khz
||𝝞|𝝞||𝝞|𝝞|𝝞||
Hat den jemand von euch und nutzt diesen für seine Synthesizer.
Hat ja Stereo I/O wie auch MIDI/USB I/O, massig Audio als auch MIDI Effekte, Instrumente, ist frei konfigurier und rout -bar.
Theoretisch ja nettes flexibles Tool.
Da es eine "offene Plattform" (open source) ist kann man direkt mit Entwicklern reden und wünsche äussern bzw. ~bugs melden oder selbst Code hochladen. Etc. pp..
MOD Duo 1st Wireless MIDI Test with iPad & Quicco mi.1rev3 -- and OP 1's Sequencer via USB-MIDI
First Test -- "MOD Duo" with "3TrinsRGB+1c"
"MOD Duo" Sound Comparison Test - - with Tiny Speaker and Standalone Modular
WHRMMY Pedal Frist Test with MakeNoise's ø-cøast and MOD Duo>> [url:1mzsibux]https://moddevices.com/pages/mod-duo[/url] << schrieb:Quick Specs
Power supply that works in every country (100V ~ 240V @ 50 ~ 60 Hz)
Compact dimensions: 180 x 74.7 x 160 (W x H x D, millimeters) / 1.2 kg
Completely independent audio inputs and outputs
Configurable input and output gain: use it with any instrument
Outputs usable in balanced and unbalanced mode: connect to any device
USB-device port for connecting to the computer
Headphone out with dedicated volume control and direct monitoring option
High-fidelity audio path
Relay-based True-Bypass
Full MIDI support - both legacy DIN and USB MIDI
USB-host port for connecting peripherals (Bluetooth dongles, etc)
Expand connectivity with a USB hub
Control Chain port for connecting MOD peripherals
