deton8 - Twisted Electrons hybrid Drummer/Sampler
Holz
Holz
Salud!
View: https://www.youtube.com/watch?v=IsDr5_E20eU
https://twisted-electrons.com/product/deton8/
deton8 is a hybrid sampler/drum synthesizer using a mix of crunchy 8BIT samples and wavetable synthesis. and a plethora of real time fx and tricks.
FEATURES:
  • USB-MIDI
  • Hardware MIDI
  • SYNC IN
  • SYNC OUT
  • 16 patterns of 1-16 steps each
  • Chain up to 16 patterns in a row to make a song
  • 8 Voices (Kick, Snare, Metal (hats), Clap, Can (tinny sounds), Tom, Nut (woody sounds), SYNTH (NES inspired triangle wavetable synthesizer, with arp that can be shaped to a square).
  • Pitch and decay modulation per step on every voice
  • 8 hands on Stutter modes: Beat repeat (with variable rate), Forward granular, Reverse granular, Pendulum granular (scratch), buzz/texture , random granular (noise generation), spin up, spin down
  • Forward & Reverse sample playback per track
  • Delay with variable delay time and pitch decay (upwards and downwards)
  • Ring mod effect with variable frequency
  • Global pitch shift
  • Copy/Paste patterns
  • Real time pattern recording with optional metronome
  • Tap tempo
  • Swing
  • Mute/Solo a track
  • Drive any voice into distortion
  • Sound variation knob for Kick (add sub), Snare (add noise/snappy), Hats (change texture) and Synth (arpeggiate)
  • Pump aka sidechain compression emulation (any track can “duck” the others for the pumping/breathing effect)
  • Pattern clean and randomize for accidental magical beats
Multiple kits can be uploaded via USB
  • DETON8 default (big beats, break)
  • AMY SISTER (jungle break)
  • HIP08 (for all your 808 hiphop needs)
  • TEK09 (Rave on)
  • MINTY POPS (Classic beats)
  • INDUSTRIAL (exclusive kit by renowned Industrial producer NEKRADAMAGE)
..kann man eigene kits hochladen? weitere soundbeispiele wären interessant..wie soll man sowas vorbestellen, ist doch´n blindflug..
suesse kleine kiste von twisted electrons in da pipeline:
"deton8"
kommt im april
255 euro plus mwst plus shipping
die website sagt:
Features
  • USB-MIDI
  • Hardware MIDI
  • SYNC IN
  • SYNC OUT
  • Tap tempo
  • Swing
  • Mute/Solo a track
  • TEK09 (Rave on)
es gibt ein demovideo:
weitere sollen heute oder morgen folgen...
vorbestellen kann man auf der website:
und wie findn wa das jetzt?
keine ahnung. ich will die kiste natuerlich haben weil "everything drum" eine magische anziehungskraft auf mich hat...
***sucht***
Twisted Electrons schrieb:
FEATURES:
Das werden aber ziemlich kurze Songs...
Warum benennt man es nicht nachdem, was es ist: Pattern-Chain. Bescheuertes Wording.
Klingt zumindest so;
You’re encouraged to submit your own samples! We will host regular competitions, the winning kits will get freebies and the kits will become available as free downloads
die samples muessen wohl auf 8bit kompremiert werden.
ich frag mal nach ob das die user machen koennen.
ok. also: nein. die samples sind im OS embedded. deswegen geht das nicht.
aber man kann seine samples einschicken und die besten kommen dann jeden monat raus. kostenlos fuer alle user.
also ich werds machen. be prepared for some mad mad noize!
update:
der import eigener samples wird doch moeglich sein per speziellem editor programm.
das erhoeht natuerlich den wert - also die usability des ganzen nochmal gewaltig....
Etwas fummelig gerade die Geschichte mit der Solo Schaltung von Sounds allerdings sollte der Kleine mit nem BeatStep Pro echt ein gutes Paar abgeben.
Mit der Möglichkeit eigene Samples importieren zu können auch als Zusatzdrummie z.B. für den Octa interessant.
alle knoeppe koennen ueber midi cc gesteuert werden (ausser mainvolume).
via midi connection oder usb
twisted electrons updated diesbezueglich website und manual.
aber alex ermahnt nochmal ausdruecklich:
es ist ne 8 bit maschine mit 128 k speicher.
deton8 soll nicht die mpc live ersetzen!
Ich werde von twisted electrons langsam fan. Nach dem Mega FM bin ich auf deton8 gestoßen. Der macht mir richtig Spaß der kleine Drummer. Feines kleines Teil und macht ordentlich Rums.
Wäre er stereo hätte ich ihn auch genommen aber echt feines kleines Ding.
Similar threads
