Using data from nearly 30000 Patternarium presets, we trained a neural network to create stellar-sounding beats and to spread them on a 2-dimensional map. We then converted this neural network into a Javascript for Microtonic that lets you drag eight points around this map to morph and combine sounds and rhythms into your own unique creations.
BeatSpace is included in the latest version of the Official Microtonic Scripts installer, available for registered Microtonic users at https://soniccharge.com/download. Simply run the installer and use the little puzzle button in Microtonic to open it.
We hope you will have as much fun with this tool as we had creating it.
/ Magnus & Fredrik Lidström
Additional info:
Each point is a drum channel in Microtonic.
There are 1000 * 1000 unique points.
Every point contains sound and pattern data for one channel.
Together, they form a constellation, an eight-channel beat.
You can right-click to copy and paste constellations. Paste your coolest findings here.
The dice randomizes the eight points.
Alt-click for solo, shift for fine, and command/control-click for mute/unmute, as it says in the UI
You can undo/redo with the standard Microtonic undo/redo buttons.
If you change a channel in Microtonic and the resulting sound differs from the neural network's output, the point will be marked with an X, and its coordinate will be struck through. Touching the point again will reset the channel to the neural network's output.
You can also right-click and choose "Enable All Points" to remove all X's.
Bright areas in the spacy background represent existing Patternarium data, while dark areas represent points in the map that have been extrapolated from this data. The colors indicate how the network has grouped different types of sounds and pattern data.
müsste ehh ne MKII werden denk ich mal, .....incl. Neu kaufen müssen.Zwecks Upgrade... ist so ein gemischtes Gefühl, ob man hier dann nicht ein fast perfektes Plugin so verändert,
So, ich habe grade mal geupdatet und das neue Beat Space ausprobiert. Wie geil ist das denn bitte? Einfach würfeln und es spuckt immer wieder neue richtig geile Sounds und Pattern aus, da ist richtig geiles Zeug dabei. Ein paar Sachen habe ich mir gleich abgespeichert und eine Bassdrum direkt als Wave exportiert.
Geil.
ollo hat die random funktion an einem synthesizer entdeckt
der skinswitcher ist auch neu oder? das war doch mal recht "kompliziert" so'n skin auszutauschen..da hat es mir doch glatt die Sprache verschlagen, und das nach ~20 Jahren Toniqnutzung.
notiere:der skinswitcher ist auch neu oder? das war doch mal recht "kompliziert" so'n skin auszutauschen
happy wife, happy life...Hab gerade Mecker von meiner Frau bekommen....
Und nur weil der Microtonic alt ist, ist er ja nicht schlecht. Eine aktuelle Version würde sich aber bestimmt gut machen.
BTW ist das Teil immer aktuell gehalten und dank dem BeatSpace so spannend wie nie.
