Colibri HE
Dlxmusic.se:
Delivering massive sound in a compact package, Messenger features two oscillators with wavefolding functionality, a sub-oscillator with continuously variable waveshapes, dual looping ADSR envelopes, 32 semi-weighted full-size keys with velocity and aftertouch, and the legendary Moog ladder filter augmented with resonance bass compensation, multiple filter slopes, and true multimode functionality.
Complete Feature List
32 semi-weighted full-size keys with velocity and aftertouch for responsive feel and dynamic control
Two continuously variable-shape VCOs and unique hybrid wavefolders, sync, and FM capabilities
Sub-oscillator with continuously variable waveshape for added bass weight
White noise generator for interesting texture and depth
Moog transistor ladder filter with unique pole-mixing design for 4-pole low-pass, 2-pole low-pass, band-pass, and high-pass responses
Resonance control with resonance bass compensation (RES BASS) switch to preserve and punctuate low end
External input to filter, feedback, and VCO FM of filter cutoff for expanded audio processing
Dual loopable ADSR envelopes with velocity responsiveness and multi-trig
Variable shape LFO (LFO 1) with sync, reset, and independent modulation bus for pulse-width modulation, dynamic wavefolding, filter FM, and more
Triangle-wave LFO (LFO 2) tied to MOD wheel and routable to multiple destinations
Pitch wheel, octave transpose, and variable response glide
256 preset locations with 240 factory presets organized into 16 categorized banks for immediate access to professionally designed tones and textures (basses, leads, pads, arps, percussion, and more)
Save up to 256 sequences each up to 64 steps and add probabilistic generative behavior and parameter recording
Unique configurable arpeggiator with multiple pattern modes and rhythmic programming
Headphone output
Analog clock in/out, control voltage in/out, gate in/out via 6x 3.5mm jacks for interfacing with analog synths and Eurorack
MIDI IN/OUT via 5-pin DIN or USB-C for compatibility with your favorite DAW
Sustain pedal and expression pedal inputs via 2x 6.5mm jacks for further control of sound in performance settings
Headphone output
