Adapterkabel gesucht: DVI-D Duallink auf Displayport
Könnte folgendes Tool hilfreich sein :dunno: wurde in 'nem Thread bei 'nem ähnlichen Problem empfohlen.
SwitchResX is the most advanced tool for Apple computers to take control of any screen connected to the Mac. No matter whether a MacBook Screen, an external monitor, a Retina display, a TV set or a beamer: SwitchResX can handle them all – if you want, straight from the menubar, a contextual menu or both. It's that easy!
Preference Pane And MoreWhen installed, SwitchResX sits in the Preference Panes and can be activated like any other of those helpers. SwitchResX pops open in a separate window for easy access of its’ vast amount of functions, that outrun Apples inbuilt Monitor preference pane easily.
Ultimate ControlWith SwitchResX you can keep control of your screen resolution and the way, every single app displays its content on your screen – or screens! Because SwitchResX can of course handle more than one screen totally individually, it gives you all the freedom and flexibility you need at any time.
Drill Down Into Details​
On top, SwitchResX includes a huge amount of additional functions, like
• Saving desktop layouts to get everything back into position right the moment, you jump back to a certain resolution
• Disable or activate screens on demand, for example to use a Macbook in clamshell mode
• Link screens to specific events like Key shortcuts, Applescript, Application launches and more
• Create and enable new custom resolutions to adapt to any available screen, including screens inbuilt into cars
• Rename resolutions to regular and useful terms like Gaming, Documents, Graphics, Presentation, TV etc.
• Arrange desktop items on a much finer grid than Apple' standard settings
• Keep a record of any change in screen setting automatically
DVI/HDMI Verbindungen sind Netzwerke, das Kabel selbst unterstützt eigentlich nur Geschwindigkeiten, keine Auflösungen.
was auch immer du damit sagen willst, aber bei jedem kabel steht dabei, welche maximale auflösung es unterstützt.
und "unterstützen" bedeutet in diesem zusammenhang, dass der hersteller garantiert, dass es bis zu dieser auflösung keine kommunikationsprobleme, keine verzerrungen und kein ghosting gibt, sondern der monitor erkannt wird und das bild halbwegs gut ist.
bei VGA und DVI-A muss man daher, ganz grob gesagt, bei höhen über 1024 und kabellängen über 2 metern 50 euro ausgeben, da billigere nicht funktionieren.
bei rein digitalen bildsignalen ergibt sich die auflösung dann aus der bandbreite, wobei man aber bei der bittiefe von 8 oder 10 bit eh nix ändern kann. :)
2k ist eigentlich nur wenig aussagekräftig, weil das ja auch noch von der Bildwiederholfrequenz abhängig ist und genau da liegt das Problem, eigentlich müsste man Gbits/s angeben, womit dann wiederum kein Käufer was anfangen kann.
da steht allerdings deutlich dabei, dass es nur 2k unterstützt. :)
Habe ich etwas übersehen?
Bevor ich das falsche Kabel bestelle, kannst du mir die Stelle aus Summas link noch mal genau zitieren, die du meinst?
Ich lese da folgendes:
"...Auflösungen von DVI auf HDMI bis zu 4K/60 Hz (3860x1920 Pixel), bei Datenraten von bis zu 18,2 Gigabit/s.
Umgekehrt, von HDMI auf DVI, erhalten Sie volle FullHD-Auflösung bei einer Datenrate von 10,2 Gigabit/s...."
Mich interessiert die Richtung DVI auf HDMI, nicht umgekehrt.
Und damit wäre dieses Kabel für mein Vorhaben genau das richtige.
Hier noch ein kurzer Abschlussbericht:
Bestellt wurden dieses Kabel und dieser Adapter (in Verbindung mit dem beim Display mitgelieferten HDMI Kabel).
Beim MDP Adapter bleibt es weiterhin bei 1920 x 1080 bei 60Hz.
Beim DVI Kabel wird zwar 2560 x 1440 zur Auswahl angeboten, beim Wechsel dorthin bleibt das Display jedoch schwarz.
Das bringt mich zu der Annahme, dass das Display diese Auflösung nicht interpolieren kann.
(Zur Erinnerung: Native Auflösung 4K 3840 x 2160 (DisplayPort: 60 Hz, HDMI: 60 Hz)
Noch etwas zu SwitchRes: damit lassen sich Customer Resolutions erzwingen. Ich kann praktisch jede beliebige Auflösung einstellen, darunter eben auch 2560 x 1440. Das Ergebnis ist jedoch völlig unbrauchbar, sprich: es erscheint zwar ein Bild, aber lesbar ist dort nichts mehr.
Ich habe zum Schluß eine Anfrage an Dell geschickt, ob das S3221QS WQHD darstellen kann. Die Antwort werde ich hier posten.
Noch am Rande erwähnt:
Während des Testens ist mir, kurz nacheinander, erst das Netzteil meines Arbeitsrechners (MacPros 5,1) und ein paar Tage später das Netzteil des backup Rechners (MacPros 4,1) gestorben. Jetzt habe ich erstmal ganz andere Sorgen. Dazu aber ggf. ein gesonderter Thread
Danke erstmal an alle bis hierhin, für alle hilfreichen Gedanken!
Similar threads
Antworten
12
Aufrufe
2K
telefonhoerer
telefonhoerer
