Update von GliGLi:
Hello,
I just released the new firmware version (build 2024-10-29)
What's new:
• New factory presets from Solidtrax.
• Firmware speed improvements, now the user interface won't slow down on modulation-heavy presets.
• New "Amplifier level" parameter, that can be used to level the volume of patches or to add even more overdrive at high levels.
• New "Wave Folder" WaveMod, that vertically (through amplitude) folds waveforms, ie. when they go past the maximum, they fold (or "bounce") back, and the WaveMod amount is the pre-amplification (from 1 to 16).
• New "Bit Crusher" WaveMod, that works by lowering the amplitude resolution of the single cycle (contrary to the "Grit" one, which lowers the frequency resolution).
• New "LFO Trigger" options, to reset the LFOs on each key press and to control how many periods they run.
• LFOs at speed 0 can now be used as a source of constant modulation.
• Patch names, that can be edited on a computer.
• Added "Perc" and "FX" as preset type.
• When the arpeggiator is in hold, new notes can be assigned regularly, allowing to play over an arpeggio pattern.
• Many user interface usability improvements.
• Bug fixes.
Download links:
https://github.com/gligli/overcycler...build_20241029
Edit: By the way, the synth will be back in stock next week!
Und noch ein Video zu den Presets:
