Arturia Minibrute Analog Synth
Arturias new Mini Brute Analog Synthesizer
more musical video approch from the EM project Node
Multimode Filter (Steiner Parker),
1 OSC with SubOSC,
2 LFOs,  0,1 Hz to 100 Hz
special „Ultrasaw“ and „metallic“ settings called Metalizer
2 ADSR envelopes
25 dyn keyboard with aftertouch
CV/Gate
USB MIDI, MIDI in / out (no thru)
Arpeggiator possibly sooner or later with Pro-One kind of Mini Sequencer
“ Note that the Arpeggiator can also be used as a basic sequencer. In the Hold mode, you press and hold the first key of the sequence, then you just enter the other notes by pressing the corresponding keys while still holding the first note of the sequence, during this process you can change the octave range of the keyboard between entering the notes therefore you are not limited to two octaves for the sequence. You can sequence a maximum of 12 notes. Unfortunatly once playing the sequence it cannot be transposed by the keyboard because pressing a new key resets the sequence.“
this is not sure to be in the software – so keep this as „things that might happen“ – just to quote Tomeso, german distribution
UPDATE: official info: http://www.arturia.com/evolution/en/products/minibrute/intro.html available in APRIL 2012
Links & PDFs Arturia NAMM 2012 – da kommt was völlig Neues!
500€
UPDATE: Videos
Arturia MiniBrute Tour
another Video / ein weiteres Video in Deutsch – vorn „Talk“, ab 2:12 Sound
one more thing.. from the NAMM
Arturia @ NAMM 2012 - MINIBRUTE
Related posts
4 Thoughts to “Arturia Minibrute Analog Synth”
  1. […] we have these analog synths now (via NAMM) – Arturia Minibrute – Moog Minitaur – Mfb Dominion X – Waldorf Pulse 2 – MacBeth Minimac – Eowave Koma AKPC_IDS += […]
  2. […] we have these analog synths now (via NAMM) – Arturia Minibrute – Moog Minitaur – Mfb Dominion X – Waldorf Pulse 2 – MacBeth Minimac – Eowave Koma- Jomox Moonwind […]
  3. […] a keyboard version – or well – this is some graphics – maybe triggered by Minibrute and other new […]
Comments are closed.
