was für ein Gerät DiGiCo-SD9
Im Anzeigentext ist ein Link zu der Digikonsole:
http://www.digico.biz/docs2/products/SD9.shtml
DiGiCo SD9: “It's off the hook.....”
The SD9 is a super-flexible, complete integrated system powered by Stealth Digital Processing and floating point Super FPGA technology. This lightweight, small-footprint console was designed with multiple applications in mind therefore is equally suited to life on the road or as part of any fixed installation, be it a theatre, conference centre, house of worship or school. The SD9 provides outstanding performance at a very competitive price point.
Gruss
7f_ff schrieb:
danke fein:
SD9 : Technical Specifications
General Specifications
Faders:: 24 x 100mm Touch-sensitive, motorised
Screens:: 1 x 15” (38cm) LCD high - resolution touch screen
Meters:: 24 x 8-Segment LED bargraph
Input Channels:: 48 Flexi channels Mono or Stereo
Busses:: 16 Flexi* (full processing**)
Solo Busses: 2 Stereo Busses
Matrix: 12 x 8 Matrix (additional to busses above)
Control Groups: 8, Selectable for VCA-style, Moving Fader, Mute Group
Graphic EQ: 16 x 32-band, Gain +/- 12dB
Internal FX: 8 Stereo FX Processors
Local I/O: 8 x Mic/Line I/O, 4 x AES/EBU: I/O (Mono)
MADI Interface: In / Out /
Optic Interface: Optocore (Optional Factory Fit Only)
MIDI Interface: In / Out / Thru
VGA Port: DB-15 Mini-Female (1024 x 768 Resolution)
USB Ports (3): USB 2
Light Connection (2): XLR3 1.2 – 12V
Ext Sync: Word Clock, MADI
Headphone: TRS Unbalanced / 8-600 Ohms 1/4 Inch Jack
GPI: 2 x 1/4” Jack TF
GPO: 2 x 1/4” Jack TF
SD9 Dimensions: 878mm (w) x 785mm (d) x 262mm (h)
SD9 Weight: 36Kg (105Kg with optional flightcase)
SD9 Flightcase: 1063mm (w) x 1131mm (h) x 472mm (d) (Optional):
SD9 Power: 90-264 VAC, 47-63Hz Auto Sensing. 208 watts, 232VA Requirements
Redundancy: Internal PSU x 2 (Optional)
Audio Specification
Sample Rate: 48kHz or 96kHz
Processing Delay: 2ms Typical @ 48k (48 Stereo Channels, Stage Input Through L-R Buss to Stage Output) 1.1ms @ 96k
Internal Processing: Up to 40-bit, Floating Point
A>D & D>A: 24-bit Converter Bit Depth
Frequency Response: +/- 0.6dB (20Hz – 20kHz)
THD: <0.05% @ Unity Gain,: 10dB Input @ 1kHz
Channel Seperation: Better Than 90dB: (40Hz – 15kHz)
Residual Output: <90dBu Typical
Noise: (20Hz - 20kHz)
Microphone Input: Better Than -126dB: Equivalent Noise
Maximum Output Level: +22dBu
Maximum Input Level: +22dBu
Processing Channel Specification
Input Channel
Name: User-Defined / Presets
Channel Selection: Mono / Stereo / Multi
Input Routing: Main & Alternate Input
Analogue Gain: -20 to +60dB
Phase: Normal / Reverse
Digital Trim: -40 to +40dB
Delay: >1 Sec (Coarse & Fine Control)
DiGiTuBe: Drive 0.01 - 50.0
Bias 0 - 6
LPF: 20 – 20kHz, 24dB/Oct
HPF: 20 – 20kHz, 24dB/Oct
Insert A: (Pre EQ/Dyn) On/Off
Equalisation: 4 Band EQ: Parametric or Dynamic (Low/Lowshelf, Lower-Mid/Lowshelf, Upper-Mid/
Hi Shelf, Hi/Hishelf)
On/Off
Freq; 20 – 20kHz
Gain; +/- 18dB
Q: 0.1 -20 (Parametric) / 0.10-0.85 (Shelf)
Dynamic EQ On/Off
Over/Under
Band On/Off
Threshold; -60 – 0dB
Attack; 500us – 100ms
Release; 10ms – 10s
Ratio; 1:1 – 50:1
Dynamics 1: Single or Multiband (3-Band)
Compressor: On/Off
Release; 10ms – 10s
Ratio; 1:1 – 50:1
Gain; 0 to +40dB with
Autogain Option
Link; Any Channel/Buss
Hi Crossover; 20Hz – 20kHz
Lo Crossover; 20Hz – 20kHz
Knee : Hard, Med, Soft
De-Esser: Threshold : 20us – 20ms
Release : 1ms – 100ms
Ratio : 1:1 – 50:1
Ess-Band : Listen On/Off
Ess-Band Filter Freq / Width: 20Hz – 20kHz
Dynamics 2: On/Off
Gate / Ducker: Threshold; -60 – 0dB
Attack; 50us – 100ms
Hold; 2ms – 2s
Release; 5ms – 5s
Range; 0 - 90dB
Key; Any Source
Key Listen
Freq/Width; 20 – 20kHz
Compressor: On/Off
Release; 10ms – 10s
Ratio; 1:1 – 50:1
Autogain Option
Link; Any Channel / Buss
S/C Source : Any Source
S/C Listen : On/Off
S/C Filter Freq/Width: 20Hz – 20kHz
Insert B: (Post EQ/Dyn) On/Off
EQ/Dyn order: EQ/Dyn or Dyn/EQ
Mute: Channel Mute / Hard Mute
Solo: Solo Buss 1 / Solo Buss 2 / Both, Auto Solo
Channel Safe: Input, EQ, Dyn, Aux, Pan, Fade/Mute, Inserts, Buss, Directs,
Full Safe
Output Routing: Buss, Insert A, Insert B, FX
Direct: On/Off, Pre-Mute / Pre-Fade / Post-Fade, Level +/- 18dB
Fader: 100mm Motorised Fader ∞ to +10dB
Aux / Group / Matrix Output
Digital Trim: -20 to +60dB
Delay: >1 Sec (Coarse & Fine control)
Bias 0 - 6
LPF: 20 – 20kHz, 24dB / Oct
HPF: 20 – 20kHz, 24dB / Oct
Equalisation: 4 Band Parametric or Dynamic
: Parametric Only
(Low/Lowshelf, Lower-Mid/Lowshelf, Upper-Mid/Hi Shelf, Hi/Hishelf)
On/Off
Freq; 20 – 20kHz
Gain; +/- 18dB
Dynamic EQ On/Off
Over/Under
Band On/Off
Release; 10ms – 10s
Ratio; 1:1 – 50:1
Dynamics 1: Single or Multiband (3-band)
Compressor: On/Off
Release; 10ms – 10s
Ratio; 1:1 – 50:1
Gain; 0 to +40dB
with Autogain Option
De-Esser: Threshold: 20us – 20ms
Release: 1ms – 100ms
Ratio: 1:1 – 50:1
Ess-Band: Listen On/Off
Ess-Band Filter Freq/Width: 20Hz – 20kHz
Dynamics 2: On/Off
Hold; 2ms – 2s
Release; 5ms – 5s
Range; 0 - 90dB
Key; Any Source
Key Listen
Compressor: On/Off
Release; 10ms – 10s
Ratio; 1:1 – 50:1
Gain; 0 to +40dB
S/C Source : Any source
S/C Listen : On/Off
EQ/Dyn Order: EQ/Dyn or Dyn/EQ
Channel Safe: Trim, EQ, Dyn, Fade/Mute, Inserts, Outputs, Full Safe
Output Routing: Outputs, Insert A, Insert B, FX
Fader: 100mm Motorised Fader ∞ to + 10dB
