island
Modelleisenbahner
Klingt spannend
https://neunaber.net/products/illumine
https://youtu.be/wCg923tUFK8
- 17 stellar stereo reverb effects cover all of your reverb needs.
- 50 professionally-crafted factory presets for superb tones right out of the box.
- 50 user presets to customize and save your favorite settings.
- MIDI input & thru/out. Controller mode replaces a simple MIDI controller.
- Powerful, flexible expression control engine. Use an external expression pedal or the built-in A/B switch with adjustable transition times.
- Analog dry signal for low noise and zero latency maintains the integrity of your source tone.
- Adjustable gain structure works with instrument or line-level inputs.
- High contrast, wide viewing angle display is easy to read from a distance.
- Small footprint with top jacks, ILLUMINE is easy to incorporate into your pedalboard.
- Power with a standard 9V @ 100mA pedal power supply (not included). No need to run a separate power adapter or free up a high-current power port.
- Manufactured locally in Orange County, California. Family owned and operated, Neunaber Audio is dedicated to bringing you the highest quality audio effects on the market.
