stylophone cpm df-8 dual multimode filter
bartleby
lieber nicht.
Meet Beauty & the Beast of all filters, the Beauty is our smooth discrete analog recreation of a 2045 (24 dB/oct) LP filter, and the Beast is our proprietary analog GEN R-8 (12 dB/oct) filter that can snarl and howl in all modes (LP, BP, HP, NOTCH). We then decided to combine the 2045 Lowpass filter with the Highpass of the GEN R-8 to create three additional filter types, a Bandpass (BP+), a phaser-like Band Reject (BR+) and a very wide Notch filter (NOTCH+), for some truly unique filter sounds.
Both filter channels have all eight filter types and are controlled by two full ADSR envelopes with multiple trigger modes to cater for every need. They can be triggered by a gate signal, by an audio signal threshold, by a manual trigger button and they can even auto-repeat in a loop mode acting as LFOs.
Add to this, two built-in White Noise sources, a Sample & Hold modulation source with its own Slew parameter and a modulatable crunchy PT2399 Delay, and you have a unique filter unit that does so much more than just filter sounds. It’s a sound source in its own right, with noise, self-oscillating delay and filters, it can create anything from a whisper to complete sonic mayhem.
Like all our Compact Portable Modular (CPM) units, it can run on batteries, external PSU or a Eurorack power bus. In addition to a stereo Line Level output It has a stereo phones out socket to listen and monitor over headphones and a compact 2 Watt built-in speaker.
Our innovative enclosure design has side ribs that can be meshed and locked so multiple CPM units can be connected to quickly set up a flexible system. Pair up the CPM DF-8 with a CPM DS-2 and you have all the building blocks of a core analog modular synthesizer system in a compact and portable format.
More news on the release date and pricing mid 2025!
• 2 ANALOG FILTER CHANNELS
• 8 FILTER TYPES (4 GEN R-8, 2045, 3 COMBINATION TYPES)
• 2 ADSR LIN/EXP ENVELOPES
• 4 ENVELOPE TRIGGER MODES GATE IN, AUDIO IN THRESHOLD, AUTO-REPEAT, MANUAL
• 2 VCAS WITH ENVELOPE INVERTERS
• 2 NOISE SOURCES
• 3 ENVELOPE DEPTH ATTENUVERTERS
• 4 BYPASS SWITCHES
• 1 SAMPLE & HOLD WITH SLEW
• 1 VINTAGE PT2399 DELAY
• 14 MODULAR PATCH POINTS
• 3-INTO-1 MIXER
• 2 STEREO OUTPUTS
• 1 BUILT-IN SPEAKER
• 6 AA ВАТТЕRУ СОMPАRТМЕNT
• EURORACK COMPATIBLE
M.i.a.u.: sospro
Sehr gute Ergänzung zum ersten CPM-Modul!
Ich steh direkt auf der Warteliste...
Schöne Grüße
Bert
Oh, nice! Holt mich vom bedarf (genug vcos sind da) auch mehr ab als das cpm! Komolettes backend mit vcas und envelopes, nice :)
Postscript: ssm2045 nachbau aha… portable mutronics mutator sache? :)
Letzteres - aber ich meine, da hätte etwas von "waiting list" gestanden.
Es wird wohl ähnlich laufen wie beim DS-2, vermute ich.
Schöne Grüße
Bert
Jo!
Ich hab schon die Nachricht bekommen, dass mein "order processed" sei.
Schöne Grüße
Bert
M.i.a.u.: klangumsetzer
meiner ist heute angekommen. bin gespannt wie er klingt. Die Potis fassen sich etwas günstig an. mal sehen. aber für den preis..wenn es klingt !!! Sind ordentlich viele kabel dabei.
Ein Kabel mit nem Fader drin, denke zum regeln der cv oder lautstärke. und ein Mono Y Adapter
ganz schön hoher Rauschpegel. habe es zwar nur über kopfhörer getestet, aber das ist schon krass
Na vielleicht können wir dann bald mit einem Dubtechno-Track rechnen? :banane:
da sind schon so einige. aber warum das jetzt mit dem filter unbedingt sein sollte…stehe grade auf der Leitung. Ist das Filter so Dub prädestiniert? Es ist toll ja aber da würde ich eher mit anderen Filtern die etwas weicher sind arbeiten wollen.
Ich hatte eher den Rauschpegel im Sinn - dann kannst du dir das space echo in der Effektkette sparen XD
M.i.a.u.: citric acid
