OS 1.2.0 ist draußen. Das geht ja jetzt Schlag auf Schlag
Improvements
Added the Steel Box Reverb FX machine for Bus, Send FX, and Mix tracks.
Added the Filter Folder FX machine for all tracks.
The Daisy Delay FX machine is now available for all tracks.
The Frequency Warper FX machine is now also available for tracks 1-8.
Added Random playback mode to the arpeggiator.
Added PATTERN MUTE mode.
Gain reduction amount is now shown in the Compressor UI.
Audio combined from inputs A and B is added as a compressor sidechain source.
Added audio from the Bus tracks outputs as a sidechain source for the compressor when placed on the Mix track.
It is now possible to start the sampling in the Recorder by pressing PLAY.
Improved tempo stability when simultaneously receiving clock and large amounts of MIDI data from an external source.
Chord mode now also affects what happens when placing trigs in GRID RECORDING mode or when using STEP EDIT.
The GRAINER SRC machine can now play shorter samples.
Improved the sample loading priority when changing patterns.
Added the [FUNC]+[NO] shortcut to exit the Sample browser.
Active track and parameter page selection, TRIG mode, FILL mode, sequence lane, keyboard octave, transition, and quantization settings are now saved in the project.
Added protection against infinite MIDI All-Sound-Off cycles.
Added control of Global track mutes over MIDI CC (94).
It is now possible to manually cancel the Auto-sampler’s timing test.
Added snap values for the DRY/WET parameters for the FX machines.
Improved the encoder feel for the TRIG PROB parameter.
Minor improvements to the screen UI and messages.
General performance and stability improvements.
Bug fixes
The FX LFO 2 depth parameter did not load correctly from presets.
When in GRID RECORDING mode, copying a parameter page incorrectly exited GRID RECORDING mode.
It was not possible to copy a parameter page when an FX track was visible in overlay mode.
Adding micro timing on step 1 on the supertrack could, under some circumstances, delete trigs.
Pasting or recalling a pattern could reset the metronome and recorder settings.
Undo/Redo key combinations could conflict with actions in the sample recorder.
The Filter Stereo Spread (SPRD) parameter on the Grainer SRC machine was not mapped to the correct MIDI CC value.
The FX LFO parameter’s MIDI CC mappings did not work on tracks 1-8.
The MIDI CCs for the IN B parameters controlled the IN A parameters.
The MIDI NRPN controls for the Subtrack’s FLTR page were mapped incorrectly.
Sequencer transport could stall if external MIDI sync was interrupted.
MIDI pitchbend and aftertouch messages were not forwarded to tracks when using the auto channel.
Daisy Delay and Frequency Warper parameters were not saved to presets if they were used in FX slot 2.
Metronome could go out-of-sync with the sequencer when cue-starting the sequencer using [STOP] + [PLAY].
Trig conditions were not reset when cue-starting the sequencer using [STOP] + [PLAY].
Exiting menus by pressing the active parameter page button instead advanced to the next page in the page group.
The Step Edit indicator LED was not illuminated when some menus were active.
Some menus had misleading LED indications on the [ARROW] keys.
Removing the last pattern in a song row created from a chain also deleted the last digit of the previous pattern’s slot number.
Rapidly changing sample slot assignment while playing could cause the device to be temporarily unresponsive.
It was not possible to use the LEVEL/DATA encoder to scroll the LOAD PROJECT section of the FILE menu.
The incorrect sequence lane could be shown as selected after loading a project.
Pasting a track sound could sometimes cause the device to become unresponsive.
