Moog * Phatty: Firmware Update 3.1
Gibt's hier:
http://moogmusic.com/OSv3.1
Klingt vielversprechend:
- Volume Velocity Sensitivity: The ability to map note velocity to output volume with fifteen adjustable levels of sensitivity saved per preset. [Tribute Edition hardware does not currently support this feature]
- Legato Glide: Automatically engage the pitch glide between legato notes. Non-overlapping notes snap instantly to a new pitch. The user is able to play or sequence dynamic bends and slides mixed with cleanly-articulated notes.
- LFO Reset: The ability to reset the LFO cycle at the start of each note. Two LFO trigger modes provide dynamic new modulation possibilities.
- Sustain/Hold Mode: A sustain pedal or control voltage plugged into the CV GATE input jack can now be used to send MIDI Sustain on/off, and to polyphonically sustain MIDI notes from the Phatty keyboard.
- 14-bit MIDI: All Phatty synths can now send and receive high-resolution 14-bit MIDI messages for critical voltage-controlled parameters.
- MIDI Output Filtering: New options control which MIDI CC messages are sent from the Phatty, for maximum compatibility with external gear.
- Expanded MIDI Clock sync options: 22 clock divisions including triplet values for both LFO and Arpeggiator MIDI sync. Clock divisions range from 32nd triplets up to 4 bars.
- Improvements to Arpeggiator:
· Global Arp Setup menu: Set important arpeggiator parameters at a global level. Arpeggiator also remains active when presets are changed.
· Gate Length: Adjust the arpeggiator note length from 50% to greater than 100% (overlapping), for a range of new sonic textures.
· Arp Clock Send: Arpeggiator can now send MIDI Clock, MIDI Start and Stop messages, allowing you to synchronize other gear to the Phatty internal clock.
- Improvements to Polyphonic Mode:
New polyphonic note-allocation scheme: Uses a “round-robin” algorithm to share notes across multiple Phatty synths in a natural and very playable way.
Polyphonic arpeggiation: Multiple ways to use the Arpeggiator across a poly chain of Phatty synths, from tight integration to completely freeform.
Finde ich ja Klasse, dass da immer noch was (Neues) nachkommt.
Cool, sowas möchte ich für den Voyager...
btw. anscheinend kommt jetzt eine Little Phatty BLACK Edition:
stimmt, der regulaere vogy hat das, beim OS muss man patchen, der hat statt der LFO-sync-wahl einen schwingungsform schalter...
"Two LFO trigger modes provide dynamic new modulation possibilities."
Morbid schrieb:
Das geht doch.
Einfach LFO Sync auf KB stellen.
Oder hab ich da was falsch verstanden?
Hm, interessant...vielleicht hab ich da ja auch was falsch verstanden...gilt das dann nur für Noten die über das KB gespielt werden, oder auch für Noten über Midi In? Auf alle Fälle ist es cool was Moog für die Phatty Besitzer noch so an Funktionen einbaut.
pulsn schrieb:
Morbid schrieb:
Das geht doch.
Das muß über Midi gehen, sonst wär die Funktion bei der RME Version ziemlich nutzlos :wink: .
Wo und ab wann gibts den denn? Hatte mal im April eine Moog-News gelesen, dass es die Seitenteile in schwarz als separates Extra zu kaufen geben sollte. Wäre natürlich Klasse, wenn die das in Serie anstatt der hässlichen grauen Plaste-Teile anbieten würden...
duerfte noch recht frisch sein, ist grade erst auf moogmusic.com aufgetaucht... nachpimpen duerfte ja easy sein, wahrscheinlich sind das eh nur die lagerreste vom redback. ;)
die neue firmware ist echt super..jetzt kan der arp durchrattern und mann wechselt mal eben zum nächsten patch und er leuft weier :-) echt lecker
(Sieglinde: „ich -w *-ürzt ihm betäubenden Trank“)
* wirsch
Jedenfalls wirkt das optisch auf mich deutlich harmonischer mit dem schwarzen Look. Klasse finde ich, dass Moog hier mit Firmware-Updates nachlegt. Sind ja gute Features hinzugekommen.
ich sag mal nix dazu.
obwohl, um den thread mal rischtich zu zerpflücken und verwirrung zu stiften und ins offtopic zu manövrieren...
phatty ist phatty?
meine,die firmware von lp und sp ist identisch?
schon.. oder?
archy?
"Sustain/Hold Mode: A sustain pedal or control voltage plugged into the CV GATE input jack can now be used to send MIDI Sustain on/off, and to polyphonically sustain MIDI notes from the Phatty keyboard."
Geht das nur wenn ich mehrere Phattys / Slims gestackt habe oder kann ich da einfach ein Sustainpedal an die Buchse KB Gate? eines Phatty hängen und der kann dann z.B. Akkorde halten? :adore:
So ein Update kann doch das Teil nicht mehrstimmig machen - oder doch?
so wie es beschrieben steht, der LP sendet ja auch MIDI polyphon. frueher war das GATE-IN nur fuer die interne klangerzeugung, die ist natuerlich nur monophon. geht also nur mit polyphonen externen synths oder eben mit mehreren LP im poly-chain.
