Gerade eben gefunden, ohne es mir komplett angeschaut zu haben:
Ich glaube nicht das es hier einfacher geht wie zb beim Analog keysNe Frage zum speichern:kann ich einen editierten SOUND (nicht Pattern) auch schnell drüber speichern ohne dafür erst wieder den Soundbrowser zu öffnen?Das nervt,weil natürlich wählt er dann erstmal nen freien Slot,der unter Umständen weit weg ist,Naming Menü,Tagmenü etc.
Hab meinen grad abgegeben
List of changes from OS 1.21 to 1.30
Improvements
The Digitone/Digitone Keys now supports class compliant audio over USB.
Added a new step recording mode for the sequencer. Press [RECORD] + [STOP] to enter STEP RECORDING mode.
Added play modes: POLY, POLY (MONO LFO), MONO, MONO LEGATO. MONO and MONO LEGATO modes also have note priority options.
Added the possibility to select all unused Sounds in the project's Sound pool.
Added the functionality to preview a single step (including its parameter locks) on the sequencer for both audio and MIDI tracks by pressing [TRIG] + [YES]
Added a new TRIG PROBABILITY parameter.
Added a new trig condition (100%) to the X% range.
Added the functionality to control Voice Reuse per track. It sets if the same note played twice should reuse the same voice, or cycle to use another free voice (default setting).
[Digitone Keys] Added the possibility to select if the Pitch Bend and Mod wheel should affect only the currently selected track or all tracks simultaneously.
Separated TRANSPORT from CLOCK send and receive settings in the SYNC menu.
[Digitone Keys] Added the possibility to select track in the Control In modulation setup.
Added snap values for the LEN parameter on the TRIG page.
Added snap values for the LENGTH parameter when pressing [FUNC] + [UP]/[DOWN] in the SCALE menu.
Restructured the SETTINGS menu.
Moved the Audio Routing options for USB Audio to the SETTINGS > AUDIO ROUTING menu.
Active notes originating from the [TRIG] keys are no longer automatically note off:ed when entering GRID RECORDING mode.
[Digitone Keys] Changed so that the screen reflects the assigned control knob CC when pressing [USER MODE].
Improved resolution of modulation depth from Pitch Bend, Modulation Wheel, Aftertouch, Velocity, Breath Control, Control Input A/B.
Improved graphics for the algorithm on SYN1 and SYN2 pages. It now indicates the operators affected by parameter changes.
Prevented MIDI feedback problems that could occur when pressing [STOP] twice.
The user is now prompted to select SysEx transfer interface when sending project backups, and USB+MIDI is selected.
Added support for OS upgrades using Elektron Transfers Drop page.
Improved the visual feedback from the [REC] key in LIVE RECORDING mode. The [REC] key now blinks per beat independent of the sequencer position.
Changed the MIDI port name to read "Elektron Digitone" over USB.
It is now possible to live record Sound pool Sounds from the Sound Manager or Sound Browser.
Bug fixes
Receiving pitch bend on multiple tracks sharing the same MIDI channel, did not work correctly.
Performing a track mute always applied GLOBAL mutes when in GRID RECORDING mode even if the most recently used MUTE mode was PATTERN mute.
Certain combinations of SCALE settings on the MIDI tracks could sometimes lead to that the first step of a pattern being played once more when changing patterns.
Trig Conditions did not function correctly under some circumstances when using SCALE PER TRACK.
The first slot in every modulation settings could disappear after rebooting the device.
Sound locks affected the display of the parameters on the FX pages even though these parameters are not part of a Sound.
For various reasons, notes could sometimes hang.
When using the TRACK NOTE method in GRID RECORDING mode, trigs could in some cases get added to the wrong track.
Decreased encoder sensitivity for some parameters to make it easier to select specific parameter values.
An arpeggiated Sound played manually had its arpeggio interrupted when the sequencer played a note trig on the same track.
The sequencer started after preroll, even if it was paused before the end of the preroll.
The dotted values for the delays TIME parameter were displayed incorrectly.
Character selection using the LEVEL/DATA knob in the pop-up naming window did not behave correctly.
Pressing and holding FUNC, and then turning the knob for the DELAY TIME parameter now makes the parameter snap to on-beat values.
The sequencer could be out of sync when using scale per track if the previously set scale per pattern value was not 1x.
The reload function of the FX parameter pages did not work correctly, even though the RELOAD PAGE message appeared.
The revert CONTROL ALL function only reverted the active page.
Parameters could get inverted when modulated with pitch bend at -64.
Pressing [FUNC] + [UP]/[DOWN] to set the TRACK LENGTH in increments of 16 in the SCALE Menu did not work.
Trigs with PRE and NOT PRE conditions did not trigger correctly the first time a pattern played.
In some cases, it was possible to place trigs outside the range of the current track.
When changing between patterns that had different AUDIO ROUTING settings, the new pattern inherited the routing of the previous pattern instead of loading its own settings.
It was not possible to clear TRACK LEVEL, MIX LEVEL, or PATTERN VOUME by pressing ENCODER + [NO].
It was not possible to randomize or reload FX pages on MIDI tracks.
A fixed (non-synced) BPM MULT setting on one LFO could, in some circumstances, affect the tempo of other LFOs.
Aftertouch modulation cut off Pitch bend modulation when an external MIDI controller was used to interact with Overbridge over USB MIDI.
All settings and empty patterns in the factory project were not cleared when performing a factory reset.
When receiving external MIDI notes in LIVE RECORDING mode, only the first played note's velocity in a chord was recorded. The following notes instead got the default velocity parameter value.
Parameter locking LFO values for MIDI tracks had no effect.
The device did not listen to the MIDI CC All Notes Off.
Als Anhänger der RTFM-Religion fällt mir nur ein Tipp dazu ein....
der da wäre …?
Sorry!Was meinst Du, womit ich die letzte Stunde verbracht habe?
Geht also nicht.
Vielen Dank für den sehr hilfreichen Tip.
Ich hab den Digitone Keys und mit dem geht's nicht. Das macht tatsächlich nur der Analog Four so. Dafür hat man ja eigene Miditracks. Dafür kann man aber externes Gerät komplett per Midi steuern.Guten Tag,
kann mir hier vielleicht jemand sagen, wie ich die 4 internen Tracks über Midi aus dem Digitone heraus bekomme (außer sie vorher auf nen Midi Track zu kopieren)?
Vielen Dank!
Ja, vermutlich möchte er die interne Sequencer Ausgabe in einer DAW aufzeichnen. Das geht halt net. Nur auf den Miditracks. Und ich weiß gar nicht ob man interne Sequencer Pattern auf eine Midi Spur kopieren kann...hab das noch nie versucht. Geht das überhaupt?Ach je.... ich glaube ich habe das mit "4 interne nicht auf die Miditracks kopieren" nicht richtig verstanden....
