OnTopic Waldorf M - Microwave 1&2 - Nachfolger
  • #2.911
Es wäre schön, wenn es dazu noch ein Update geben würde, das nur die ursprünglich angedachten Funktionen mit funktionierendem Multimode enthält, @rolfw
Nicht die Lösung, aber hier das Statement von Vladi, das dem Update beigefügt ist:
Multi-Mode Tips & Tricks
The M’s multimode has received considerable criticism over the years. I understand this, as
users often expect it to function similarly to digital-only synthesizers. However, the multimode
was originally intended as a highly flexible system, allowing users to configure the four
dedicated outputs for four independent instruments and process them via external effects. This
led to a complicated voice management structure with reservation of hardware voices to the
outputs, parts priority, and an inability to steal voices between parts.
Later additions to the synthesizer engine have further complicated matters. However, it is
possible to create a working multi-arrangement by following several building rules. Here I will
attempt to explain them.
Rule 1 – Parts Priority for Voice Reserve! The V.Total parameter of an arrangement sets the
number of hardware voices that M will mark as reserved and locked by the DSP for each part.
However, this is not a guaranteed reservation, as one might assume. Part priority (1 → 2 → 3 →
4) plays a crucial role here; priority always determines voice allocation. For example, if you
reserve six voices for part 1, four for part 2, and two for part 3 on an 8-voice M, the actual
distribution will be six voices for part 1, but only two for part 2 and zero for part 3. On a
16-voice M, reservations are honored as requested. Therefore, rule one is to carefully manage
your voices, considering hardware limitations and part priority.
Rule 2 — Mind the PLAYMODE parameter for the part’s sound. It is makes no sence to set more than
1 voices for Monophonic sounds, the Voice Stealing does not matter too.
Rule 3 – Only the First Part Can Use Modern Mode! This is an important restriction related to
the limited memory resources of the M’s DSP. Remaining parts can be in classic or MVA modes, but
only the first part can utilize extended RAM for the “modern” (i.e., Microwave 2) wavetable
layout.
Rule 4 – Consequently, No Transition-Enabled Parts Can Mix with Part One in Modern Mode! Because
transition replay for “classic” (i.e., PPG 2.3 / Microwave 1) mode uses the same extended RAM as
the wavetables for “modern” mode, loading a part with transitions enabled will immediately
corrupt the wavetable data for modern mode!
Rule 5 – There is Only One Arpeggiator in the M. Loading or creating an arrangement with
multiple parts containing arpeggiator-enabled sounds is pointless; only one (first) part’s
arpeggiator will function.
Rule 6 – Cross-Parts VCF Lock. Regardless of which part is selected, if a part's LOCKVCF
parameter is set to On, it will follow the VCF behavior of another part. This parameter allows
all locked parts to track the controls of the currently selected locked part. For example, if
you have three parts and parts 1 and 3 have LOCKVCF = On while part 2 has LOCKVCF = Off,
adjusting the VCF section’s controls on part 1 will cause part 3 to follow the same settings
(i.e., lock to part 1), and vice versa. However, this will not affect part 2. Consequently,
editing part 2's VCF section will not influence these locked parts.
Rule 7 – Be Mindful of MIDI Filters. The M has a flexible set of MIDI filters capable of
blocking/passing certain messages like mod wheel, pitch bend, program/bank changes, aftertouch,
channel volume, and panorama. However, there is no CC filtering! Therefore, if you have two
parts in an arrangement on the same MIDI channel, both will respond to all CCs received on that
channel. And, don’t forget about the global MIDI filters of the M, which applied first!
Rule 8 – Voices Routed to Different AUX Outputs Still Appear on Main/Headphone Output. The M
does not exclude voices routed to different AUX outputs from the main output. In other words,
the main out is a sum of all Aux outputs (which is also true from the M’s schematic
perspective).
M.i.a.u.: LaBoum
  • #2.912
Also Multimode mit mehren Parts im Modern Mode geht nicht?
  • #2.914
Soweit ich es verstanden habe nein.
Wegen DSP Speicher, schade irgendwo dass die Geräte alle so auf Kante gestrickt sind, das wäre aus meiner Sicht ein Punkt für die Contra Liste wenn das nicht funktioniert. Wenn ich die Anleitung richtig verstanden hab' gibts auch Ringmod nur im Modern Mode?
M.i.a.u.: eusti
  • #2.915
Es ist ja nur der Multimode.
Als es noch keine VSTs gab und ich nur sehr wenige Synths hatte, war Multimode für mich noch Pflicht... Aber heute, mit heutigen Möglichkeiten der einfachen Aufnahme, was damals ja noch relativ aufwendig und nicht selbstverständlich war im Homrecording, und den heutigen Möglichkeiten mit VSTs zu ergänzen, ist MM doch eher hinderlich.
Wäre nur evtl Live interessant oder - ok, das wär nen Punkt: Fürs Layern
M.i.a.u.: Hamudi2000 und eusti
  • #2.917
Genau so ist es. Der Microwave hatte keinen Ringmodulator.
Ich wollte einfach nur sicher gehen, in anderen Bereichen wurde das Konzept des Originals ja schon sinnvoll erweitert, Wavetables pro Oszillator etc. Ohne Ringmod und/oder FM hätte mich der M wohl auch schon Ende der 90er nicht interessiert. Irgendwie schade weil man 'ne Menge klangliches potential verschenkt, speziell im Zusammenspiel mit Wavetables pro Oszillator.
  • #2.918
Im Modern Mode gibt es den Ringmod ja dann und Filter FM ist auch dabei.
  • #2.919
Schon Ende der 90er hab' ich nur Klangerzeuger geholt die mindestens 4fach multitibral waren und bis auf wenige Ausnahmen hat sich daran auch nicht all viel geändert, denn es wär es bei meiner Arbeitsweise eher kontraproduktiv wenn ich die eigenen Sounds mit den Funktionen die ich gerne nutze nur für einen Part einsetzen könnte. Ich nehme an die Erweiterungen auf 16 Stimmen liefert da keinen extra DSP für 'nen 2ten Modern Mode Part?
  • #2.920
Nein. Leider nicht - aber dennoch ist der M ja vierfach multitimbral. Nur halt nicht mit allen Features.
  • #2.921
Schade, dass Hermode Tuning nicht kommt, das konnte der MW1 damals und ich habe es sehr geschätzt. Zumindest ist Fingered Portamento endlich drin. Werde die neue Firmware heute Abend Mal installieren.
M.i.a.u.: qwave
  • #2.922
Leider ist das was, wofür Lizenzbeiträge nötig wären. Ist ja keine Waldorf Entwicklung. Ich habe das beim WAVE geliebt und vermisse das mehr als den Klang des WAVEs.
M.i.a.u.: eusti und Hamudi2000
  • #2.923
Schon Ende der 90er hab' ich nur Klangerzeuger geholt die mindestens 4fach multitibral waren und bis auf wenige Ausnahmen hat sich daran auch nicht all viel geändert...
Irgendwas ist immer und den perfekten Synthesizer gibt es nicht und wird es nie geben. Was auch immer die eigenen klanglichen Ideale sein mögen.
M.i.a.u.: Axel Jungkunst
  • #2.924
Oder zum Jammen. Natürlich hast du Recht, dass der MM nicht mehr zwingend notwendig ist. Aber ich will alle Spuren gleichzeitig auf meinem Mischpult haben; ganz in der klassischen Technomachart. Meine Musik soll mehr oder weniger live sein bei begrenztem Platz. Deswegen war der MM ausschlaggebend und die nachträglichen acht Stimmen ein „Pflichtkauf“.
  • #2.925
Es geht weniger um Perfekt, sondern um sinnvolle Parameter Kombinationen jenseits der aktuell herrschenden klanglichen Vergangenheitsbewältigung. Bin da eher bei animierten Obertönen, Texturen und flexiblem Charakter und nicht sentimental genug um Klänge nutzen zu wollen die bei Musik genutzt wurde die bei mir in der Vergangenheit Emotionen ausgelöst hat die beim hören immer wieder abgerufen werden. Wenn ich Sounds für mich mache geht geht es bei mir halt schon sehr lange nicht mehr darum zu klingen wie, es geht eher darum das sich für sie auch ohne Vintage Brille für mich funktionieren sollen.
Der Ansatz dem M noch so ein paar Synthese Leckerlis zu verpassen hat mich neugierig gemacht und auch das er 4fach multitimbral ist, das kombiniert und wenn mir vielleicht mal einer günstig über den Weg gelaufen wäre, aber so kann ich die Cons auf meine Merkliste packen. Von daher danke für die Antworten!
  • #2.926
Das hängt ein wenig mit meiner Arbeitsweise zusammen, ich beschäftige mich meist intensiv mit einem Klangerzeuger, mache 'ne Reihe von Sounds von denen mich einige dazu inspirieren mit ihnen Musik zu machen, nur 4 davon gleichzeitig nutzten zu können ist schon ein Kompromiss, wenn auch das nicht zwangsweise mit voller Polyfonie sein muss, für die kompromisslose Version gibts ja ganz zum Schluss HD Recording. Ich bin zu wenig vintage orientiert und war schon in den 90ern Sound technisch schon zu abgeklärt um groß Verwendung für Sounds im reinen MW1 Bereich zu haben.
  • #2.927
Soweit habe ich die Features der neuen Firmware noch nicht ausprobiert, aber ansonsten scheint der M gut mit 1.11RC1 zu laufen.
Ein paar Anmerkungen zu Punkten die ich weiter oben angesprochen habe:
Patches lassen sich sowohl mit dem Edisyn Editor als auch mit Midi Quest herunterladen.
Man kann bei Edisyn einstellen welchen Bereich der Patches / Bänke man herunterladen möchte.
Es dauert eine Weile alle 16 Bänke herunter zu laden. Mit Midi Quest kann man (soweit ich verstanden habe) nur einzelne Bänke herunterladen. Ich bin mir immer noch nicht sicher was die beste Strategie ist um die Sounds besser zu organisieren... Bin immer noch nicht so der M Programmierfuchs, finde es aber trotzdem doof immer wieder an Patches zu geraten, die ich unbrauchbar finde... Deswegen lösche ich die dann gerne... Das ist schon ein guter Schritt, aber was dann? Eine Bank mit Pads? Eine mit Bässen? Wie macht ihr das?
  • #2.928
Eine frage zur FW 1.10
Irgendwie verhält sich mein gebraucht erworbener M komisch: Ist das normal das bei nahezu jedem patch der interne sequencer startet und mir meine programmierte line überspielt!?
Ich kann den abschalten aber bei jedem start von Ableton startet der M-sequencer neu.
Ich kann keine einstellung finden die das verhintert: weder im M (systemsetting) noch in Ableton (voreinstellungen)
Weiss jemand was da los ist!?
Die neueste FW habe ich noch nicht aufgespeilt - da warte ich lieber noch ab...
  • #2.929
Hast Du in den System Setting versehentlich Midi Clock Mode auf EXT oder AUTO gestellt, stat auf INT? Oder in Ableton für den Kanal Sync deaktivieren in den Voreinstellungen.
M.i.a.u.: Palindrom
  • #2.931
Neues Update mit neuem Release Candidate der Firmware 1.11 via Gearspace.com:
"Ahoi, M pirates!
Here is the latest version of firmware - FW 1.11 RC2.
Link on my GD : https://drive.google.com/file/d/1dTU...usp=share_link
Lot of stuff was tested and fixed, especially voice allocator for monophonic single modes (legato / portamento) and multi-mode (voice allocations / part guards).
Short list of changes :
- new voice allocator for the multi-mode;
- updated voice allocator for the legato / portamento monophonic patches in single mode;
- various bugfixes (WaveEnv in multi mode, Smooth with LinFM corruption for the modern mode);
- UI changes : wording to more correct / neutral, neutral,mistypes fixed, red color changed to the orange color in popups;
- part guards were REMOVED as annoying for users (and to free space for new allocator
Lol smiley
-MVA compatibility with multi mode has been improved and now reflects part modes correctly.
The list of bugs reported by Frostwilder was completely checked and tested. Report will follow today later.
I am deeply appreciate your input into testing. Thank you all for your help again!
your Vladi"
M.i.a.u.: majestix, Hamudi2000, ModernerPurist und 2 andere
  • #2.932
Ich bekomme den M nicht gut ans laufen - es hakt hier und da... FW 1.10
Kann jemand mit der fehlerbeschreibung etwas anfangen!?
"Im sustain-status klingt der ton einfach weiter, obwohl Release ausgelöst wird. Also der ton klingt schon aus... du hörst aber noch den ton aus dem sustain-status. Das liegt auch daran das die standart-patches den sustain gerne auf 100% haben - was ich sowieso nicht verstehe! Dann gibt es noch einen seperaten VCA amount, der spielt da auch mit rein.
Stellt man sustain auf 0 dann ist auch der ton weg und man kann das teil "normal" spielen.
Das ist auch nicht bei jeden patch so!!!!
Eigene patches laufen einwandfrei - daher gehe davon aus, das es kein hartwareproblem ist."
  • #2.933
Nicht so richtig: Der Ton klingt aus, bleibt aber im Sustain? Was ich mir darunter vorstellen könnte, ist, dass die VCA Releasephase zu lang ist. Dann scheint der Ton über den Filterverlauf und/oder das Wavetable Morphing vielleicht im Frequenzspektrum auszuklingen, aber nicht, oder nur sehr langsam, in der Lautstärke. Eine andere Möglichkeit wäre eine unbekannte VCA Modulation.
Womit steuerst Du den M den an - Keyboard oder Sequenzer? Gibt es vielleicht hängende Midi-Noten?
M.i.a.u.: Palindrom
  • #2.934
Danke das werde ich prüfen!
mit dem sequencer angesteuert...
ps: Ich versteh die welt nicht mehr... heute aus seiner verpackung nochmal raus und heute spielt er so wie ich das erwarten würde - nämlich ganz normal.
Werde meinen fehler nicht finden... Naja, besser so als anders herum! (Trotzdem sehr frustrierend!)
Der M scheint in meinem ersten setup von irgendwo her kein "note off" erhalten zu haben.!? Das würde das verhalten erklären (aber nicht die ursache)
Test:
Anhang anzeigen TEstM.mp3
