[iOS]: SENODE Graphical Music Sequencer
könnte interessant sein, bin aber vom Video nicht beeindruckt. Dort läuft der Sequenzer immer etwa gleich. Gleich langweilig zudem.
Gestern gab es ein Update, in dem nun auch die Wahrscheinlichkeit (Probability) pro Step eingestellt werden kann.
Uhlala:
https://senode.org/help_1.0.3.html
"MIDI Control Bindings
When activated, Senode will listen to all MIDI IN devices on the selected channel for control messages. These can be used to play the on-screen keyboard, control the synthesizer and clock. Furthermore, each emitter can be assigned MIDI bindings that will trigger actions."
Hier ein schönes Beispiel von ajp, wie man Senode mit einem anderen Sequencer (hier: Sonogrid) antriggern kann. Gefunden via dem discchord Blog.
View: https://youtu.be/VkiYMzqNi5g
Hier die Videobeschreibung:
"More of a demonstration or proof of concept than a real piece of music.
Senode is a personal favorite. It allows you to create musical graphs with branching and probabilities to allow you to have aleatoric processes but in a controlled manner. It can be as deterministic or random as you want it to be. However, it was hard to change things on the fly. It was more of a “set it and forget it” experience. Now, with the recent 1.0.3 update, it allows external control of the emitters and synth.
sonogrid is a very cool app for quickly exploring complex polyrhythms and polymeters. However, it doesn’t have a great provision for controlling pitch. It’s more of a straight rhythmic tool than a musical phrase generator.
I realized that sonogrid would be a wonderful way to control the stepping of the emitters in Senode; allowing you a quick and flexible way to traverse the graphs in a shifting and rhythmically interesting way. Giving you the flexibility of Senode’s musical networks with the easily adjustable rhythm programing of sonogrid.
The emitters in Senode are ultimately triggering iSEM, two instances of Zeeon and two instances of Mersenne, hosted in AUM with Eos 2 reverb and RE-1 Virtual Tape Machine."
ajp macht weiter.
Jetzt mit Self-Triggering:
View: https://youtu.be/PG_RVHyX_Dk
Unter dem Video steht:
"Very simple example of Senode triggering itself. Currently requires a roundtrip though another MIDI processing app as you cannot set the Senode MIDI input as an output. Make sure the "MIDI keyboard input channel" is set to something other than an emitter's output channel. If not, and you select that emitter, you will create a MIDI feedback loop and crash the app. Note 60 in the Sender graph emits a new token in the Receiver below. Note 61 clears the Receiver's graph. Note 62 emits a new token in Receiver 2. And note 63 clears that graph. Because of the routings and probabilities in the Sender graph, the triggering of the two receivers is variable. More sophisticated routings could allow song sections or pieces that evolve over time...."
Neues Update kam vor paar Tagen raus und dazu gab es auch ein kurzes Jam-Video.
Sebastian schreibt dazu:
„There's a new feature in Senode: the Arpeggiator Mode! Use the "Arp" and "Hold" modes to control the Emitter from MIDI input. The following setup was used in this video: Senode version 1.3.3 running as AUv3 in AUM host on iPad Mini 4. Synths from Nord Lead 4, Bass from Toraiz AS-1, Drums from Nord Modular G2. The AS-1 keyboard is controlling the Emitter.“
https://youtu.be/V8nA99-MKds
M.i.a.u.: robworld
