Liste mit Factory resets Roland
Gerade gefunden... Ohne Garantie
http://www.futureproducers.com/forums/h ... ets-76951/
Roland A-220
hold B and memory then power on
Roland A-30
write + power on (15 seconds)
Roland A-33
Roland A-50
hold 1st+3rd+4th buttons under display, press channel, then press any cursor key
Roland A-80
Roland A-880
hold signal and memory then power on.
Roland A-90
hold edit, power on then press enter
with voice expander board: hold manual, power on, then press Enter.
Roland ADA-8024
no rom reset
Roland Alpha-Juno 1
no rom reset
Roland Alpha-Juno 2
no rom reset
Roland AP-700
power on, exit repeatedly to analyzer/filter screen; cursor to: menu + enter, system + enter, init + enter; use value select all then exec + enter twice
Roland AR-series
no rom reset
Roland AT-series
one touch program + power on
Roland AX-1
write + power on (30 seconds)
Roland Axis-1
hold function; press f#0, c#2, and d#2 keys
Roland CA-30
resets every time toggled of and then on
Roland CR ( all other)
no rom reset
Roland CR-80
del + repeat + power on, then press enter.
Roland CSQ-series
no rom reset {*}
Roland D-10
no rom reset {*}
Roland D-110
no rom reset {*}
Roland D-20
no rom reset {*}
Roland D-5
no rom reset {*}
Roland D-50
tune/function and midi data init: hold 0 and data transfer, power on, patch + reverb data must be loaded from card or sysex file
Roland D-550
tune/function and midi data init: hold patch bank 2, patch number 6, and enter, power on; patch + reverb data must be loaded from card or sysex file
Roland D-70
no rom reset {*}
Roland DDR-30
hold #1 button + power on
Roland DEP-3
memory no up and down + power on
Roland DEP -5
Roland DJ-70
no rom reset
Roland DJ-70mkII
no rom reset
Roland DM-series
no rom reset
Roland DR-5
fret left + fret right + power on; 2 x enter
Roland DR-550
hold -1 and +1 and power on, then press start
Roland DR-550mkii
Roland DR-660
utility then cursor to select (8) init; 2 x enter
Roland DS-330
reverb + split + power on; press yes
Roland E-10
hold write + power on
Roland E-12
no rom reset
Roland E-14
no rom reset
Roland E-14us
resets at power on
Roland E-15
resets at power on
Roland E-16
resets at power on
Roland E-20
Roland E-28US
resets at power on
Roland E-30
Roland E-35
hold rec/punch in + power on
Roland E-36
recorder + power on
Roland E-5
no rom reset
Roland E-56
Roland E-66
record (in disk recorder section) + power on
Roland E-68US
Roland E-70
Roland E-86
Roland E-96
Roland EM-101
no rom reset
Roland EM-303
resets at power on
Roland EM-305
resets at power on
Roland EP (all other)
no rom reset
Roland EP-3
resets at power on
Roland EP-5
hold rec + play, press strings, power off / on
Roland EP-7
Roland EP-707
resets at power on
Roland EP-7mkII
hold rec + play, press strings, power off and on
Roland EP-9
hold rec + play, press choir, power off and on
Roland FC-100
no rom reset
Roland FC-100mkII
hold #1 + #2 + #8 and power on
Roland FC-200
hold #10 and power on, then press ctl pedal
Roland FG-10
hold clear and exit then power on
Roland FG1000
Roland FP-1
resets at power on
Roland FP-8
press func and release hold piano press func again
Roland G-800
hold write, then power on.
Roland GC-8
no rom reset
Roland GI-10
hold parameter + and - , power on then press value +
Roland GM-70
poly mode: hold play, general edit, + ind edit then power on; mono mode: hold tune, control assign, and data transfer then power on
Roland GP-100
hold in parameter knob, power on, press write
Roland GP-16
hold #6, #7, #8, then power on; use function left and rught to select "2; all factory preset" then press write 3 times
Roland GP-8
no rom reset
Roland GR (all other)
no rom reset
Roland GR-09
hold pedal #2 then power on; press value+ then press edit/play
Roland GR-1
hold write/copy then power on then press yes
Roland GR-30
hold pedal #2, power on. Press patch + to select init; press edit/play, then patch + and - simultaneously
Roland GR-50
no rom reset
Roland GS-6
no rom reset
Roland GT-5
hold mod + feed backer/slow gear, power on; then press write
Roland GX-700
press tuner/utility; use parameter left and right to select fact init; cursor to left, dial system, then right and dial p#100; press write then tuner/utility
Roland HP (all other)
resets at power on
Roland HP-100
no rom reset
Roland HP-300
no rom reset
Roland HP-400
no rom reset
Roland HS-series
no rom reset
Roland JD-800
press data transfer; page up to select factory preset, press yes
Roland JD-990
hold exit and press utility; press F6 then F5.
Roland JP-6 ( = Jupiter 6)
no rom reset
Roland JP-8 ( = Jupiter 8)
no rom reset
Roland JP-8000
hold shift, press init/bulk. Press button 7, use up/down (select factory reset), press write to select factory preset
Roland JP-8080
Roland JS-30
hold record button (sequencer section), power on
Roland JUNO-106
no rom reset
Roland Juno-60
no rom reset
Roland Juno-1 ( = Alpha-Juno 1)
no rom reset
Roland Juno-2 ( = Alpha-Juno 2)
no rom reset
Roland Juno-6
no rom reset
Roland Jupiter 4
no rom reset
Roland Jupiter 6
no rom reset
Roland Jupiter 8
no rom reset
Roland JV-1000
hold number 8, power on; press enter then write
Roland JV-1080
press utility; cursor down once then right 3 times to factory preset; press enter twice, then utility
Roland JV-2080
press utility. Press F6 twice to menu 3; press F1 then F6; if required use value dial to turn off mem. prot. and press F6 twice
Roland JV-30
press chorus + reverb (above init) together then press value up
Roland JV-35
press control + master together; use parameter up and down to select all; press value up
Roland JV-50
Roland JV-80
Roland JV-880
press utility, use data dial to select factory preset; press enter twice
Roland JV-90
Roland JW-50
press tune/function; press F5 then F4 then F3 then F4.
Roland JX-1
hold write and flute then power on
Roland JX-10
no rom reset
Roland JX-3p
no rom reset
Roland JX-8p
no rom reset
Roland KR-100
resets at power on
Roland KR-3000
hold from and to, then press write
Roland KR-33
resets at power on
Roland KR-350
hold load and save, then press write
Roland KR-3500
Roland KR-370
resets at power on
Roland KR-4500
Roland KR-4700
hold load and edit, then press save
Roland KR-500
Roland KR-5000
Roland KR-55
hold midi function and press cards (5 seconds)
Roland KR-5500
Roland KR-650
Roland LVC-1n
hold enter button then power on
Roland M-760
hold edit, press write; parameter up/down to select all + press write; on completion press edit to return to play
Roland M-DC1
hold F3 and then power on
Roland M-GS64
hold f3 and then power on contributed: hold select and press F4, press F3 and then press enter
Roland M-OC1
Roland M-SE1
Roland M-VS1
Roland M-BD1
Roland MC-series (exc. 303)
no rom reset
Roland MC-303
hold shift and then power on, then press enter
Roland ME-10
hold bank down pedal, then press write
Roland ME-5
hold pedals 1 and 2, power on; press write immediately
Roland ME-6
hold left + down and power on; then press write
Roland ME-6b
Roland ME-8
hold left + down and power on; press write/copy
Roland ME-8b
hold parameter left + down buttons, then press write/copy
Roland ME-x
hold parameter left + down and power on, then press write
Roland MK-80
hold write, press edit; hold left and right cursor buttons and press up
Roland MKB-series
no rom reset
Roland MKS-50
poly mode: hold number buttons 4 and 8 and power on
Roland MKS-50
mono mode: hold number buttons 3 and 7 and power on
Roland MP-series
no rom reset
Roland MS-1
no rom reset
Roland MSQ-100
no rom reset
Roland MSQ-700
no rom reset
Roland MT-100
hold stop, press delete; after the display flashes "all clear" press execute
Roland MT-120
hold repeat, song (blue), and play, power on.; press fwd repeatedly until reads T13; press play then record, then power off/on
Roland MT-120s
hold repeat, song (blue), and play, power on; press fwd repeatedly until reads T13; press play then record, then power off/on
Roland MT-200
hold repeat, song (blue), and play, power on; use dial to select T15 on display; press play then record, then power off/on
Roland MT-32
hold master volume, press rhythm part, press par t 1
Roland MT-80
resets at power on
Roland MV-30
no rom reset
Roland Octapad
hold midi ch and note number, power on; power off, then power on again
Roland Octapad II
hold both value buttons, power on
Roland P-330
no rom reset
Roland P-55
hold both instrument buttons, power on, then press param 1
Roland Pad-8
Roland Pad-80
Roland PC-150
hold command (left), power on
Roland PC-200
hold the 2 buttons under "standard", power on.
Roland Piano Plus (all)
no rom reset
Roland Planet-P
no rom reset
Roland Planet-S
no rom reset
Roland PMA-5
hold value, power on; touch 2 cal; points top right + bottom left of display w/ touch pen; displays completed then initialize, touch exec
Roland Pro-E
hold write, power on
Roland R-5
hold page + select and power on; press enter twice at prompts
Roland R-70
hold midi + assign and power on; press yes twice at prompts
Roland R-8m
hold cursor right and enter, power on. Press enter twice at prompts
Roland RA-50
hold write then power on
Roland RA-90
Roland RA-95
hold rec, power on
Roland RSP-550
power on while holding prog page up and down, then press write
Roland SB-55
power on while clear
Roland SC-155
power in standby mode; hold both instrument buttons, press power on and then press all
Roland SC-33
hold split and reverb while powering on, then press yes
Roland SC-50
hold both instrument buttons and power on; then press all
Roland SC-55
Roland SC-55mkII
Roland TD-8 V custom
press setup then [f3 (menu)]; press inc/+, rotate the value dial, or press cursor to move the cursor to "reset"
Roland TR-505
hold pattern group a and mode and power on
Roland TR-626
hold track #1 and mode and power on
Roland TR-707
hold track write and pattern 1 and power on
Roland TR-727
Roland TR-909
hold track #1 and pattern #1 and power on
Roland U-110
hold the edit and part buttons and power on
Roland VP-70
hold midi, play, and voice exp and power on
Roland XP-50
press disk util, select sound, then protect, set mem protect off; exit, select preset and press enter (remember to set mem protect back on )
M.i.a.u.: GeoTeknique
die der tr909 habe ich vor kurzem mal bei nem bekannten gemacht. die pattern die dann in der 909 sind sind echt der knüller..
