bartleby
lieber nicht.
jemand namens hi-oja hat eine neue firmware mit allerlei zusatzfeatures für die ohnehin schon sehr gute volca drum veröffentlicht!
einen überblick gibts auf reddit, eine detailliertere anleitung und den code auf github.
die wichtigsten infos von der reddit-post:
und der obligatorische demo-clip:
New features
- ACCENT goes negative. -15 to +16 instead of 0 to +16. Ghost notes.
- MIDI velocity finally works. It was only ever driving the accent amount, which is exactly why it could make a note louder but never quieter. Now that accent reaches below zero, velocity covers the whole range, with 63 sitting right on your LEVEL knob setting.
- Elektron-style trig conditions on PROBABILITY. A-B (fires on the A-th bar of a B-bar cycle), 1st (first bar only, plus a NOT option), and FILL (active while holding the FILL FX in Touch FX, plus a NOT option).
- Touch FX on step 9-16: octave up/down, stutter, reverse, bit crush, wave guide full send, wave guide wet only, fill. Momentary, and you can hold several at once (up/down, send/wet and stutter/reverse are mutually exclusive for obvious reasons).
- SLICE gets sub-step patterns. 17 of them on the negative side, up to 4 subdivisions, so you can slice a step and only sound some of the pieces.
- FUNC + knob shows you the stored value instead of jumping to wherever the knob happens to be sitting.
- FUNC + SELECT cycles just the SRC waveform, instead of every SRC/MOD/EG combination.
- SWING goes negative too, -75 to +75.
- MUTE + step 7-16 clears motion one knob at a time, rather than the whole part or the whole pattern.
Fixes
The one worth calling out: SLICE has never divided the step evenly. Only 8 of the 16 values are actually correct, the rest fire extra hits at uneven spacing. That's been in the official firmware since release.
There are four smaller fixes too (a mismatched display string on motion undo, AMOUNT misbehaving with both layers selected, default markers going missing on negative values, and the TEMPO knob mapping in Full range). They're all written up on the repo.
