khz
EAT THE RICH
Patchbox OS is a custom Linux distribution specially designed for Raspberry Pi based audio projects. It comes pre-configured for low latency audio performance and pre-installed audio software that will help you get started with your projects in no time!
* All of the software is configured to use the shared Jack audio backend, that means that multiple audio programs may use the audio card and play together. Run patchage to see and edit the audio signal flow.
# >> https://blokas.io/patchbox-os/ <<
# << https://blokas.io/docs/ >>
Features |
On-board, I2S and USB sound card support |
Jack audio backend for audio management |
Real-Time kernel for low latency audio performance |
Lightweight RPD Desktop Environment with low memory footprint |
Automatic MIDI connection manager (amidiauto) |
WiFi-MIDI support (touchosc2midi) |
WiFi Hotspot support |
SSH & VNC enabled by default |
Dedicated command-line utility for OS configuration (patchbox-config) |
Most popular audio programs pre-installed |
Pre-Installed Software | Version |
Audacity | 2.1.2 |
Chromium | 65.0.3325 |
Jack Backend | 1.9.12 |
Patchage | 1.0.0 |
Pianoteq Standard Trial | 6.4.1 |
Pisound Software | Latest |
Pure Data | 0.49.0 |
Sonic Pi | 3.1.0 |
Super Collider | 3.9.3 |
touchosc2midi | 0.10.0 |
