			ganje
Benutzerdefiniert
PC4:
EC4:
- Universal controller for all kinds of midi controllable hard- and software
- iPad compatible with camera connection kit
- USB interface with bus powering - class compliant / no driver necessary (consumption < 500mW)
- MIDI in and out ports with routing and merge functionality
- 24 pots with rubber knobs and standard midi resolution of 7bit
- Fast pot assign by incoming midi commands like control change (CC), pitch bend, program change
- Switchable snap function for all pots to avoid value jumps
- 16 setups with backup and restore functions
- Very compact design in a black casing (180x105x70 mm, 350 g)
EC4:
- iPad compatible
- Control surface script for Ableton Live is shipped with the controller
- USB interface - class compliant / bus powered / no driver necessary (consumption < 500mW)
- MIDI in and out ports by 3.5mm minijack sockets type B with routing and merge functionality
- 16 gridless push encoders - resolution = 36 pulses per revolution
- Encoder push buttons can send separate commands
- 4 x 20 character OLED-display to show control values (numeric/bar), names and programming data
- Names for encoders, groups and setups are editable (4 characters per name)
- 14 bit high resolution encoder mode for sensitive parameters
- Programmable value ranges with min/max values
- Data feedback avoid value jumps
- All encoders fully programmable in the device by channel, type, number, mode, name etc.
- Different command types like control change (CC), pitch bend, NRPN, program change and notes
- Advanced programming functions like copy, paste and fill
- 16 independent groups per setup for 16 encoders (256 commands per setup)
- Learn function for fast assignment to incoming MIDI commands
- 16 setups with backup/restore function contain all controller settings incl. names
		 Liegt's vielleicht daran?
 Liegt's vielleicht daran? . Danke für den Hinweis.
