Erica Synths Bassline DB-01 (V1.07)
Sammy3000
Sammy3000
Features:
  • Aggressive LP/BP filter design from the Acidbox
  • One knob overdrive for even more destructive sound
  • Transistor based sub-oscillator
  • Independent amplitude, filter cutoff and pitch envelopes
  • BBD based detune for massive swarm sound
  • Syncable LFO with multiple waveforms for FM and VCF modulation
  • Noise source
  • Intuitive, easy to use sequencer for up to 64 step patterns
  • Sequence transposing
  • Pattern randomization
  • Arpeggiator
  • Modulation track with VCF cutoff automation
  • Built in and user defined scales with micro tonal possibilities
  • Analog clock in and out
  • CV/Gate output/input
  • MIDI IN and THRU – play it with a keyboard!
  • 4 banks of 16 patterns memory
  • Compact, durable aluminium enclosure
https://www.youtube.com/watch?v=CDalimq5SvI
Sieht auf den ersten Blick schick aus. Könnte was vom Todesstern sehen.
Derzeit noch eine Bassline herausbringen ist durchaus mutig... mal anhören....
Nun ja, Sounddemo etwas "zerfahren". Hubschrauber-Arpeggios sprechen mich erstmal nicht an. Der hat 2 Oszis? Wo stelle ich eigentlich das Tuning ein?
Nice - geiler Sound - Katze tot. Passt natürlich zum Gesamt-Konzept. Programmierung der Steps sieht aber nicht sehr intuitiv aus - aber gut das ists bei der 303 auch nicht.
mono lancet 15 finde ich besser. gut der hier hat einen sequencer.
This is THE Bassline!
From basslines and rave sounds to massive drones and drums - the Erica Synths Bassline DB-01 synthesizer lets you explore new territories of sound and performance techniques and go from a melody to noise and back in no time. The DB-01 packs analogue Erica Synths signature sound engine with an advanced sequencer on top of it.
Features:
Aggressive LP/BP filter design from the AcidboxOne knob overdrive for even more destructive soundTransistor based sub-oscillatorIndependent amplitude, filter cutoff and pitch envelopesBBD based detune for massive swarm soundSyncable LFO with multiple waveforms for FM and VCF modulationNoise sourceIntuitive, easy to use sequencer for up to 64 step patternsSequence transposingPattern randomizationArpeggiatorModulation track with VCF cutoff automationBuilt in and user defined scales with micro tonal possibilitiesAnalog clock in and outCV/Gate output/inputMIDI IN and THRU – play it with a keyboard!
Get yours in spring 2020!
Price - 460 EUR (ex. VAT)
https://m.facebook.com/ericasynths/videos/2482195802005224/
Das ist ne erwachsene Volca - was ich gut finde. Aber wieso finde ich den sound so "normal" - bei mir kommt kein Acid-feeling auf!?
Kann die auch Acid??
Wenn... dann will ich auch sowas machen können wie mit der Volca Kick:
  • vKikPhras 50.WAV
Ich hab mal in das Modul reingehört und es ist ganz OK, aber nichts, was sich für die ewig überausgestattete Monosynth Sammlung aufdrängen würde.
