SirAdrianFish
TheSilentVisitor
Trash80 [M8],
Version 6.6.2 Released - One day(s) since last bug and EQ spectrum drawing improvements@M8s Read the readme.txt file if you need instructions.
Manual needs to be updated. Expect delays.
Current M8 Firmware:
https://github.com/DirtyWave/M8Firmware/raw/main/M8Firmware.zip
Full changelog can be read here:
https://github.com/Dirtywave/M8Firmware/blob/main/changelog.txt
Headless version will be updated in the coming weeks. Some features may not be included.
2026-08-22 - Version 6.6.2
- Fix: ARP retriggered an instrument that had already been turned off with KILL/OFF
- Fix: Sampler - STA on the same row as an instrument trigger did not restart envelopes
- Fix: Firmware Update - Settings and project autosave are written after confirming, before restart
- Fix: Mute/solo after boot let the first notes of muted tracks through
- Fix: RMX FX command - Tracks in song selection loop mode continued past the loop region
- Fix: EQ View - Spectrum briefly showed the next instrument when switching, even if it used a different EQ or none
- Fix: EQ View - Mix / FX EQ switched to bank 00 after a display reset
- Improved: EQ View - Spectrum now includes left and right (was left only)
- Improved: EQ View - Improved spectrum visuals
