Elektron Machinedrum: Neue inoffizielle Firmware (X.10)
stuartm
Das ChangeLog dazu, die letzte offizielle von Elektron war 1.63:
* Machinedrum OS 1.71 Release information *
This is an unofficial firmware release and is not
affiliated or endorsed by Elektron.
How to upgrade:
* Hold down the [FUNCTION] button while powering up.
* This should take you to the Machinedrum boot menu.
* Enter the "MIDI Upgrade" mode by pressing [5 LT].
* Send either the SYSEX or the MIDI firmware file to the Machinedrum.
To transfer the SYSEX file we recommend using C6 − Sysex Tool by Elektron.
After starting the transfer you should see the trig LED’s lighting
up, and when the update is done the unit should reset itself and
boot the new OS.
Detailed instructions are available in the EARLY STARTUP MENU chapter
in the latest Machinedrum users manual.
PLEASE BACKUP ALL USER DATA VIA SYSEX BEFORE UPGRADING.
BETTER SAFE THAN SORRY.
The [redacted] development team
List of changes from Machinedrum SPS-1 OS 1.70 to 1.71
Updates
A hidden machine, TRX-S2, is now available. The machine can be accessed
in the TRX category, below TRX-B2.
Sample slot query command 0x34 now returns information for all ROM slots.
MIDI Byte | Purpose
(SYSEX init)|
$70 | Status query.
$34 | Sample slots query. The slot id param is removed.
$f7 |
The response message contains n, the number of available slots (30 for MKI and
48 for MKII), followed by n 5-byte slot information.
MIDI Byte | Purpose
(SYSEX init)|
$72 | Status response.
$34 | Sample slots query response.
%0aaaaaa | n, the number of available slots.
... | ROM-01, 4 bytes ASCII name (7-bit)...
%000000b | ... b=0 if slot is empty
... | ROM-02, 4 bytes ASCII name (7-bit)...
$f7 |
Bug fixes
SYSEX kit dump receive bug:
Fixed regression when storing kits to a specific slot.
List of changes from Machinedrum SPS-1 OS 1.63 to 1.70
Updates
Updates to the MD's SYSEX specification are listed below.
SYSEX kit request:
MIDI Byte | Purpose
(SYSEX init)|
$53 | Kit dump request ID
%0aaaaaaa | Send kit number %0aaaaaa ( 0 to 63 )
If kit number >= 64, the current unsaved kit data (workspace)
is sent.
SYSEX kit sysex dump:
MIDI Byte | Purpose
(SYSEX init)|
$52 | Kit dump ID
$04 | Version
%0aaaaaaa | Kit originalPosition %0aaaaaa ( 0 to 63 )
If kit number >= 64, the kit is copied to the current
SYSEX status request:
MIDI Byte | Purpose
(SYSEX init)|
$70 | Status for parameter %aaaaaa (see list below)
%00aaaaaa |
%0bbbbbbb | <Extended paramater>
$f7 |
0x01 Current global slot (0 to 7)
0x02 Current kit number (0 to 63)
0x04 Current pattern number (A1=0, A2=1, ... B1=16, ...)
0x08 Current song number (0 to 31)
0x10 Current sequencer mode (pattern mode=0, song mode=1)
0x20 Current lock mode (classic=0, extended=1)
<Extended functionality>
0x30 Firmware capabilities:
- Returns a multibyte bitmask indicating available firmware features
0x31 Enable/disable Trigger Interface mode:
- bbbbbbb = 0x01 | Enable
- bbbbbbb = 0x00 | Disable
0x32 Enable/disable Track Select mode:
0x33 Query mute state
0x34 Query sample slot:
- bbbbbbb | Slot Number
Trig Interface (TI) Response:
When the TI is enabled, the Machinedrum will send a SYSEX message upon
trig key press, without triggering internal sounds.
This can be used to extend the GUI of an attached MIDI devices.
MIDI Byte | Purpose
(Universal
SYSEX) | Realtime Universal System Exclusive Header
$0D | Status for parameter %aaaaaa (see list below)
%0aaaaaaa | if (%0aaaaaaa >= 64) Trig on
| else { Trig off }
$f7 |
Track Select Response:
When Track Select is enabled, the Machinedrum will send a SYSEX message
when the current track is changed.
MIDI Byte | Purpose
(Universal
$0E | Status for parameter %aaaaaa (see list below)
%000aaaa | Current MD track.
$f7 |
Bug fixes
SDS Lockup bug:
Sending samples to the MD could cause the buttons and encoders
to become unresponsive, requiring a restart.
Hmm.... hidden machine ? War die vorher schon drin oder ist die erst ergänzt worden? Schon cool. Aber mehr wäre jetzt für mich gar nicht interessant ? Schon jemand probiert?
Das machen die Leute hinter der Megacommand, die Weiterentwicklung der Minicommand von Ruin&wesen, spannendes Projekt.
Das hatte ich schon mitbekommen. Aber hat es denn schon jemand probiert? Drüben im Elektronauten-Forum hoffen ja einige auf ein paar Ergänzungen für den Sequenzer, was schon geil wäre. Aber abwarten. Da stand auch dass eventuell ein Downgrade der Firmware nicht möglich sei. Deshalb bin ich vorsichtig.
Auf Elektronauts gibts einen Thread zu der Firmware, ist auch recht aktiv.
Der Entwickler schreibt da auch.
M.i.a.u.: Orphu
Ich habe es installiert, alles bestens.
M.i.a.u.: Orphu und verstaerker
Update kommt^^ GND Sine Pro, Saw, Pulse.
GND-SN-PRO = 4x GND-SN
One machine, 4 voices, so you’ll get up to 64 OSCs!
Other models, GND-PU and GND-SW, get 3 OSCs, because we implement variable waveform (SKEW for SAW, and WIDTH for PULSE) and there’s got to be a knob for it
SKEW: allows smooth transition between SAW and TRI
https://m.youtube.com/watch?v=6Ci_QPOyeu4&feature=youtu.be
Sounds kommen alle aus der MD.
  • Hmm
M.i.a.u.: Orphu, lowcust, stuartm und eine weitere Person
M.i.a.u.: Slushyluv und Hans Olo
Sehr cool was die Jungs da geleistet haben. Hab es gestern auf meine MD MK2 nonUW gespielt. Hat eine Ewigkeit gedauert aber die MD ist ohne zu mukken gestartet. Einwandfrei. Die neuen Synth-Maschinen sind sicherlich eine Bereicherung. Sogar Chords sind möglich. Fetzt.
M.i.a.u.: Green Dino
was gibt es dort zu sehen? (Insta ist hier gesperrt)
Ein altenatives OS mit 3 neuen Machines mit vielen OSCS
    • Unofficial Machinedrum x.04 firmware is released! Featuring TONAL pitch control, new LFO shapes, new GND machines (saw, square, noise), trig preview, multiple track trig n more! Turns MD into a LYRA8 type machine in my perspective... Massive!
      Many thanks to JustinValer & V-Yadli for their hard work, which goes beyond machine's design. What a way to push forward! Firmware download can be found on Elektronauts!
      #machinedrum
      #x.04
      #ambient
      #lyra8
      #customfirmware
      #modding
      #soundscape
      #machinedrumuwmkii
      1 Tag
This new unofficial firmware adds numerous new creative features to the MachineDrum. First, the GND section got an upgrade with three new machines, each with relative pitches for additional oscillators and unison.
  • GND-SN-PRO is a compatible model for GND-SN, featuring up to 4 sine OSCs.
  • GND-SW is a sawtooth/triangle machine with up to 3 variable waveform OSCs.
  • GND-PU is a pulse wave machine with an adjustable duty ratio and up to 3 OSCs.
Then several machines received a tuning functionality: GND: SN SW PU, TRX: BD SD XT RS CB CL XC B2 S2 & EFM: BD SD XT CP RS CB HH CY. The Edit Kit menu also got an update to incorporate the tuning setting per track. Then, the TRX-S2 decay and noise parameter sensitivity has been improved. Also, it adds new LFO shapes to the MachineDrum including sine, rev-linear, rev-exp, notch, and step.
sagt Tom.
      #machinedrum
      #x.04
      #ambient
      #lyra8
      #customfirmware
      #modding
      #soundscape
      #machinedrumuwmkii
      1 Tag
sagt Tom.
also .. das ist ja das selbe was Green Dino schon postet .. dachte es geht nochmal um was Anderes
Ich habe das neue OS soeben via MIDIOX aufgespielt - lief problemlos, allerdings konnte man dabei einige Tassen Kaffee kochen gehen. Bin mal auf die neuen machines gespannt - das wird dann aber wahrscheinlich erst am Wochenende. In jedem Fall Hut ab vor den beiden Entwicklern, da steckt sicherlich einiges an Arbeit drin.
ich find das ganz schön krass ... da liegt doch sicher nur compilter code vor ..
zur Info:
Es gibt eine neue inoffizielle Firmware für die Machinedrum, neue Machines, Solo, tonales Tuning der TRX und EFM Machines und vieles mehr.
Changelog:
Updates
** Three new GND machines are now available. **
GND-PU is a pulse wave machine with adjustable duty ratio and up to 3 OSCs.
All new GND machines have relative pitches for additional OSCs, and UNISON
capability.
** The following machines gain a new tuning setting: **
GND: SN SW PU
The "EDIT KIT" menu is updated to incorporate the tuning setting per-track. In
addition to SYNTH, MACHINE and RELATE, one can use
keys to
access the tonality setting in the right upper corner of the menu, and toggle
between "DEFAULT" and "TONAL" with [UP]/[DOWN] keys.
"TONAL" tuning implements a quater-tone equal tempered tuning scale across the PTCH
parameter of selected machines. When enabled, TONAL has the added benefit of
increasing the machine's maximum tuning range.
** Machinedrum Kit version increased to 64.1 **
Kit dumps from X.04 firmware will be tagged with version 64 revision 1.
Machinedrums running an older firmware will not support these dumps indicated by
a "SYSEX ERROR 4" message.
Changes from Kit Version 4.1 to 64.1:
When set, bit 17 of uint32_t model indicates the model tuning is tonal.
** TRX-S2 decay and noise parameters sensitivity has been improved" **
** New LFO shapes are available: SINE, REV-LINEAR, REV-EXP, NOTCH and STEP. **
** Trigger groups can be arbitrarily chained. **
For example, you can set track 1 to trigger track 2 and track 2 to trigger
track 3, and thus track 1 will trigger all three tracks.
** Triggers can now be previewed in step editing mode. **
Hold a P-locked trigger and press [ENTER] will preview the P-locked sound.
** Solo Mode **
From the mute menu, you can now toggle between MUTE/SOLO mode with [ENTER].
The toggle also functions as a mute inversion tool, so that you can switch
between two playback states.
** Mute/solo actions are now transmitted via MIDI. **
** Trig Interface (TI) Extended Response: **
The TI has been extended to respond to press and release of some command keys.​
M.i.a.u.: offebaescher
wie grass ist das dennn ?!!??!
Geht das auch bei nicht UW ? so wie ich es verstehe ja ?
Hatte nie eine MD, aber das solche Updates kommen ist wirklich sehr cool. Wenn Dataline das postet ist diese Entwicklung offiziell abgesegnet? Ich denke doch schon, dass die den unkompellierten Code haben müssen, oder?
Jetzt bitte am Cycles (mein einziges Elektron Gerät) noch ein paar schöne Updates...
M.i.a.u.: Orphu
also als hesse spricht man krass .. grass aus .. zumindest hier ;-)
"graß" ist wieder was anderes
aber echt wie geil ist das. höchsten Respekt für das Projekt ! Ich liebe sowas !
Hatte er den Quellcode oder reverse engineering ?
  • #28
Die neuen GND Machines können ja mal richtig geil klingen und schmeicheln dem Minimal Sound der Machinedrum. Die Tonal Option hätte Elektron schon lange bringen können, damit lässt sich die Kiste viel intuitiver bedienen und erspart einem viel Kopfrechnen 🧮
Wäre toll, wenn einige Funktionen der Megacommand noch Platz im OS finden; conditional trigger und Microtuning...
M.i.a.u.: Orphu
