Neutral Labs Scrooge
neutral-labs
neutral-labs.com
Heute erscheint als idealer Begleiter zur Elmyra 2 der Neutral Labs Scrooge.
Scrooge is a sequenced malfunction generator, available as a 42 HP Eurorack module or semi-modular desktop synth. While you can convince it to deliver boomy kick drum sounds, clicky hi-hats or metallic snares, it would much rather be making glitchy artifacts, hollow crackles and horribly distorted growls. It contains a sophisticated and performance-oriented step sequencer with parameter locking and the possibility to control all steps across multiple tracks at once. Its 5 distinct and fully analog voices are made up of special circuits that work without dedicated power supplies, scrounging power from the sequencer control signals instead, which gives them an organic and unstable quality. As a bonus, it means you won’t have to power the unit itself if you sequence it from external gear.
* 5 distinct analog voices
* device can work passively without a power supply if sequenced from external gear
* each voice can be routed to either of 2 main outputs (headphone compatible)
* individual voice outputs
* individual voice CV inputs that respond well to audio signals
* 2 modulation tracks, individually routable to voices
* 2 modulation CV inputs
* onboard step sequencer
* parameter locking per step
* "control all" mode (change parameters for several steps and tracks at once), great for interactive playing
* arbitrary step length per track (up to 64 steps)
* generative algorithm builds random variations on patterns (available while performing), or creates random patterns from scratch
* pattern chaining (up to 32 patterns)
* stores up to 128 patterns in 16 banks
* microtiming
* CV slew limiter per track
* can sequence external gear
* sync output
* sync and reset inputs
* MIDI input (TRS type A)
Hier ein Video von Mylar Melodies:
Das Kit ist nicht allzu kompliziert zu bauen und meiner Meinung nach prinzipiell auch für Anfänger geeignet, vor allem dann, wenn schon ein wenig Löterfahrung vorhanden ist. Alle SMD-Teile sind bereits vorinstalliert, es geht also nur um die Bedienelemente. Bauzeit etwa 1-3 h, je nach Können.
Exploding Shed hat Kits vorrätig, also greift zu. :)
Hast Du doch hier schon geposted:
Genau, das war im Modular-Forum und hier ist DIY. Hab ich bei Elmyra auch so gemacht, um die Diskussionen um den Zusammenbau von dem anderen Kram getrennt zu halten. Scrooge gibt es ja als Kit oder fertig gebaut.
Coole Kiste!
Mich würde interessieren, im passiven Modus, ist der Sound anders je nachdem wie hoch die Spannung der Gate-Signale an den Eingängen ist?
Genau, das ist ja die Idee dahinter: Der eingebaute Sequencer generiert nicht nur Gates, sondern veränderliche CV, und erreicht dadurch eine breite Palette an Klängen für jede Stimme. Und das funktioniert auch passiv. Richtig cool ist es, Audio in die Eingänge zu senden, zum Beispiel eine Bassline. ;-)
Hier hat SCROOGE DIY Standalone, wohl ein sonst schweigsames Forenmitglied inkognito gelötet 🤭.
( Aber leider nicht geschafft, trotz guter Absichten und vollständig vorhandener Videodoku, das in Reihenfolge zu bringen - Dawless Typ halt wie ich aus sicherer Quelle weiß 🫣😂).
Mir jedenfalls ( seid meiner Kindheit Blei im Arsch ). Aktuell immer noch nicht der Beatprogrammierer ist:
In meinem Setup, SCROOGE willkommen im Einsatz:
Mein DrumBrute erzeugt nur rudimentären einfachsten DrumBeat mit 2 klassischen elektr. Drumsounds ( BD+Clp z.B.).
SCROOGE ergänzt mit allem anderen, handson und sehr variabel in Modulation schon ohne patchen externer Quellen.
Sehr entgegen kommen mir die Schalter pro Stimme, mit denen ich dry/mute/wet schalte, nach Gusto.
(Ich liebe es im Affekt Schalter umzulegen, Drehregler bedienen für Hüllvenänderungen - solange man sein Instrument gelernt hat, in welchen Grenzen man dies tun kann.
Bin weniger der Typ der dies im Voraus plant, programmiert - sondern handson, solange die Hände ausreichen. Mit späterem Plan, verfeinert, dann programmiert um Hände dreinzuhauen bekommen)
Mischen / routing is immer noch eine Schwachstelle in meinem Modularen.
SCROOGE DIY Standalone, eine Ergänzung die mir Spaß macht und schneller ist für Ideen, als in meinem Modularen.SCROOGE soldering
Hier ein (wie ich finde) sehr schöner Jam, der zeigt, dass Scrooge nicht immer so grantig klingen muss, sondern sich auch zur Begleitung liebreizender Harmonien eignen kann. ;-)
