OnTopic Waldorf M - Microwave 1&2 - Nachfolger
  • #2.911
Es wäre schön, wenn es dazu noch ein Update geben würde, das nur die ursprünglich angedachten Funktionen mit funktionierendem Multimode enthält, @rolfw
Nicht die Lösung, aber hier das Statement von Vladi, das dem Update beigefügt ist:
Multi-Mode Tips & Tricks
The M’s multimode has received considerable criticism over the years. I understand this, as
users often expect it to function similarly to digital-only synthesizers. However, the multimode
was originally intended as a highly flexible system, allowing users to configure the four
dedicated outputs for four independent instruments and process them via external effects. This
led to a complicated voice management structure with reservation of hardware voices to the
outputs, parts priority, and an inability to steal voices between parts.
Later additions to the synthesizer engine have further complicated matters. However, it is
possible to create a working multi-arrangement by following several building rules. Here I will
attempt to explain them.
Rule 1 – Parts Priority for Voice Reserve! The V.Total parameter of an arrangement sets the
number of hardware voices that M will mark as reserved and locked by the DSP for each part.
However, this is not a guaranteed reservation, as one might assume. Part priority (1 → 2 → 3 →
4) plays a crucial role here; priority always determines voice allocation. For example, if you
reserve six voices for part 1, four for part 2, and two for part 3 on an 8-voice M, the actual
distribution will be six voices for part 1, but only two for part 2 and zero for part 3. On a
16-voice M, reservations are honored as requested. Therefore, rule one is to carefully manage
your voices, considering hardware limitations and part priority.
Rule 2 — Mind the PLAYMODE parameter for the part’s sound. It is makes no sence to set more than
1 voices for Monophonic sounds, the Voice Stealing does not matter too.
Rule 3 – Only the First Part Can Use Modern Mode! This is an important restriction related to
the limited memory resources of the M’s DSP. Remaining parts can be in classic or MVA modes, but
only the first part can utilize extended RAM for the “modern” (i.e., Microwave 2) wavetable
layout.
Rule 4 – Consequently, No Transition-Enabled Parts Can Mix with Part One in Modern Mode! Because
transition replay for “classic” (i.e., PPG 2.3 / Microwave 1) mode uses the same extended RAM as
the wavetables for “modern” mode, loading a part with transitions enabled will immediately
corrupt the wavetable data for modern mode!
Rule 5 – There is Only One Arpeggiator in the M. Loading or creating an arrangement with
multiple parts containing arpeggiator-enabled sounds is pointless; only one (first) part’s
arpeggiator will function.
Rule 6 – Cross-Parts VCF Lock. Regardless of which part is selected, if a part's LOCKVCF
parameter is set to On, it will follow the VCF behavior of another part. This parameter allows
all locked parts to track the controls of the currently selected locked part. For example, if
you have three parts and parts 1 and 3 have LOCKVCF = On while part 2 has LOCKVCF = Off,
adjusting the VCF section’s controls on part 1 will cause part 3 to follow the same settings
(i.e., lock to part 1), and vice versa. However, this will not affect part 2. Consequently,
editing part 2's VCF section will not influence these locked parts.
Rule 7 – Be Mindful of MIDI Filters. The M has a flexible set of MIDI filters capable of
blocking/passing certain messages like mod wheel, pitch bend, program/bank changes, aftertouch,
channel volume, and panorama. However, there is no CC filtering! Therefore, if you have two
parts in an arrangement on the same MIDI channel, both will respond to all CCs received on that
channel. And, don’t forget about the global MIDI filters of the M, which applied first!
Rule 8 – Voices Routed to Different AUX Outputs Still Appear on Main/Headphone Output. The M
does not exclude voices routed to different AUX outputs from the main output. In other words,
the main out is a sum of all Aux outputs (which is also true from the M’s schematic
perspective).
M.i.a.u.: LaBoum
  • #2.912
Also Multimode mit mehren Parts im Modern Mode geht nicht?
  • #2.914
Soweit ich es verstanden habe nein.
Wegen DSP Speicher, schade irgendwo dass die Geräte alle so auf Kante gestrickt sind, das wäre aus meiner Sicht ein Punkt für die Contra Liste wenn das nicht funktioniert. Wenn ich die Anleitung richtig verstanden hab' gibts auch Ringmod nur im Modern Mode?
M.i.a.u.: eusti
  • #2.915
Es ist ja nur der Multimode.
Als es noch keine VSTs gab und ich nur sehr wenige Synths hatte, war Multimode für mich noch Pflicht... Aber heute, mit heutigen Möglichkeiten der einfachen Aufnahme, was damals ja noch relativ aufwendig und nicht selbstverständlich war im Homrecording, und den heutigen Möglichkeiten mit VSTs zu ergänzen, ist MM doch eher hinderlich.
Wäre nur evtl Live interessant oder - ok, das wär nen Punkt: Fürs Layern
M.i.a.u.: Hamudi2000 und eusti
  • #2.917
Genau so ist es. Der Microwave hatte keinen Ringmodulator.
Ich wollte einfach nur sicher gehen, in anderen Bereichen wurde das Konzept des Originals ja schon sinnvoll erweitert, Wavetables pro Oszillator etc. Ohne Ringmod und/oder FM hätte mich der M wohl auch schon Ende der 90er nicht interessiert. Irgendwie schade weil man 'ne Menge klangliches potential verschenkt, speziell im Zusammenspiel mit Wavetables pro Oszillator.
  • #2.918
Im Modern Mode gibt es den Ringmod ja dann und Filter FM ist auch dabei.
  • #2.919
Schon Ende der 90er hab' ich nur Klangerzeuger geholt die mindestens 4fach multitibral waren und bis auf wenige Ausnahmen hat sich daran auch nicht all viel geändert, denn es wär es bei meiner Arbeitsweise eher kontraproduktiv wenn ich die eigenen Sounds mit den Funktionen die ich gerne nutze nur für einen Part einsetzen könnte. Ich nehme an die Erweiterungen auf 16 Stimmen liefert da keinen extra DSP für 'nen 2ten Modern Mode Part?
  • #2.920
Nein. Leider nicht - aber dennoch ist der M ja vierfach multitimbral. Nur halt nicht mit allen Features.
  • #2.921
Schade, dass Hermode Tuning nicht kommt, das konnte der MW1 damals und ich habe es sehr geschätzt. Zumindest ist Fingered Portamento endlich drin. Werde die neue Firmware heute Abend Mal installieren.
M.i.a.u.: qwave
  • #2.922
Leider ist das was, wofür Lizenzbeiträge nötig wären. Ist ja keine Waldorf Entwicklung. Ich habe das beim WAVE geliebt und vermisse das mehr als den Klang des WAVEs.
