Baloran The 3FX
Lauflicht
TR4ever
Laurent hat wieder was spannendes kreiert
Laut eigener Beschreibung auf Gearspace
Ist das u.a. das langersehnte TRIKO II.
Kommt wahlweise mit einer BT Fernsteuerung für die ganzen Parameter oder PC / Mac Editor / WiFi.
Zitat
ARCHITECTURE
The heart of The 3FX is built around three fully independent effect voices, each based on a coherent 8-module architecture:
  • Two delays per voice, usable in series or in parallel
  • An advanced, progressive feedback path up to controlled self-oscillation
  • An analog 12 dB/octave multimode VCF (BP, LP, HP) to optionally process the audio spectrum, both on the delay lines and on the dry signal
  • Independent levels for the dry signal and each delay line
  • A panorama control to position the voice within the stereo field.
The stereo input signal is distributed across the three voices: left / left + right / right. A mono signal is distributed across all three voices.
Each voice can be used alone, stacked or combined with the others to create textures impossible to achieve with a conventional delay.
M.i.a.u.: robworld
Krass. Nicht gratis, aber gefühlt fair für das gebotene. Habe schon mehr Kohle in solche Schwurbler gesteckt. Aber:
The six delay lines are based on a hybrid component: the PT2399, the most “analog" digital circuits : while the delay itself is generated by an ADC → memory → DAC delta-sigma chain, all surrounding processing remains analog. This component brings its own musicality and characteristic imperfections — which is why it is found in so many boutique effects pedals.
Stimmt schon. Das wäre eine ziemlich große Bedienoberfläche. :-)
Mir fehlen noch weitere Klangbeispiele für das genannte "abgefahrene".
