Bauteile für Threeler und Teezer
Ich überlege gerade, bei Bridechamber etwas zu bestellen. Da ich mich für Ian Fritz' PCBs interessiere, für teilw. seltene Teile benötigt werden, wollte ich eigentl. die Kits (= Bauteile) mitbestellen, ABER Scott/Bridechamber hat eine Flatrate für Sendungen mit Bauteilen von 43USD!
Vgl. hier:
http://www.bridechamber.com/bridechambe ... _Info.html
Hat jemand schon Threeler und Teezer aufgebaut und weiß, ob die Teile auch über Mouser, Reichelt, Segor u.ä. zu bekommen sind?
Treeler hat u.a.
2 x 3280
DG409
2k Tempco
Teezer special parts:
1) CA3280 OTA. This is the heart of the VCO. I tried an LM13700 but it was quite a bit inferior. Bridechamber is stocking the 3280, and I have a large stash of my own, which I will let Scott have if he needs more.
2) VN0104 MOSFET. Two of these are used for the integrator discharge switches. The switches have to swing a large voltage, due to the bipolar signal, and the low capacitance of this device makes a big difference in the reset signal. They are not rare or expensive, really, probably just a bit unfamiliar to most builders. 42 cents at Mouser.
3) A pair of matched 4.3V zener diodes. Buy 10 or so, measure their breakdown voltages and pick the best pair.
4) One pair ea of LM336-5 for the subregulated 5V supplies.
5) One pair ea of 3.3V zeners and 5.1V zeners for comparator decoupling.
6) MAT03 matched super transistor pair for the expo current source. SSM2220 is probably OK and has the same footprint. I've been using 2SA798, and the board will also take that.
7) One OPA2227 precision opamp for the expo converter circuit. OPA2134 would be just about as good.
#eight) 2 ea OPA134 and 2 ea OPA2134. Where low leakage/high speed are needed.
9) 2 ea LM311 high-speed comparators. For the two ramp resets.
10) Other opamps: 1 ea TL072 (or similar); 2 ea TL071 (or similar); 2 ea LM741 (for spike reduction).
11) 2k 3300 or 3500 ppm tempco resistor.
12) 6 ea ferrite beads. The power supply is split into three separately decoupled branches.
Beides würd mich evtl. interessieren. Allerdings auch nur als Kits. Möchte meine 3280 nicht dafür opfern ;)
Danke!
So auf die Schnelle sehe ich folgende Probleme: CA3280 und VNO104, der aber vermutl. durch einen anderen 104 MOSFET ersetzt werden kann?
Den OAP2227 finde ich nicht, aber dafür den OPA2134, der auch geht.
Den Rest gibt es alles bei Segor in Berlin. Allerdings teilweise teuer.
Die Tempcos sollten auch beschaffbar sein.
edit: CA3280 gibt es in der Bucht.
Nein. Ich habe mich (mal wieder) dazu entschlossen, erstmal meinen Rückstand an Projekten abzuarbeiten.
Allerdings, wenn ich mir Ians Projekte ansehe, juckt es mich schon wieder in den Fingern... :roll:
Wenn Du noch keine CA3280 hast und zum Bonner Treffen kommst, kann ich Dir zwei verchecken.
Das ist nett! Aber ich habe ja noch nicht mal die Boards. Nach Bonn kann ich auch nicht: Stubenarrest.
Ich bestelle was bei Bridechaber, wenn du noch was brauchst dann pm ;)
2k Tempcos brauch ich noch hat die wer?
Das dusselige bei Bridechamber sind die Kosten für den Versand. Da verdreifachen sich schnell die Kosten.
$8 International padded mailer -- small parts or one panel
$16 International flat-rate envelope -- anything that can be mailed flat (not parts!)
$45 International flat-rate box -- anything else
Ich bin immer noch unentschieden. :oops:
PM mir mal was du haben willst und ich frag mal Scott wies mit dem Versand aussieht. Momentan sinds nur einige Platinen, die theoretisch in eine padded Envelope passen müssten. Die Bauteile bekommst ja auch woanders, muss ja nicht von ihm sein.
