ja, man lernt dazu, auf die eine oder andere weise. ;)Dieser war allerdings angeblich so beabsichtigt.
@Mr. Roboto in dem Kontext meinte Tyskie wahrscheinlich, WAS soll denn der Design-Fehler sein?
Fehlende Abschwächer für die FX Returns?
Anscheinend gibts nun einen "Praga II", jedenfalls ist der bei Musicstore gelistet.Würde mich auch interessieren, finde den Praga nämlich ganz interessant.
Will hier nicht zuspamen.... auf der Webseite von xaoc gibts nur einen Praga, ohne 2, auch alle Bilder bei unterschiedlichen Händlern sind identisch, keine Ahnung, wie MS auf Praga II kommt...?Anscheinend gibts nun einen "Praga II", jedenfalls ist der bei Musicstore gelistet.
“Mr. Roboto on Muffwiggler“ schrieb:I do have this module for two weeks now and I really like it. Unfortunately I do have a serious issue with distortion on the returns.
Today I found some time to check the issue in some more detail, using lots of different module combinations and scenarios.
Unfortunately it looks like the return signal is very distorted most of the time.
The input signal is fine, no clipping indication. Also the send signal is fine as all my FX-modules did not indicate any clipping. Unfortunately the return signal on the mixer sum is distorted most of the time (and it never is related to the output level of the FX). The only way to "fix" this is to lower the send level (using the knob) to a ridiculous low level. Then there is no distortion on the return but obviously the input level for the FX-module is unnecessary low.
This scenario is valid for all four channels (for testing I was only using one single channel at a time).
Am I doing something wrong here? Anybody having similiar issues? Possibly a defect of my module?
„Reply from xaoc_tech on Muffwiggler“ schrieb:Please, note, that there is no onboard attenuation of the return inputs. These signals are mixed at 0dB gain with everything from the input channels (that usually are significantly attenuated, because 0dB setting is near max of the attenuators). If you put a full range signal into returns, there is no headroom left for adding anything else, and distortion may occur. In order to avoid this, and balance the amount of the FX, you need to use some external attenuator. The Hrad expander will offer attenuation of returns, among other functions.
If it didn't solve your problem, please contact our support to diagnose it in more detail.
