Elastic Drums jetzt für iPad
https://www.sequencer.de/blog/ipad-versi ... rums/22204
sind da - eine Art Electribe R - also Drumsynth mit verschiedenen Syntheseformen pro Drumsound.
Promocodes gibt es auch, aber natürlich für treue Sequencer.de Blog-News Leser..
Naja "syncing Options"....wie oft hab ich das schon bei ner App gelesen und was war? Käse im Quadrat!
Ich präzisiere die Frage mal: Läuft es stabil in Sync?
Moogulator schrieb:
'n paar mehr Infos wären schon angebracht.
(Tust du auch immer meckern) ;-)
Features
Elastic Drums is an iOS app with 6 channels of synthesized sounds, a step sequencer and 4 effect channels, all tweak-able in an elastic way.
– 6 synth channels with 10 different percussion synth engines
(kick, snare, hihat, clap, tom, wobble, fm, fm4, square, grain)
– 12 parameters for each synth engine
– automation for each parameter via knob recording or velocity
– 4 send effect channels with 2×11 mono effects and 2 x 9 stereo effects
– automation for all of the 8 possible effect parameters via xy pad
– master effects (stutter, delay, compressor …)
– 16 step sequencer for the 6 channels, each with own tempo multiplier & length
– record audio and export to Soundcloud or Audioshare
– email audio recordings and presets
– iOS 8 supported
– Audiobus supported
– Inter-App audio (IAA) supported with transport control
– Midi start/stop/sync
Because all sounds get generated in realtime, the app is cpu heavy! iPhones 5 and greater can handle it with no problem, on iPhone 4s effects 3 and 4 get switched off by the engine automatically to save some cpu power. iPhone 4 and iPad1 are NOT recommended!
Plans for upcoming versions
– Midi controller support
– Midi notes recording
– native screen size for iPhone 6, 6+
– new sequencer features (rolls, etc.)
– new synth engines (other percussions, sampler, etc)
Releases
– iPhone version: out!
– iPad version: out!
– price: $ 9.99 (Universal = for both iPad & iPhone apps together)
Reviews
- http://www.musicappblog.com (iPad)
- http://iosmusicandyou.com (iPad)
- http://createdigitalmusic.com
- http://main.iosmars.com
- https://www.sequencer.de
- https://ipadmusiced.wordpress.com
- https://zlaurent.wordpress.com
- http://www.palmsounds.net
Moogulator schrieb:
Es gibt da 2 Links, was es tut, aber generell ist das schon richtig, schadet hier natürlich auch nicht.
Das tut aber weh, wenn ich 2x klicken muss.
Da kriege ich ne Entzündung.
alles klar - finde das generell auch gut/besser - ausnahmen sind nur Sachen die eh auf dem Blog zeitgleich stehen wie hier.
Ok, da steht faul - dann das au'nich.
Ja, wie dem auch sei - das ist wie bei den Machines der Machinedrum, finde ich ein sehr nettes Konzept.
Etwas einfacher als Stroke Machine aber auch mit mehr als einem 16er Pattern.
Das fasst's weitgehend zusammen und ja - Zusammenfassungen als Erstpost sind besser. Kann ich mir selbst auch empfehlen.
Der Vergleich hinkt, weil SM auch chromatische und polyphone Sachen drauf hat. Elastic Drums = Drumcomputer, SM = Groovebox. SM "kann" übrigens auch deutlich mehr als 16 Steps.
