Tasty Chips GR-Mega Granular Sampler
og_penson
og_penson
Am vergangenen Wochenende auf der Superbooth erstmals präsentiert, hier jetzt auch Zahlen und Fakten von der Tasty Chips website:
FeatureSpecRemark
General
Multitimbrality4 layers
Polyphony per layer20 voices
Total number of grains5000all layers combined, about 4 times as much as the gr-1
EnginesSampler(including loop, start end)
Granular
Tape mode
Granular slice modeSampler slice mode possible
Spectral
Preset system
Number of presets128per project
Multitimbral combinations1000per project
Number of projects50
Sampling and samples
Audio input2 channels (stereo)
Max sample length60 minutes3 minutes max in granular, because of polyphony
Sample rate48 kHz
Mix resolution32 floating point
Sample channelsmono or stereo
Granular engine
Max chord size12
Max grains per voice128
Rate modesFree, Sync-size, Scan & rateFree means independent rate and grain size, other modes have synchronized rate and size options
Loop modesBounce, wrap, kill
Arp modesUp, down, random, shuffle, play order, and more
Spawn modesDirect, gradual, recycle
Phase vocoder
Max polyphony3
FFT size256..8192
Chord modeup to 12 notes per voice
Mod matrix
Number of LFOs44 per layer
Number of modulation sources20
Number of modulation destinations80and growing
Number of step sequencer modulators4
Filters
Filters per voiceLPF and HPF
Slope12 dB per octaveOther slopes possible in future firmware
Envelopes
DestinationsPitch
Filter
Amplitude
AuxFreely assignable
Length0.1 ms .. 45 s per stage
StagesADSR
ShapeCurved: from log to linear to exponential
FX
Number of simultaneous fx4
EffectsDelaysPlain, and ping pong
ReverbsHall and large (algorithmic)
DistortionOverdrive, and reducer
Dynamics (compressor)
More effects possible in future firmware
Step sequencer
Max chord size7
Max steps64
Step sequencers per patch1In multitimbral mode you’ll get up to 4 step sequencers total
Connectivity
Audio outputStereo TRS 1/4 ” balanced
Audio inputStereo TRS 1/4 ” balanced
SNR110 dB (in and out)
Headphone1/8 “
MIDIDIN (in out thru), USB C (in and out)
Eurorack interface1x gate out, 2x CV in (-5V..+5V)
LAN (ethernet)Gigabit (firmware update & filesharing)
Disk / USB sticksUSB A 3.0
Computer keyboardUSB A 2.0
HDMI output (monitor or beamer)1.2 full size
Storage
Included USB stick32GB, USB3, up to 100 MB/s
Internal storage512GB, 200+ MB/s
Dimensions465x270x95mm WxDxH
Weight4 kg
Zusätzliche bisher bekannte Infos:
Voraussichtlich gegen Ende des Jahres erhältlich, anvisierter Preis: ~1.800€
Für Besitzer des "kleinen Bruders" GR-1 interessant: die Software wurde von grundauf neu geschrieben, es dürfte also fraglich sein, was davon auch den Weg in den GR-1 findet (von den Beschränkungen der Hardware mal ganz abgesehen).
Einen direkten Vergleich von GR-Mega und GR-1 gibt es ebenfalls auf der Website.
Audio In, Midi In/Out/Thru - endlich. Ob mir das aber den saftigen Preis wert ist, muss man sehen. Oder besser hören. Bei den Effekten und bei den Filtern besteht erheblich Potential für Verbesserungen.
Ich hab direkt mal geordert. Hab voll Bock auf das Teil. Finde den Preis im Rahmen des Gebotenen in Ordnung und hoffe, dass die Firmware stabil läuft.
Bisher habe ich von der Soundqualität her und mit diesem Direktzugriff noch nichts Besseres im Granularbereich unter den Fingern gehabt als den GR1. Der hier reizt mich schon wegen der erweiterten Möglichkeiten und die Demos lassen Gutes erahnen.
Mittlerweile konnte ich in Erfahrung bringen, dass die Bestellungen nach Eingangsreihenfolge abgearbeitet werden. Ich rechne selbst nicht vor September mit der Kiste.
Wollte den GR-1 schon verkaufen, aber damit warte ich dann lieber noch.
Hat jemand Erfahrung mit der Kompatibilität zwischen dem GR-1 und dem M-Audio Air 192/14 gemacht? I Manuell selbst ist dieses nicht gelistet.
Ich habe keine Erfahrung mit dem M-Audio, aber da es class-compliant ist, sollte es mit dem GR-1 funktionieren. Ich hab mir damals extra ein Focusrite gekauft, nur um danach festzustellen, dass mein simples, aber class-compliant'es Zoom H2 auch bestens funktioniert...
Hab das Teil auch mal vorbestellt , ich habe den Eindruck das wird spannend und so ein Konzept Sampler/ Granularsynth mit grossem Bildschirm ( bye bye elektrons mit 1980jahre Anzeigen ) gibt es sonst nicht am Markt . BlackBox und Quantum können zwar auch beides aber BlackBox ist viel fummelspass und Quantum ist mit seinen 8 particle strains da eher einfacher gestrickt hat aber andere mächtigere Stärken.
Also auf ins Abenteuer Vorbesteller ...
Damals war ich einer der ersten beim Hapax und den würde ich nicht mehr abgeben wollen ... Ein wahnsinns Sequenzer !!! Sorry für off topic aber da gehen sämtliche Gäule in mir durch ...lach
Also tasty chips ...haut rein ... mir macht es auch irgendwie spass neue Geräte zu testen ins Set up einzubinden ... schauen was kann es ( mich interessiert eher weniger was ein Gerät nicht kann wofür es nicht konstruiert wurde ... )
