-panel headphone outputs. The analog outputs deliver a measured dynamic range of 125 dB with -113 dB THD+N. All inputs and outputs can be calibrated with boost or trim in precise 1 dB increments. You can create completely customized mixes for each headphone output that include live 828 inputs, host computer channels and built-in reverb. All line outputs are DC-coupled, so they may be used to manipulate and sequence voltage-controlled modular synthesizers from a host DAW.
Advanced Extras​
Also included are MIDI In/Out jacks (with optional MIDI Thru), BNC word clock I/O (with optional Thru), and a foot switch input for hands-free punch-in during recording (or to trigger other host software keystrokes).
If the 828 is connected to a computer on a Wi-Fi network, you can control everything wirelessly from the CueMix 5 app running on mobile devices or other computers on the same network — even multiple devices at the same time. You can manage access to the 828 (and other on-line MOTU devices) with network discovery features and password protection.
The 828 driver provides two loopback USB channels for live streaming and podcasting. You can easily route computer output back to the computer, where they can mix it with live 828 inputs (microphones, guitars, etc.) in their host software for live streaming or podcasting.
The 828 also supports guitar re-amping. You can connect a guitar to the front-panel input, use CueMix's near-zero latency to loop to any output (with a re-amp adapter, if needed), and record both the dry signal and a mic’d up amp simultaneously. Then the dry signal can be re-amped later with different amps and cabs — or amp modeling plug-ins — to experiment with different tones.
Included Software​
The 828 includes the following software for musicians to start making music immediately: CueMix 5 app to control mixing and settings from your Mac, PC or iOS device, MOTU Performer Lite and Ableton Live Lite workstation software, 100+ instruments (in Performer Lite), and over 6 GB of included free loops, samples and one-shots from industry leading libraries.
828 Feature Highlights​
  • Next-gen 28 x 32 USB3 audio interface with DSP, mixing and effects
  • New 3.9-inch 24-bit RGB LCD with precision metering for all I/O
  • Superb analog audio performance driven by ESS Sabre32 Ultra™ DAC Technology
  • Ultra-low latency and proven, high-performance MOTU drivers (~2 ms RTL with a 32 sample buffer @ 96 kHz)
  • Universal connectivity with 5 Gbps USB3 (compatible with USB2)
  • 60 simultaneous audio channels (28 inputs and 32 outputs)
  • 2x high-performance mic/line/hi-Z guitar inputs on combo XLR/TRS
  • Individual preamp gain, 48V phantom power, -20 dB pad, phase invert, remote control, and dedicated inserts for each mic input
  • Measured -114 dB THD+N, 118 dB dynamic range and -129 dBu EIN on mic inputs
  • Flexible insert returns can operate as extra line inputs (when mic inputs are unused)
  • DSP-driven 24-input digital mixer with 8 stereo busses and DSP effects (reverb, 4-band EQ, gate & compressor)
  • Wi-Fi control from CueMix 5 app on multiple mobile devices (via a USB-connected computer on the same network)
  • Network management features (discovery for multiple devices on the network and password protection for each device)
  • Precision boost for all analog inputs and trim for all analog outputs in 1 dB increments
  • Control room features include Talkback and A/B monitor select via CueMix 5 software or front panel controls
  • Two flexible headphone outputs with independent volume control and fully customizable independent mixes
  • 2x balanced XLR main outs
  • 8x balanced, DC-coupled 1/4-inch TRS analog outputs with measured 125 dB dynamic range
  • Hardware (direct) monitor mixing for each analog output pair and both headphones (8 mix busses)
  • 8x balanced 1/4-inch TRS analog inputs with measured 120 dB dynamic range
  • 2x banks of optical digital I/O (16 ADAT channels at 1x sample rates) with optional stereo TOSLink on Bank A
  • 1x RCA S/PDIF stereo digital I/O
  • MIDI in/out/thru
  • Word clock in/out/thru
  • Foot switch input for hands-free punch-in recording or other programmable host computer keystrokes
  • DC-coupled TRS outputs can be used to control modular synthesizers from a host DAW using control voltage (CV)
  • Support for 44.1 to 192 kHz sample rates
  • 1-rack U form factor built with rugged steel construction
  • USB audio class compliant for plug-and-play operation on macOS and iOS (no driver required)
  • Driver loopback for mixing host software output with live 828 inputs for streaming and podcasting
  • Guitar re-amping with near-zero loop-thru to record the dry guitar signal and mic'd amp simultaneously
  • CueMix 5 app to control mixing and settings from your Mac, PC or iOS device
  • MOTU Performer Lite and Ableton Live Lite workstation software included
  • 100+ instruments (in Performer Lite)
  • Over 6 GB of included free loops, samples and one-shots from industry leading libraries
  • Two-year warranty
https://motu.com/en-us/products/828/
Bilder/Text Quelle: motu.com
1200 € beim großen T.
Das mit AVB vermisse ich auch sehr, koennte gut noch ein paar analoge I/Os via AVB gebrauchen.... habe seit einiger Zeit das Motu 112D im Einsatz und bin super zufrieden, was man damit via AVB und den digitalen Schnittstellen Adat, AES und Madi alles connecten kann. Adat waere noch eine Moeglichkeit zum neuen 828, aber AVB direkt mit nur einem Netzwerkkabel waere mir doch lieber. ;(
Wie seit 30 Jahren per ADAT?
Da ist aber wie gesagt bei max 28 Kanälen (inklusive S/PDIF) Ende. Mehr geht nicht.
Am "alten" 828Es hab ich hier via AVB noch ein 24 AI dran hängen. Das sind so schon 32 Kanäle und funktioniert einfach prima ohne Probleme. Da könnte ich jetzt sogar nochmal ADAT Interfaces dran hängen und würde in Summe max 70 Kanäle hin bekommen...
Das klingt echt gut, wie sind denn so die Wandler DA/AD des 828e oder des 24 AI? Bin ja treuer Fan von RME, aber das Motu AVB faende ich interessant als analoge I/O Ergaenzung per AVB (das 112D ist auch gerade wegen AVB echt genial, aber ja rein digital und hat somit keinen eigenenen Klang sondern leitet nur weiter).
Man bekommt sowieso kaum noch AVB-Interfaces. Abgekündigt sind sie ja nicht.
Das ist echt schade... AVB finde ich nach wie vor ein super Format zum Uebetragen von Audio und auch die bessere Wahl (weil offen und unter Apple standardmaessig supportet) im Vergleich zu Dante.
Anhang anzeigen 200726Anhang anzeigen 200727
Front Panel​
Additional I/O​
Advanced Extras​
Included Software​
  • MIDI in/out/thru
  • Two-year warranty
geil main out wieder xlr und dedizierte send und return buchsen ohne dass man die eigentlichen eingänge vergeuden muss.
sieht super aus.
Meine ganz persönliche Vermutung ist, dass AVB nicht so der Renner, sprich nicht übermäßig von den Kunden gefordert wurde. Ich sage nicht, dass es schlecht oder unnötig ist, nur ist halt der Interessentenkreis aus kommerzieller Sicht wohl zu klein. Wie gesagt, das ist meine ganz persönliche Vermutung.
Geld verdient ein Unternehmen ja nicht durch Penner, also Ladenhüter.
Ansonsten finde ich das Ding schon einen Kracher. 60 simultane Audiokanäle für EUR 1.200,--. Denkt mal 15 Jahre zurück. :)
ich bin mit meinem alten 828ES immer noch sehr zufrieden, falls dieses mal aussteigen sollte, ist man hier aber auch sehr gut bedient finde ich.
das 828 und das neue 16rig von arturia sind zwei tolle optionen zu einem unglaublich guten preis für leistung/ausstattung/klang.
beim 16rig gibt es mehr eingänge, beim 828 dafür sehr wenig latenz dank USB3.
der einzige punkt der für mich noch relevant wäre ist: kann diese cuemix software auch so individuell angepasst werden wie die bisherige browser matrix?
Wem max 28 Eingangskanäle reichen, ist da sicher mit gut bedient. Aber für so GAS verseuchte Synthnerds wie mich, sind 28 Eingangskanäle einfach mal zu wenig.
Die Cuemix Software kommt bei anderen MOTU Interfaces ja schon länger zum Einsatz (Ultralite z.B.). Die ist imo deutlich intuitiver zu bedienen, als die Browser Matrix (ich bekomme da echt immer nen Kopfkrampf und bin normalerweise nicht komplett blöd (für ein abgeschlossenes Ingenieursstudium hat es mal gereicht)). Ob man in Cuemix tatsächlich so flexibel jeden Eingang und Ausgang routen kann, weiß ich ehrlich gesagt nicht genau. Ich glaube aber ja, jedoch auf andere Art und weise (mehr wie man es aus einer DAW heraus machen würde).
Genau das dachte ich auch. Gerade AVB war der Vorteil dieses Interface. Wie werden die jetzt kaskadiert?
das geht ja hoffentlich noch softwareseitig, so wie eh und je.
ich denke aber, dass ein neues usb interface auch viel weniger kosten wird als das AVB als es rauskam.
naja, die ein- und ausgänge aufzuakkumulieren ist ja sicher ein netter trick fürs webeprospekt, ergibt aber keinen sinn.
vor allem wie benutze ich denn die adat eingänge ohne zusätzliches geld auszugeben?
so wie es da steht ist es für mich erst mal ein 8-kanal interface mit zusätzlichem main out, genau wie es das mkII vor 25 jahren auch schon war. und kosten tut es auch genauso viel.
Man hört sie nicht. Ich bezweifle, dass die Wandler bei allen halbwegs aktuellen Audiointerfaces ab der Mittelklasse irgendeinen Einfluss auf den Sound haben bzw. sich der Sound dadurch unterscheidet. Ganz egal ob MOTU, RME, Apogee, name it.
Man hört es zumindest nicht "unangenehm" heraus. Anders klingen die alle!
Hatte in den letzten Jahren RME FF uc, clarett 4+8pre und jetzt motu 828es/Ai24/Ferrofish Pulse, dazw. auch noch Behringer ada8200.
Es war mir schon sehr deutlich, dass rme sehr kühl/digital/clean klang, clarett sehr weich, british eben und motu zwischen den beiden. Ada8200 wie ein schwammiges rme. Rein subjektiv, habe nicht direkt verglichen, denke aber schon, dass die Unterschiede groß genug sind, dass die selbe Produktion unterschiedlich klingen könnte, aber alle (ausser ada8200) auf einem level, wo es irrelevant ist, da alle "gut" klingen.
Wieso, was kosten denn zwei ADAT-Interfaces ohne Preamps?
keine ahnung, das sollte man wohl mal bei motu erfragen welches die da so empfehlen.
du kannst natürlich für 50 euro ein altes digidesign aus den neunziger drapacken, die gibt es für 50 euro.
brauchst du dann aber 4 stück davon, zuzüglich kabelpeitsche und klinkenpatchbays, und das ist das system 5HE hoch und du hattest 3 tage arbeit mit dem besorgen.
von einem "60 kanal interface" würde ich jedenfalls erwarten, dass es auch 60 wandler hat, und nicht 10.
Einen hörbaren Einfluss der Preamps auf ein zu verstärkendes Signal - also primär für Mikrofonaufnahmen - kann ich mir gut vorstellen und glaube ich - bekomnme ich auch in Einklang mit Deiner Beschreibung. Bei unverstärkten Linesignalen - also z.B. Synths - glaube ich das beim besten Willen nicht.
Man kann die Preamps natürlich auch zur (dezenten) Klangbeeinflussung für Linesignale nutzen. Da hättest Du dann wieder recht. Aber üblich ist aj erstmal, das Linesignmale einfach ohne Verstärkung gewandelt werden und die Laustärke Anpassung dann in der DAW erfolgt. Bei den Dynamikbereichen und Rauschabständen die die AD Wandler heute bieten, ist das ja auch überhaupt kein Problem.
Das Clarett hat eine zuschaltbare Air Funktion, die aber nicht wirklich Mehrwert bedeutet. Ich meine das sonst so wie ichs schrieb. Line Signale, kein MicPreamp.
Aber ich höre auch nen krassen Unterschied
zwischen digitaler Summierung und dem Mixdream XP, wo die meisten aufhören, ist es für mich der Unterschied zwischen solala und klingt richtig geil - und das auch noch im AB Vergleich
Das Wichtigste ist, dass die Round-Trip-Latenz wohl mit dem alten 828ES (über Thunderbolt angeschlossen) bei unter 2ms mithalten soll, wenn das Interface mit den Treibern für Mac OS oder Windows verwendet wird - also nicht class-compliant.
Mein 828ES ist bei mir fast voll augereizt mit allen analogen Eingängen und Ausgängen plus weniger weiterer Ausgänge über ADAT und aller verfügbaren Eingänge über ADAT und SPDIF. Da hängt an Ein- und Ausgang 1 ein Arturia AudioFuse 8Pre dran, dann über den zweiten ADAT-Anschluss mein Focusrite ISA One und über SPDIF der SPL Channel One mkII. ACB brauche ich nicht, aber es ist Spitz auf Knopf.
Kein AVB mehr und damit in Summe maximal 28 Eingänge. Imo eine klarer Rückschritt im Vergleich zum 828Es.
Moment, das hier ist KEIN Nachfolger des 828es, sondern der Nachfolger des 828MKIII Hybrid, welches ja noch USB und Firewire hatte, also längst überfällig war und somit auf den Stand wie das Ultralite MK5 angehoben wurde. Das 828es ist aber auch kein vollwertiges AVB-Interface (hat weniger Streams), sondern ein Zwischenmodell.
Wäre es ein AVB oder ähnlich dem ES, hätte es auch das Webinterface, stattdessen gibts wieder die doofe Cuemix-App, die es aber in der Version 5 auch endlich für iOS gibt (wohl schon seit dem Ultralite MK5).
Immerhin hat es die guten ESS Sabre32 Wandler bekommen, wie alle aktuellen MOTU Audio Interfaces.
Mag sein. Fakt ist aber, dass ich mit dem 828Es (bei entsprechenden Erweiterungen) mehr als doppelt so viele Eingangskanäle in den Rechner bekomme wie mit dem 828 2024, weil ich das eben nicht so weit erweitern kann. Wer mit den max möglichen Eingängen des 828 2024 auskommt, hat damit ganz sicher ein tolles Audiointerface.
Cuemix finde ich übrigens gar nicht doof, sondern im Grunde intuitiver zu bedienen. Schrieb ich oben aber glaub ich schon.
Viel zu wenig Eingänge für diesen Preis -> AudioFuse 16rig
Auf dem Papier ist AudioFuse 16 Rig interessant. Ich schicke aber nun gerade das zweite Gerät zurück, aus dem dümmsten Grund ever.
Wenn man die "Rack-Ohren" links und recht montieren möchte, muss man zuerst jeweils 4 Schrauben entfernen. Die Schrauben haben 2mm Hex-Durchmesser. Dazu kommt ein mitgelieferte Minischlüssel. Es ist fast unmöglich alle Schrauben herauszuschrauben (oder wieder hereinzuschrauben) ohne sie zu zerstören. Beides mal klemmte bei mir eine Schraube, die zu fest vorgeschraubt worden ist. Mit dem Schlüssel franst das Hex-Gewinde aus, auch wenn man super vorsichtig ist. Absoluter Witz und Konstruktionsfehler.
Ich kaufe mir nun ein Motu 828.
autsch!
hab das neue motu letzte woche im musikgeschäft gesichtet – die verarbeitung ist erstklassig. wirst du bestimmt nicht bereuen.
Influencer. Hör auf hier die Leute für doof zu verkaufen.
Der Grund warum ich in diesem Thread gelandet bin ist, dass ich gestern Abend vor meinem zweiten Audiofuse 16 Rig mit klemmender Schraube sass, und dringend ein neues Audio Interface brauche und deshalb am recherchieren war. Da das Audiofuse hier erwähnt wurde, dachte ich, ich poste meine Erfahrung. Im Audiofuse 16 Rig wäre meine Info aber wahrscheinlich angebrachter weil anscheinend ein ganzer Batch das gleiche Problem aufweist.
Antwort Arturia Support Unit 1
Antwort Arturia Support Unit 2 (heute morgen)
Dein zweiter Post war ja nur eine Reaktion auf die selten blöde Anmache eies anderen Forumteilnehmers. Insofern passt das schon.
