Blofeld LFO monophon und freilaufend?
Sektor
Sektor
Brauche mal eure Hilfe, wie kriege ich beim Blofeld die LFOs monophon und freilaufend?
Wenn ich das Manual richtig verstehe soll doch "LFO Sync" genau das tun, dennoch startet der LFO bei jedem Tastenanschlag zufällig neu.
Will eigentlich nur eine langsam durchlaufende PWM auf der Sequence aber ich kriege das nicht gebacken, was hab ich übersehen?
Das liegt in der speziellen Architektur des Blofeld begründet. Wenn die VCA Envelope auf 0 geht, dann "vergisst" der Blofeld alles, was mit dieser Stimme/diesem Sound zu tun hat.
Hier ist es sehr schön erklärt:
https://www.gearslutz.com/board/showpost.php?p=9322447&postcount=4
Hier ist noch meine Antwort von anno Ofenrohr im Waldorf User-Forum:
> In polyphonic mode yes. In monophonic mode I would call it a bug. Free
> running LFO means free running right? I expect in monophonic mode that
> 1 LFO is used all the time, not depending on voice triggering, I mean
> *the same* LFO. As it is now it looks like with every new trigger,
> even in monophonic mode, a different LFO is used?
> Well, I guess you know what I mean
I know what you mean, well, at least I am quite sure about that.
Point is, in a synth as implemented with the same philosophy as the
Blofeld (I am sure, the other DSP based Waldorf synths behave the
same here, but I haven´t checked) there is nothing like *the same*
LFO.
The Blofeld is a multitimbral synth with dynamic voice allocation, even
the DSP and RAM ressources are dynamically allocated. So technically it
is quite different to anything in the league of an old style analog
polyphonic synth.
I am not saying it would not be possible to implement it in a way it
would behave like expected, but then a differen approach would be
needed.
In the Blofeld, as with other Waldorf synths, the voice allocation is
tied to the VCA envelope. When a voice is triggered, an instance of
that voice with all the needed settings is created and the calculation
starts. When the VCA envelope is reaching 0 in the end of the release
stage, calculation stops and all the ressources (DSP and RAM) are
released. The next triggered voice could be a differen sound with
different setting. There may be some fancy caching going on in the
background, only Stenz and Wolfram may know that...
There is no way that one voice hands over LFO status information to
another, since when the VCA envelope has reached 0 in the end of the
release stage, it is gone. The new voice is not in existence and there
is nothing implemented to let the LFO run further in the background.
Well, this is not fully true, there is the sync parameter in the LFOs.
This syncs the phase of the LFOs of a part together. This leads to
the workaround -> see below.
In a synth, where you have real hardware, or maybe even in a DSP VA
synth, with a fixed architecture you may have a LFO which continues
in the background, even if no voice is sounding.
For the Blofeld a Global LFO (per part maybe) would be needed, this
would eat up DSP ressources all the time.
> > And there is a workaround available. More on that later as well.
> THAT I am interested in
You have to use the LFO sync, that´s obvious. In addition you need
to create a continuous time stream, that is, make sure that at least
voice is allocated for the time you want a continous LFO pattern.
Option 1:
Have a soustained note, which is silent. That could be done with
clever use of modifiers or just an ADSR setting like 0 20 0 0 or
velocity. Press and hold one note, then play along your chords
or patters.
Option 2:
Have the notes overlapping, this is just setting the release to the
right timing. If needed you could use an ADSR setting like 0 20 1 127.
You have to prevent that the part gets deallocated. This works for the
arp patter in mono mode and works fine.
> @ Stefan: yes it is common: Jupiter 4 for instance, Korg PS3100,
> Jupiter 6, Memorymoog etc. etc. Polyphonic synths, 1 or 2 LFOs. But
> they run (in free running mode) independent from voice triggering.
The examples are not really valid, since those synths are quite limited
in architecture (not in sound or coolness). They only offer global LFOs.
They are not multitimbral, I think the JP6 offers two parts.
More valid synths would be Xpander, Andromeda, SunSyn, maybe OB-8 (here
the page 2 options offered a rate modulation of the LFOs)...
Danke erstmal für die Erklärung. :supi:
Workarounds muss ich ausprobieren, der einfachste, Option 1 mit der stillen Note per Velocity, funktioniert nicht wirklich, selbst bei Vel 0 > 100% Amp hört man die Note noch leise. Option 2 überlappende Noten per Release, da wird doch alles Klangbrei oder?
Mit den Modifiern blick ich noch nicht durch, hab keine Ahnung was ich damit anstellen kann und wie. Was ist mit "clever user" gemeint, wie erzeuge ich damit eine dauerhafte stille Note?
Bin für alle Tipps und Tricks dankbar, muss doch irgendwie möglich sein.
Das Herumprobieren kann ich Dir leider nicht abnehmen. Das Prinzip sollte klar sein. Du kannst z.B. mit ModSrc Maximum und negativem Ammount den VCA weiter schliessen. Sieh es einfach als von Waldorf angeregte Knobelaufgabe.
Mist das hab ich fast befürchtet... nee nur Spaß. :)
Bisschen doof finde ich es aber trotzdem das man für so Basics irgendwelche komplizierten Umwege nehmen muss, sofern diese dann auch funktionieren, zumal mit LFO Sync die Funktion ja eigentlich vorhanden ist.
Bisher funktioniert keiner der Umwege so wirklich, ich knobel mal weiter. :?
Danke Dir. :supi:
Die LFO Sync Funktion ist in erster Line dazu gedacht, bei mehreren Stimmen die LFOs wie einen einzelnen wirken zu lassen. Ein konstantes Durchlaufenlassen der LFOs (egal ob in Mono oder Poly) ist aus schon besagten Gründen nicht möglich. Einfachste Lösung: Nimm einen Minimoog oder etwas vergleichbares. Dort magst Du dann etwas anderes doof finden, z.B. dass er kein Midi hat oder nur eine Stimme kann :mrgreen:
Ich wollte nur lustig, lösungsorientiert und pragmatisch sein. Der Blofeld ist einfach so, wie er ist. Vielleicht bekommst Du es ja mit den Hinweisen und Probieren noch hin. Deinen Usecase hatten die Entwickler nicht im Blick und ja, es ist doof. Aber es hilft Dir halt auch nicht weiter.
Sorry dann hab ich das einfach in den falschen Hals gekriegt.
Danke nochmal.
