mmai
Ableton* 9.2 kommt bald...
Ehrlich gesagt hätte ich bei einem x.2 mehr Features in Sachen Push erwartet. Im Gegensatz zu vielen hier finde ich nämlich, dass Push noch überhaupt nicht fertig ist - für so viele essentielle Sachen ist die Maus notwendig (schon in den ersten Minuten beim Starten eines neuen Songs). Tja, dann bleibt nur noch das ungewisse Warten auf ein (kostenpflichtiges) AL10.
Was mich auch ziemlich nervt - bin nämlich bewusst noch auf 10.6.8:
Dropped compatibility for Windows XP and Vista, OS X 10.5 and 10.6.
Improvements and feature changes:
Added the Tuner Device to the Live audio effects.
Added a "Start Transport with Tap Tempo" preference to determine if Tap Tempo is going to activate playback.
Improved tempo detection for warped audio files where the tempo appears to be constant.
Improved the sound of Complex and Complex Pro Warp modes.
Added the option "Warp Selection as x-Bar Loop" in the context menu when right clicking on a time selection inside an audio clip.
Live Sets that contain Max for Live devices or third-party plug-ins now have lower latency.
Automation and Modulation are now fully latency compensated.
Modifying the Arrangement loop brace with mouse or keys will not affect the current track selection, while previously all tracks were selected as soon as the braces where adjusted with the mouse.
Bugfixes:
When switching between Note and Scene mode with the APC20, the Pad LEDs would occasionally not update correctly.
The Session Ring would not be entirely displayed on screen anymore when navigating through tracks if the Live Set contained folded Group tracks.
Fixed a bug in the Axiom Air 25, 49 and 61 Control Surface remote script, where the Send mix mode controlled the available Sends for the currently selected channel, instead of controlling Send A for the first 8 channels.
Fixed a bug in the MPK Control Surface remote script, where the Record Arm button had to be pressed twice to be toggled, and Exclusive Arm would not work.
Fixed a bug in the Vestax VCM600 Control Surface remote script, where the Punch In and Punch Out controls would work only as momentary toggles.
Fixed a bug which caused artefacts in the waveform visualisation when increasing the Gain on low amplitude audio clips.
Live would not display bluetooth audio devices in the Input and Output device menu under Preferences-->Audio
When controlling a number of mixer or device parameters via Aftertouch, crackles could be noticed in the audio stream.
The Live browser "All Results" label would not remember the settings for the optional second column.
Fixed a rare crash which might happen on OS X with certain input sources.
Fixed a crash which might occur when deleting several Max for Live devices from a Live Set at once.
Live would crash when quitting the application while renaming a Groove in the Groove Pool.
Changes for Push:
Added 64 Pad Drum Rack mode for Push. The Note button now toggles between the Drum Rack three section layout and the 64 Pad Mode.
Improved Aftertouch response and added an Aftertouch Threshold setting in the Push User Preferences
Added Modwheel functionality for the Push Ribbon Controller. Tapping the Ribbon Controller while holding "Select" toggles between Pitch Bend and Modwheel function.
Holding "Delete" and tapping an encoder on Push resets the respective parameter to the default setting.
Holding "Shift" while turning an encoder on Push changes the respective parameter with finer resolution.
Improved buttons readability on Push. The Repeat and Metronome buttons now blink if active.
When recording using Repeat on Push, the MIDI notes would be recorded with a negative offset with respect to the grid if the option “Reduced Latency when Monitoring” was on. This caused the very first note in the Clip not to be played back at all.
Using "Shift" + "Add Effect" or "Add Track" while in Scales mode would cause the display to show the Note Layout options even after releasing the Shift button.
When selecting a Drum Rack Pad set to Multisample mode with Push, pressing “Device In” with Push would automatically select the first device in the Chain list, and it would not be possible to go back to the enclosing Instrument Rack device.
*) Affiliate/Werbung
