MAM MAP 1 midi arpeggiator [English]
Hi ,
i bought from ebay a MAM MAP 1 midi arpeggiator without manual but i thought is not problem.
I send a note to the midi in but nothing comes out on the midi out connected to my synth. I allready check many conbination but nothing.
Do has somebody a solution or this unit is broken?
Thanks in advance.
You have MIDI Clock = int ?
If you attached the MAP to the masterkeyboard, you must switch this to "local off"
1. Check the Midi-Channel your Keyboard is sending.
2. Set the MAP-1 Midi-In-Channel to this channel.
3. Check the MAP-1 Midi-Out-Channel and make sure it is set to the same channel your Sound-Module responds to.
Then it should work.
