Psychic Modulation PulseCode - LoFi Software Drummie
H
hairmetal
Eine 80er LoFi Drummaschine von Psychic Modulation - den Machern von Phonec und den Freeware-Klassikern wie Minimal, Cubix oder Cerebrum.
Psychic Modulation has introduced PulseCode, a PCM Drum Machine that pays tribute to the lo-fi drum machine sounds from the late 1980s.
The sounds supplied with PulseCode have been resampled in 12 and 13-bit with vintage gear to stay true to the era. Each sound includes its own sampled 13-bit reverb layer, recorded from a vintage unit from the same time period.
Key Features:
  • 8 Drum Engines for loading up a variety of Sound Elements
  • Each Element is made up of 6 layers: Core, Grit, Hit, Body, Reverb and Noise
  • All layers of each Element have been sampled in 13-bit using vintage gear
  • Compressor, Filter and Saturation per Drum Engine
  • 64-step Pattern Sequencer with lane for each drum
  • Unique Pattern Offsets for creating variations to your patterns
  • Multi-parameter Accents for each step
  • Individual Speed and Length for each Sequence Lane (allows polyrhythms)
  • Adjustable Flams per step
  • Flow: controls the movement and rythmic flow of each sequence lane
  • Fracture: momentary buildups and breakdowns using snap-back controls
  • Drum Mixer with Multiple Outputs for each drum
  • Drum Fill Arpeggiator for automatic rolls, fills and more
  • Pitchbender & Modwheel integration of Fracture and Flow
  • Tight sync to Host tempo and position
  • MIDI Learn and automation of most parameters
  • Sub-presets: seperate load/save settings for Drum Engine and Sequencer
  • Double Click Parameter Reset
  • Intuitive patch management system
  • Default bank of 128 example presets
  • Includes several Sounds Elements to start out
  • More soundpacks will be available in the future
Pricing and Availability
PulseCode is available now for US $89.
December 6, 2018 synthheadSoftware Synthesizers & Samplers, Virtual MusiciansPsychic Modulation, Virtual Instruments
M.i.a.u.: Audiohead
Auf der Webseite haben gerade eine 25 % Rabattaktion. Am besten gleich mit dem beiden Soundsets dazu kaufen.
M.i.a.u.: subsoniq und Audiohead
Ähnliche Themen
R
Antworten
0
Aufrufe
870
Rastkovic
R
