The Stackcables have been tested in the lab for a long period as well as by our beta testers and had no issues found with them. We tested them with modules from all manufacturers.
The signs you might see beneath the jacks could have been caused by other plugs too, scratching the surface of the solder mask. That is not damage, that is use. It seems that the clearance on those specific jacks is very tight and tolerance is an issue. It is btw. common to leave hole in the PCB design exactly for this purpose when using jacks that gets the plug tip with such proximity to the surface of the PCB.
The Stackcables are made with precise tooling to meet the spec and the little nib is part of the manufacturing process and not a defect. But since this nib do touch the surface of the pcb on some of these modules mention we will take care of it and make sure we remove it completely after production. Overall I'm happy that this came up which allows us to fine tune the design and make the product work even better.
Nuuji had suggested to sand the little nib and had show how it looks before and after, I think this is a good idea for now and very easy to do. That should solve the problem immediately and keep us all back rolling.
I can only say that I'm sorry if anyone feel that his modules got damaged and assure you that we will take care of the little nib in our next production run.
tomcat schrieb:Hat die schon wer im Einsatz und Erfahrungen damit? Will mir gleich einen grösseren Satz zulegen, wäre also blöd wenn ich nachher auf Probleme draufkommen würde. ;)
http://www.tiptopaudio.com/stack.php
Q960 schrieb:Feedback
Ich benutze die Stackcabel auch schon ein paar Jahre und muß sagen das von ca 20 Stück 2-3 nicht mehr richtig funktioniere, die haben wackler.
Auch kann ich nur davon abraten sie mit Doepfer Kabeln zu kombinieren.
Ich habe das Gefühl das die Stackcabel buchsen dann irgendwie ausleihern und nach einiger Zeit nicht mehr gut funktionieren.
Leroy schrieb:Ich hab 2 und ich mag die gerne. Aber im Verhältnis schon teuer, 10 pro Kabel summiert sich ganz schön. Was empfiehlst du? Brauche destens10 Stück. Von Thema sssnake würde mir abgeraten, der Preis lockt natürlich...
Wieviel am jeweiligen Zielmodul ankommt hängt von der Eingangsschaltung beider(!) Zielmodule und von der Ausgangsschaltung des Quellmoduls (also da wo Du zwei Kabel stackst) ab. Wenn die Eingangsschaltungen beider Zielmodule die gleiche Last für den Ausgang der Quelle erzeugen, dann kommt bei beiden gleich viel an. Wenn eine der beiden Eingangsschaltungen "attraktiver" als die des anderen Moduls ist, dann wird mehr in das "attraktivere" Modul fließen.Kommt dann tatsächlich an beiden Kabelenden die gleiche Signalstärke (Volt) an?
Da wird normalerweise nichts kaputt gehen, aber die gegenseitige Beeinflussung ist hier ähnlich gelagert wie beim umgekehrten Fall, nur dass die Einflussnahme, meist noch größer ist.Und noch wichtiger, darf ich mittels eines Stackcables auch zwei Signale in einen Eingang zusammenführen?
Probieren kannst Du das sicher. Ich würde behaupten, dass es unter den geschätzt 2000 heute verfügbaren Modulen 5 (wiederum geschätzt) geben mag, die irgendeine Kombination mit etwas anderem nicht mögen. Hier sind vorallem digitale Anschlüsse (Clocks, Trigger) potentiell gefährdet. Garantieren kann Dir also niemand was, aber das Risiko was kaputt zu machen ist sehr, sehr gering.Oder kann ich theoretisch beliebig viele Stackcables ineinander stecken und für sämtliche Ein-/Ausgänge gedankenlos ausprobieren?
Danke für die Antwort!Wieviel am jeweiligen Zielmodul ankommt hängt von der Eingangsschaltung beider(!) Zielmodule und von der Ausgangsschaltung des Quellmoduls (also da wo Du zwei Kabel stackst) ab. Wenn die Eingangsschaltungen beider Zielmodule die gleiche Last für den Ausgang der Quelle erzeugen, dann kommt bei beiden gleich viel an. Wenn eine der beiden Eingangsschaltungen "attraktiver" als die des anderen Moduls ist, dann wird mehr in das "attraktivere" Modul fließen.
Sagen wir so es kann dazu führen. Wenn man VCOs unterschiedlicher Hersteller im Einsatz hat, dann ist man auf der sichereren Seite, wenn man ein sogenanntes "Buffered Multiple" im System hat.Das bedeutet, bei ungleichen Eingangsschaltungen führt die ungleiche Signalstärke dann auch zu anderen Ergebnissen? Bei CV z.B. zu anderen Tonhöhen?
