Roland Juno-60 Chorus PCB Build- Tipps
I don't seem to be getting any signal across C30 or C31.
There is no signal "across" C30 / C31. You have to measure one side of the capacitor against ground.
I'd check the complete signalpath sending in a constant testtone: U9A pin1, U9B pin7, Q19 Emitter, U5/U7 pin3, U5/U7 pin8 and pin7, Q11/Q12 base Q14/Q15 base, Q16/Q17 Drain, U19 pin1 and pin7. All points measured against ground. For measuring use an audio probe or an oscilloscope.
I got as far as pin 7 of U9 before the signal doesnt show on my scope. What could this mean?
EDIT: Nevermind I had the input level turned down so it wasnt showing, I will continue testing the signal path
EDIT: Ok I was able to follow the signal until I got to pins 8 and 7 of U5 and U7. Would this suggest the chips are bad? Or could there be another problem? They are the xvive models.
  • #34
Hey Copacetist,
I have the same problem with the xive bbd chips. There is only the dry signal without any chorus effect.
I thought for a while I fried them and couldnt check one a scope to verify my thoughts.
Now hearing you had the same porblem, I might have another try on finishing this.
  • #35
Interesting! I also know of one other case of this happening from a different forum. I ordered some new chips in the hopes that they will fix the problem. Please let me know if you give it another shot and discover anything.
  • #36
Small update: Unfortunately I still haven't been able to get this working. I just got some new MN3101s from a different source as the previous pair in today and swapped them in but no change occurred. I also have tried fresh MN3009s and that didn't help either. I noticed that pressing the bypass switch didn't have an effect on Q13 so I replaced it as well, but that didn't change anything either. I now know of at least two others that are having this same problem. If anyone has any ideas as to what is going wrong and how to fix it I would appreciate it greatly if your were share them. Thanks.
hi, seems like I have pretty the same problems with my build. bypass switch does not have any effect, no output on pin7/8 of the MN3009 (xvive), the lfo signal (depth/rate) gets lost right after Q1/Q2 and D3/4.
unfortunately, i have too little understanding of the circuitry around MN3101, how the clock signal output on pin 2+4 is generated. my 3101s work fine with the test oscillation circuit in the datasheet, but in the chorus circuit i have something like a constant -15VDC on OX1.
i assume that the xvive BBDs are fine as long as they don't get a proper clock signal on CP1+2...
any help would be really fine.
cheers
  • #38
hi Copacetist and others, i think i got it now. and it's too bad...
the BOM file on top of this thread is somehow messed up for my PCB (second column of resistors is sorted by name AND value). i got it from synthDIY/Canada. after comparing with gligli's BOM i had to interchange 28 resistors and voilá everything's up and running!
so maybe that's the same thing with your build.
but there is still a problem with LFO bleedthrough (ticking at speed rate on direct and both FX audio paths) which is described in #19. i tried with different power supplies, no change.
is there any solution for this?
M.i.a.u.: Peppy
  • #39
I have the same problem too - I also bought the pcb from Synth DIY in Canada. I'd used the wrong resistors as noted here so I switched them today - still no effect and just the level pot working, the 3pdt I'm using as a switch does nothing either
  • #40
Just found that D3 is wrong on the BOM here too - should be a 1N4148. Doesn't change anything for me unfortunately
  • #41
Finally got around to replacing the resistors today. Mine works now! I also replaced D3 as noted by Lanark, just to be safe. Thanks fyfno!
  • #42
ich habe mir neulich zwei mal den Juno Chorus gebaut. Als erstes die THT Eurorack-Variante von Feedback Modules. Dafür habe ich alle Bauteile (bis auf die Xvive MN3009) von Reichelt bezogen und es läuft alles einwandfrei. Das Chorus-Rauschen ist sogar leiser als bei meinem originalen Juno-106. Ich bin also sehr zufrieden damit.
Als zweites habe ich den GliGli-Chorus gebaut um den es ja hier im Thread geht. Die Bauteile sind auch alle von Reichelt (bis auf Platine & Xvive MN3009) und die Schaltung ist etwas anders als die von Feedback Modules. Der Chorus scheint zu funktionieren, jedoch liegt über dem Chorus-Rauschen ein störendes Signal. Es klingt wie ein schneller Sinusweep, Laser FX oder irgendetwas was einstreut.. ich habe keine Ahnung. Vielleicht kennt jemand das Problem oder wüsste wo es herkommt. Bei meinem Originalen Juno und dem Feedback Modules Chorus ist das Geräusch nicht.
In der Audiofile hört man: Sound ohne Chorus - Sound mit Chorus - nur den Chorus - nur den Chorus (+42dB)
Vielen Dank für Eure Hilfe!
  • #43
Das ist Taktübersprechen. Eventuell ist der Takt, der die Eimerkette taktet, einfach bis zu einer zu niedrigen Frequenz herunter moduliert.
Ein Defekt oder Baufehler im Bereich der Eimerkette selber oder der Taktunterdrückung ist das eher nicht, da es rechts und links, also bei beiden Eimerketten auftritt. Da müsste es ein systematischer Fehler sein.
  • #44
Hi,
da scheinst du nicht der einzige zu sein. @thecity hat das gleiche Problem:
Ich hätte noch ein Frage an alle, die diese Platine auch schon aufgebaut haben. Ich hab jetzt alle Buchsen und Potis dran und auch 2 BBDs eingesetzt, bekomme aber 2 seltsame Störgeräusche.
Zu einem ein Regelmäßiges Knistern und dann eine Art Sinus. Beides wird schneller, wenn ich den Rate-Regler hochdrehe.
Sind hier die BBD-Chips vielleicht defekt? Oder doch eines der Bauteile?
Bei mir tritt ein etwas anders geartetes Geräusch auf, jedoch ist es meistens nach aus- und anschalten wieder weg:
es ist wieder Herbst und somit Bastelzeit ?
Ich hatte im Frühjahr mit einem Kollegen mal ein Scope an den Chorus angeschlossen, aber das komische war, dass er genau dann funktioniert hatte. Ich habe mittlerweile herausgefunden, dass ein An- und Ausschalten beim Auftreten des Störgeräuschs hilft. Wenn man den Chorus wieder aus- und anschaltet wenn er korrekt funktioniert, geht er meistens auch weiterhin (auch mehrmals). Ab- und-zu kommt dann aber auch nur wieder das Störgeräusch.
Ich würde das Projekt nun gerne abschließen, komme aber mit diesem Fehler nicht weiter und wollte euch nochmal um Hilfe bitten, was denn das Problem sein kann. Ich habe zur besseren Veranschaulichung ein Video aufgenommen (Vorsicht, die ersten 30 Sekunden sind nur das Störgeräusch):
Habt ihr eine Idee was das Problem sein kann? Oder muss ich damit leben dass beim Auftreten des Störgeräuschs einfach ein an- und ausschalten hilft?
Danke im Voraus!
  • #45
@diggs
Wildwestmethode, also erst schießen, dann fragen:
* zwei Dioden (SB130, 1N400x (mit x=1..7)) in Sperrrichtung über die Versorgung (z.B. an C3 und C4) löten. (Der Strich der Diode kommt dabei an die Plus-Seite (das ist die nicht markierte Seite) des Elkos. )
* U1 und U4 gegen 4558 (MC4558, RC4558 usw. ) tauschen.
  • #46
Vielen Dank für die Antworten!
Ich habe alle Widerstände, Kondensatoren, OPVs, Dioden und Transistoren geprüft und konnte keine Fehler finden. Ich habe auch den MN3009 und MN3101 von meinem funktionierenden Nachbau verwendet, jedoch ohne Erfolg.
Momentan weiß ich nicht was ich noch überprüfen könnte. Falls ich Lust und Zeit habe werde ich weiter nach dem Fehler suchen.
Viele Grüße
  • #47
Ich habe das Problem nun lösen können. Nachdem ich wie bereits geschrieben alle Bauteile überprüft hatte, blieben nur noch die 15V Spannungsregler übrig. In dem Juno Chorus von Feedback Modules wird mit 12V (Eurorack) gearbeitet. Ich habe daher bei mir zum testen 12V Spannungsregler verlötet und siehe da, der Chorus funktioniert einwandfrei ohne Nebengeräusche. Warum ich der Einzige mit diesem Problem bin weiß ich nicht. Theoretisch sollte die Schaltung mit 15V funktionieren. Falls jemand also eine Idee hat woran das liegen kann, würde ich mich freuen es erklärt zu bekommen. Danke und viele Grüße
  • #48
Hello,
the posts here are a bit old, try to ask anyway.
I have everything there to build the chorus, but now I'm confused about which parts list I should stick to? to that of "fyfno" which he posted here as a correction or that of "LED-man" (gliglis) with the 19x 22k resistors and 7x 10k?
who was successful with which variant?
Thanks in advance
Symbol „Von der Community überprüft“
  • #49
...it's been dealt with ! DSL-Man has mixed up the list of resistors here, it is correct to stick to the "Originale-GliGli" Bom list!
M.i.a.u.: diggs und Miks
  • #52
I have now completed the Juno Chorus 60 (PCB) and the Feedback Chorus 106, both work and sound great, they sound very identical, but the juno 60 is more flexible! No interference with GR1815-Y!
I've never really liked the chorus sound with synthesizers, but these sound great, making the sound warm and wide!
M.i.a.u.: fanwander und Miks
