audio.computer beat friend
bartleby
lieber nicht.
niedlich:
Beat Friend is the first offering from audio.computer, a UK-based duo making ‘benevolent, semi-autonomous music machines’. Beat Friend is an analogue drum machine, using circuits based on the ‘twin-t’s from the legendary Roland CR-78. Each drum has a slider that changes the drum’s complexity within one of the 30+ preset patterns, which already allows hundreds of variations on any given beat.
But wait! There’s more! Turning the Enthusiasm knob allows Beat Friend to add or subtract notes from the pattern as it sees fit, either keeping the pulse of the pattern or going completely off piste. It's like having an enthusiastic robot Labrador playing a 70's electronic drum kit just for you.
All the sounds are routed through a Triforce of digital and analogue effects, which...well, you just have to turn knobs to find out what they do. If you’ve ever wanted to base a track on a 7/8 samba through a bit-and sample crusher, then this is the unit for you.
And, sure, if you’re a control freak who absolutely must design every bar, you can control the drums individually via MIDI. It even includes a letterpress-printed manual, numbered to match your unit.
Beat Friend plays in glorious mono and is powered by a universal 12V power supply (included in the box).
https://audio.computer/
