Beetlecrab Tempera - Granular Synth
Was kann ein Emitter und wie klingt das dann - als "Hintergrundaudio-Check" gemacht für unsere Sondersendung mit Andre (Entwickler)
Andre​
Hello all!We are go for Tempera firmware v2.3-rc1 with a bunch of improvements, bug fixes and polishings Big thanks to everyone who participated, reported bugs and brainstormed
  • Fixed modulator modulating another modulator's size
  • Fixed crash when viewing waveform after being on the last page of parameters
  • Fixed Note index modulator is now quantized to notes and hidden decimal numbers are discarded
  • Polish dangerous actions of loading or merging a canvas, or batch-loading samples from a folder are now protected by the need to hold the button for a bit
  • Polish the defaultly selected element in Sync time is now the time signature
  • Polish Sync time is now greyed out again when Grain trigger is 0.0
  • Polish most action UI buttons now flash briefly to give a confirmation that they did a thing. Seems more civilized to me but let me know if it's obnoxious.
  • New function Grain skip probability works the same was as Grain reverse probability and these two share a UI slot
  • New function Internal SD Card / Flashdrive formatter which will format the medium with a compatible ExFAT and MBR partition. This is usually not necessary but might help.
  • New per-emitter function Grain pitch. It goes smoothly from -12 to +12semitones and integrates the Octave switching. Grain pitch is also a modulation target. Behind the scenes it hitches a ride on pitchbend which was already per-voice
  • New function to Nudge cell markers in -> Edit -> Trim . Select the marker and then turn the 2nd encoder to adjust. This allows to have uneven cell lengths if your audio material requires it
Bytes are ready for download here: https://fw.beetlecrab.audio/tempera/tempera-2.3-rc1.firmware , update procedure same as before.Please give it a go and report any new or lingering bugs or oddities.
Spannendes Teil. Ich habe ihn gebraucht gekauft und freunde mich gerade mit ihm an. Es wäre noch toller, wenn man ihn auch als externen MIDI Sequencer nutzen könnte...
Andre​
Hello fam,Many thanks for testing and bug reports, here's them fixed in Tempera firmware v2.3-rc7:
  • Fix crash when macroing the quad-macro (you animals) @Sezare56 @Gav :: Realm
  • Fix bug where Rec monitor and Effects sendwould move together @Mafic Depths
  • Fix bug where switching emitters via a shortcut or scroll-through would not send the action over midi when Control MIDI channel is enabled @ezoray
  • Fix bug where while holding the quad-macro Store, repeated storing was not possible @Sezare56
Download here: https://fw.beetlecrab.audio/tempera/tempera-2.3-rc7.firmwarePlease report bugs, quirks and incorrects Update procedure same as before:
  • Place the firmware file onto an SD card or USB flash drive
  • With the storage medium plugged in, turn Tempera on while holding the round button until the orange splash
  • Follow instructions on the displays
M.i.a.u.: MC242
Das sind nur die Texte die von dort gepasted sind - da müsstest du direkt Andre fragen, weiss nicht ob die / er hier mitliest. Spricht kein deutsch (auch wenn das heute weniger ein Problem ist)
Ach okay, danke. Jetzt sehe ich es auch. Danke für den Hinweis! Und danke für den Post, SirAdrianFish. Dann werde ich mich mal direkt an den André wenden.
M.i.a.u.: SirAdrianFish
Mit liebem Gruß - von "hier" und allem, die geben ja dermaßen viel Gas bei Firmware. Das muss man echt mal sagen.
M.i.a.u.: MC242 und j3122
Ich habe das jetzt mal im Beetlecrab Discord Kanal gepostet und direkt schon Aufmerksamkeit bekommen.
Man muss aber auch sagen, dass die „ähnlichen Mitbewerber“auch ziemlich auf Zack sind.
Der Torso S-4 wird auch sehr schnell entwickelt inzwischen. Aber der war wohl am Anfang auch eine ziemliche Katastrophe… 🙈
